MSI GT60, GTX880M at fault ?
  • Jay1st
    • Jun 2022
    • 7
    • La Réunion
    Hello all,
    I'm looking for some ideas on how to fix my laptop's graphic card.
    It's an MSI GT60 Dominator, got it new in 2014 (or 15), served me well for gaming, and 3 years ago it went bezerk.
    Here are the symptoms:
    _cooling fan full speed
    _orange led on ( it's white when the I7 integrated gpu is on)
    _had a hard time having it detected by Win8.1 ( after it failed i installed linux and used it with LinuxCNC for a cnc plasma cutter)
    _re-installed Win8.1 (original disk came with the laptop)
    _Nvidia GTX880M shows as "basic video card" and of course ERROR 43
    trouble shooting phase:
    _GPU-Z > card shows up, but no details except basic things, and no BIOS version either
    _modded Nvidia Inf file to have it recognise my card and isntalled the drivers
    __BIOS update, failed with message " GPU not found"
    So i guess there is a hardware problem, i might take the card out (MXM connector) and try looking for anything unusual (VRMs for GDDR GPU.
    Has anyone encountered the same problem or has experience with MXM cards ?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3588
    • slovakia
    Re: MSI GT60, GTX880M at fault ?
    test rams for errors with mats
    • Jay1st
      • Jun 2022
      • 7
      • La Réunion
      I guessed i'd have that answer
      Trying to donwload it right now
      And in the mean time i've found some info on the MXM 3.0 and the 16f41 mobo
      • Jay1st
        • Jun 2022
        • 7
        • La Réunion
        Ok, so i managed to find ver 367.381 but my card is not recognised......maybe need ver 400.184 or it's only detecting the integrated gpu instead of the GTX880M.
        • Rictech
          Panasonic SA-MAX770PU SMPSU board fault....
          by Rictech
          Hello everyone. 😀
          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
          There are no devices that have exploded or otherwise show signs...
          08-26-2024, 01:05 AM
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
          ESR meter came to the rescue again today with a PLC I/O card fault
          I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
          I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
          One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
          12-18-2023, 08:17 PM
        • cazi1001
          Strange fault on Lenovo ThinkPad E14 Gen. 2
          by cazi1001
          I have a strange fault with a Lenovo ThinkPad E14 G2 (Board No. NM-D011 Rev. 1.0).
          The first Problem, which I fixed already, was a dead TPS65944AD (USB Type-C) controller. After I fixed this fault, all functions working fine and the notebook run very well with the charger and battery.
          On the next day, I tied to start the notebook with the battery, but nothing happened. I started with the charger and on windows, I saw, that the battery was empty. And this was nearly impossible, because the battery was charged. I disconnected the battery and found out, that the board...
          03-24-2024, 04:16 AM
        • PanicMechanic
          Extech EX330 multimeter current range offset fault
          by PanicMechanic
          My multimeter has developed this fault, a few months ago. I tried to fix it, but had no success.
          The fault is that on the current ranges it never shows 0. Does not matter if the probes are open or shorted.
          As you can see from the pics, the offser is the same (just multiplied for other rages):
          -4.9 uA
          -0.49 mA
          -0.49 A
          I don't know what exactlly caused the fault.
          The meter had a battery leak before I noticed the fault, but I am not sure if the fault was present before that happened. I just did not noticed. The battery leaked...
          05-11-2021, 11:13 PM
