LA-H901P +3VALW low resistance what would be the possible damge
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    I tried to Trace the +3VALW all remove the jumper connections that flows the +3VALW line but same got 70 ohms I already remocve the PJ401 from the PL402 coil. Hope some can guide me what to check next.. home my cpu is not dead or pch maybe?
    Last edited by SMDFlea; 05-01-2023, 06:21 AM. Reason: Added "LA-H901P" to thread title...
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Re: +3VALW low resistance what would be the possible damge
    schematic
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      also my uc7 bios chip pin 8 has 33 ohms?
        • 20923
        come on man,do we have to guess what the motherboard model number is
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          sorry its a FH50P LA-H901P REV 1A
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3593
            • slovakia
            u dont need to rar pdf
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              sorry
              • albin16d
                Albin
                • Feb 2021
                • Bolivia
                kalilinux25, It may be a possibility that the CPU is damaged because the +3VALW line enters the CPU and the bios is fed with 1.8v, possibly you also have a short circuit in the 1.8v line.
                you separated the line +3VALW from +3VALW. can you measure with respect to mass the +3VALWP line, what value does your multimeter mark in diode mode?
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  diode mode 0
                  Thanks for the help the pch is already dead confirm after removing the pch chip all shorts gone,
                  Ive learned that if you test the pin8 of the Bio chip it can be easly conclude that shorted pch , great experience.
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3593
                    • slovakia
                    no need to remoeve chip. inject voltage and u will see hotspot on side of pch/pour IPA on it/
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      diode mode 0
                      Very old facts and its known to almost every technician.
                      • cind12
                        GTX 1080 TI Gigabyte Aorus low resistance on vmem
                        by cind12
                        Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                        Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                        The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                        Resistance on 12V 4K ohms (Power present when on)
                        Resistance on 12V PEX 4K ohms...
                        12-08-2023, 09:09 AM
                      • Nagy Daniel
                        Lowest possible resistance on laptop motherboard rail - Guide Table request
                        by Nagy Daniel
                        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                        So, I generated a table with AI so I can...
                        03-04-2025, 08:24 AM
                      • nawsn
                        Dell 3537 LA-9981P No Display
                        by nawsn
                        Hello everyone, i have this old laptop and wanted to repair it, when i press the power button, here are some measures i took below, Hope someone can help me, thanks.
                        B+ - 13.6v (Don't know if its good)
                        3.3valw - ok
                        5valw - ok
                        EC_RSMRST# - ok (3.3v)
                        PBTN_OUT# - ok (3.3v)
                        SIO_SLP_S0# - ok (3.3v)
                        CPU_DETECT# - ok (0V)
                        LID_SW# - ok (3.3v)
                        ON/OFFBTN# - ok (3.3v)
                        EC_ON - ok (3.3v)
                        ACIN - ok (3.6v)
                        65W/90W# - ok (3.3v)
                        PCH_PWR_EN - ok (3.3v)
                        ACIN_65W - ok (3.3v)
                        SIO_SLP_S3#,...
                        10-20-2024, 04:20 AM
                      • Jane
                        What is the lowest acceptable resistance on a coil without considering a short on PCB
                        by Jane
                        I have Asus FA506 ( board DA0BKXMB8D0 Rev: D). Can you please roughly indicate what the lowest resistance I should measure on a coil? I know that a low resistance is allowed on coils in CPU or graphic circuits but can you provide acceptable values of resistance?
                        Thank you.
                        02-27-2024, 01:42 PM
                      • loopster
                        645 G9 with Ryzen 5 PRO 5675U | Resistance to ground of CPU?
                        by loopster
                        Hello everyone, I have a 645 G9 here with a Ryzen 5 PRO 5675U.
                        This board has a blown inductor component above the driver chip to the CPU coil, and I am wondering whether the CPU is shorted/dead.
                        Could anyone please measure the resistance to ground on the leftmost coil/inductor to the CPU?
                        My resistance value is 2.2 Ohms, which doesn't look good to me.
                        Thanks to everyone willing to give a value.​
                        06-05-2025, 02:33 PM
