Problem with resistor HP 450 G1
  • playgr
    • May 2022
    • bulgaria
    Hi, I have the following problem with HP 450 G1
    When I turn on the charger, the element I showed (resistor 330) becomes very hot and hits light current when touched. The laptop does not turn on.
    I'm a beginner so I'm asking here if you can give an idea where to look for the problem
    Greetings
    !!! I apologize this post is not for this topic. If the post can be moved
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Problem with resistor HP 450 G1
    follow the trace, but i bet one of that diaodes is shorted
    remove resistor and i bet that one side have voltage and other side is shorted
    • jinu_j
      by jinu_j
      Hi
      05-03-2025, 10:51 PM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • mikey5791
      Need help to replace burned resistor in 350w atx psu
      by mikey5791
      Hi to all forum members,
      Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
      The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
      Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
      Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
      12-26-2024, 04:55 AM
    • artvandalai
      What resistor ohm will work better to repair this waterpik?
      by artvandalai
      The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
      01-05-2025, 04:10 PM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
