Macbook air a1932 bootlooping after airport control
  • Featurea
    • May 2021
    • 23
    • Polska
    once again I am here with problems with my macbook. After successful repair, when everything was working fine, I took my macbook air to the airport and flight with it in carry-on baggage. Firstly after landing it was working fine, but suddenly it shuted down and started bootlooping to the apple sign. I managed to run it normally throught SMC reset, but problem was going back untill SMC reset stopped working. Now Macbook is bootlooping in normal start, I can't go to recovery, I tried internet recovery, but after fully loaded download bar it switches off.
    I have no idea what to do now. NVRAM reset is not helping, battery removal is not helping also.
    I was thinking about new SMC? Or maybe hard disk just end its life...
    Not sure if it is connected somehow with airport control or flight, I know it shouldn't be, but it is what it is...
    My motherboard is 820-01521, maybe you will have some idea what to do? I would really appreciate any help, thanks.
  • mon2
    • Dec 2019
    • 14779
    Re: Macbook air a1932 bootlooping after airport control
    Try a USB media boot to rule out a corrupt OS.
    • Featurea
      • May 2021
      • 23
      • Polska
      I tried to do bootable USB with MacOS, but I have only windows, so managed only to do EFI boot from OpenCore, which is seen by macbook as at the picture, but after choosing this boot device it is switching off and going bach to boot loop... Do you have any good advice how to do bootable USB with MacOS on Windows?
        • 22209
        TransMac is what ive used before.Not sure if there`s any other alternatives
        • Featurea
          • May 2021
          • 23
          • Polska
          I tried that too but not sure where to find good dmg file with macOS... can you recommend something?
          • Featurea
            • May 2021
            • 23
            • Polska
            Ok, so I managed to do USB installer on other macbook, but it is still bootlooping after trying to boot from USB Any other ideas what should be checked? Now I think this is hardware issue...
            • todenkopf
              • Oct 2014
              • 49
              • UA
              Welp.. X-ray could damage flash memory, but its too rare case. Does it bootloop with ssd removed?
              • Francisco.s
                • 686
                • Spain
                Try DFU Restore:
                https://logi.wiki/index.php/DFU_Mode...roubleshooting
                • Featurea
                  • May 2021
                  • 23
                  • Polska
                  There is no removable SSD disk, so I can't check that. I also don't have another macbook so DFU Restore is not an option for me also...
                  • bouch
                    unlock macbook air A1932 2019
                    by bouch
                    hi
                    i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                    i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                    i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                    have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                    I need help or information?
                    Does anyone have the minat2 activator 1.4 software?
                    Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                    Thank yo...
                    03-12-2025, 10:14 AM
                  • reessi
                    Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                    by reessi
                    With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                    No corrosion any where!
                    Tried a replacement power button off ebay and the same.
                    Very occasionally it will work with the power button connected!
                    Same results with or without the battery.
                    Can it be a fault with the Audio board or the mainboard?
                    The touch Id assembly connects through the Audio board first then to the Mainboard.
                    Flex...
                    06-26-2024, 03:31 PM
                  • nikolayu
                    MacBook Air A1932 internet recovery loop
                    by nikolayu
                    I have A1932 that is going to internet recovery every time.
                    i tried nvram and smc reset but it looks that MacBook is not reacting to that.
                    i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
                    keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
                    also won’t open option to boot from usb device.
                    and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
                    07-22-2025, 02:55 AM
                  • TOMÁŠ
                    MacBook Air A1932
                    by TOMÁŠ
                    Hi, I've never worked with a MacBook before, so I need some advice.
                    I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
                    05-20-2025, 11:19 AM
                  • Arshad alam4659
                    macbook air a1932 sign out of find my
                    by Arshad alam4659
                    Today I receive a MacBook Air A1932, its apple ID has been deleted but when I am resetting it is showing a message(sign out of find my ) customer's have no apple id he bought this MacBook from someone else can someone help me remove this message...
                    04-09-2025, 12:37 AM
