can I change bq24725A vs BQ24735
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    My mb is a X202E REV 2.0 Charger ic is bq24725A
    My available ic is just the BQ24735 can I chang those IC?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: can I change bq24725A vs BQ24735
    On some boards it works but not on all boards. However, no harm in trying-it wont do any damage. I'm not sure about Asus X202E.
    • Verlengsnoer
      Bios splash/logo change
      by Verlengsnoer
      at firs, i hope this is the right place to post my question.
      Im looking for a tool to change the bios logo.
      everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
      i know that HP has a build in option to change the splash logo.
      but i want to change the manufacturer logo to an own logo.
      I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
      10-28-2022, 09:52 AM
    • Jane
      BQ24735 - faulty?
      by Jane
      Can you please give your opinion on this matter?
      Laptop does not work. I checked voltages of charging circuit BQ24735 .
      Values are :
      pin 20: VCC 19V
      pin 6: ACDET > 2.4V
      pin 16: REGN 6V
      pin 5: ACOK 2.62V
      Are these values correct and (if BQ24735 is working in the correct way)
      ACDRV (pin 4) should have more than 19V?
      Or I must check any other values to be sure to decide that BQ24735 is faulty?
      AS I have ACDRV about zero, so I guess BQ24735...
      10-21-2022, 11:45 AM
    • rustinjust
      Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
      by rustinjust
      My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
      The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
      It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
      I have to turn the tv off and then on again with...
      09-28-2023, 12:23 PM
    • TuanTongbadcaps
      Change CPU multiplier through BIOS editing
      by TuanTongbadcaps
      Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would...
      07-22-2024, 07:57 PM
    • ktmmotocross
      Apple A1990 and A1707 after battery change low speed
      by ktmmotocross
      Hello. H
      Have this apple A1990 and A1707 that goe slow after battery change. with old battery back it is normal. So battery is problem as it is aftermarket. what battery vendor except original can u recommend. so it work as it should...
      08-27-2025, 10:19 AM
