MSI MS16J11 - no 3.3/5V
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3567
    • slovakia
    Hello.
    HAve this MSI MS16J11 that have no 3.3V/5V. i found that SUS_ON signal was shorted by IC PU10. so i replace ic, now have SUS_ON - 3.3V, but absolute no reaction on 3VSUS and 5VSUS. I have REG3/5 ok, i have win, i check all mosfets. all looks good but this crap still wont release SUS voltages.
    any hint?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: MSI MS16J11 - no 3.3/5V
    Post PU10 Voltage on all pins??
    • kalilinux25
      ASUS X1403ZA R2.2 shorted +3VSUS
      by kalilinux25
      Ive isulated everthing and 2 thing is getting hot the pcb board and the cpu mildly
      +3VSUS resistance to gnd is 1.6ohms
      also i remove the PL8601 to isulate the low resistance side from the +1.2V Im getting 148 ohms resistance
      hope someone can help me how to determine and find the issue oif this low resistance
      04-09-2025, 09:18 AM
    • martin83
      Asus gl504gm 3.3v with 7v
      by martin83
      Good afternoon everybody.
      I would like to ask for help identifying a problem that I will describe below.
      Asus gl504gm laptop
      Won't power on
      When connecting a power supply to the input, it does not turn on and consumes 5mAh, but if you connect the battery, the battery voltage is present and when you press the power button, it starts without an image with:
      pch- 1v
      3.3vsus - 7v
      5vsus - 5v
      tps51285a is new
      pch was changed
      3.3 mosfets replaced
      1.2 controller replaced as well as the respective mosfet.
      No power supply has...
      01-07-2025, 11:49 AM
    • t34v2
      MSI GV72 MS-16j91, dead, no SUS_ON
      by t34v2
      MB: MSI MS-16J91 ver 1.0
      CPU: i7-7700HQ SR32Q
      PCH: SR30W
      GPU: nVidia N17P-G0-A1
      KBC: ENE KB9028Q C
      No response to the power button (3.3V present on the button).
      After pressing the button, the +3VSUS/+5VSUS converters should appear, but this does not happen.
      KBC does not issue the SUS_ON signal (PU4 pin6 and pin20 = 0V).
      +3VALW and +5VALW present.
      Choke11 (+3VSUS) = 0V, 4kΩ
      Choke10 (+5VSUS) = 0v, 11kΩ
      I inserted another KBC programmed for this board - the same result.
      I have placed KBC chip to another board...
      03-18-2024, 05:49 AM
    • MobsterLobster
      ASUS FX505DT w/ FX505DD Mobo - Not Turning On
      by MobsterLobster
      As per title, when battery is connected or jack connected: keyboard light flashes once but cannot turn laptop on. Holding power button for 10 seconds then the KB backlight will flash again. Unknown history and signs of previous repair (jump wire from CMOS battery holder positive terminal to R2453, presume broken trace under it)
      Thermal camera at board, 3 points warming up (not hot, just warm). CPU, BQ chip and ethernet controller. I guess this is OK??
      - Ethernet chip I guess is powered for wake on lan functionality?
      - BQ chip is driving input mosfets
      - CPU warming...
      12-09-2024, 05:05 PM
    • pc_okay
      Overheat +3VA_DSW / +5VSUS [System Power] ON GL504GS 2.1
      by pc_okay
      I have a messed up motherboard asus GL504GS 2.1.
      Someone break pin of fan connector and 12V pin touch FAN1_PWM pin, and of course turn off pc..
      Now pins are repaired but, still, the 3v/5v chip overheat, and FAN1_PWM is 12 ohm to ground.
      FAN1_PWM is directly connected to IT8225VG-128.... There is just a condo on the way and it's okay.
      So my deduction is IT8225VG-128 is dead and pull to much voltage from 3V linear of 3v/5v chip. (i already change 3v/5v chip for fun, and same problem of course...)
      Can you confirm my guess?...
      07-25-2024, 08:08 AM
