820-01987 image bat no backlight
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    i have 0v on l8410
    PPVIN_S0SW_LCDBKLT 0v
    PPVIN_S0SW_LCDBKLT_R 12v
    LCDBKLT_EN_L 12v
    already replaced q8400 but nothing changed
  • mon2
    • 14677
    Re: 820-01987 image bat no backlight
    Voltage on BKLT_EN_R ?
    Remove all power / no battery.
    Meter in resistance mode.
    Check the resistance to ground of PPVOUT_S0_LCDBKLT.
    Post the resistance and meter scale used for the measurement.
    • lordgeny
      • Apr 2016
      • 223
      • Italia
      fixed missing PP5V_G3S ,
      found l8504 blowed replaced and jumper fired trace
      • mon2
        • 14677
        So now it is working ?
        • lordgeny
          • Apr 2016
          • 223
          • Italia
          yes work
          • Salem Aboshala
            820-00138-A got image but no backlight
            by Salem Aboshala
            Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
            I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
            History: my laptop backlight stopped working without any reason.
            Symptoms:
            I have image on screen using my flashlight.
            I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
            Keyboard backlight still working and can be adjusted normally.
            Since two days I tried to follow all similar...
            06-11-2024, 03:02 PM
          • zaurus81
            Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
            by zaurus81
            This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
            The board is equipped...
            01-16-2025, 03:54 AM
          • Constantinos
            Macbook Pro A2442 820-02098 No image but has backlight
            by Constantinos
            Hi all
            I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
            He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
            Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
            Obviously, he decided against this and gave it to me so that I could have a crack at it.
            From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
            08-24-2024, 09:48 AM
          • ajgae
            HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
            by ajgae
            Hi everyone!
            First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
            03-06-2025, 09:53 AM
          • learnmore
            Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
            by learnmore
            Hello Community!
            CASE DETAILS
            Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
            13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
            Tried inserting firmware on USB and left it in for a few hours, but no change
            03-03-2024, 09:49 AM
