Dell Alienware 17 R4 BAP10 LA-D751P, cpu b+ shorted?
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    is it normal t have 1 ohms resistance to the CPU B+?
    MOD Edit ,link to schematic https://www.badcaps.net/forum/showthread.php?t=74069
    BAP10 LA-D751P REV 1.0
    Last edited by SMDFlea; 10-02-2023, 02:03 AM. Reason: Added "Dell Alienware 17 R4 BAP10 LA-D751P" to thread title
  • mon2
    • Dec 2019
    • 14243
    Re: cpu b+ shorted?
    Yes, it is possible.
    See section 2.2 :
    https://www.logi.wiki/index.php/Begi...with_no_reason
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      Re: cpu b+ shorted?
      See section 2.2 :
      thanks I though my cpu is dead
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        Re: cpu b+ shorted?
        why when I attached the PL500 a cpu b+ line I got shortedd at my PR702 a 19v line.. When I remove the PL500 shorted 19v line missing .?? those it mean my short comes from the cpu b+ line?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3597
          • slovakia
          Re: Dell Alienware 17 R4 BAP10 LA-D751P, cpu b+ shorted?
          why dont u inject? with 10A 1V u see hotspot on CPU if it is dead. or u find bad capacitor. but i have two of them with bad cpu
          • piernov
            • Jan 2016
            • 4435
            • France
            No you don't inject voltage, you check for a shorted high-side MOSFET…
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              I'm trying to remove all the ic that related to the cpu b+ line but the problem even a 500c heat I cant remove the ic , what a amzing board
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Use a knife tip on your soldering iron and put some solder on all pins of mosfets first and then try removing it with a lot of good bga quality flux applied.
                  • mon2
                    • Dec 2019
                    • 14243
                    Multilayer pcbs like this one will have lots of heavy copper. This will make parts removal and soldering difficult. Do consider to buy an underside preheater to help. We recently bought the Hakko preheater unit but many on the market and clones on AliExpress.
                    • dellxps15
                      • Feb 2014
                      • 1588
                      • italy
                      check all mosfet on cpu side by probing in diode mode drain-source and drain-gate and source-gate values. generally a shorted mosfet give low resistance on source-gate.
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        I tried my hotair staion is jsut a yihua 858d
                        • kalilinux25
                          • Mar 2018
                          • 2089
                          • ZAMBOANGA SIBUGAY
                          thanks for the good advice
                          • gtech83
                            • 4
                            Anyone have info on PL500 Ferrite Bead Value Part info?
                            • gtech83
                              • 4
                              Found it
                              • Drassh
                                • Apr 2017
                                • 43
                                • Mexico
                                Found it
                                Thanks for sharing.
                                • reessi
                                  Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                  by reessi
                                  Hello:
                                  I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                  I started on the ACER:
                                  Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                  All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                  I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                  10-29-2024, 11:31 AM
                                • Bowline
                                  by Bowline
                                  06-11-2025, 10:13 AM
                                • guizmo1967
                                  Dell Latitude 5501 LA-H181P shorted power rail
                                  by guizmo1967
                                  This is my problem:
                                  Laptop: Dell Latitude 5501
                                  Motherboard: EDC51 LA-H181P
                                  I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
                                  I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
                                  I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
                                  I injected +1.05V - 2A...
                                  07-25-2023, 06:56 PM
                                • TevasLT
                                  Dell G3 3779 CPU and GPU vcore shorted
                                  by TevasLT
                                  I have water damaged Dell G3 3779.
                                  Things I did. During visual inspection i noticed PL911 filter was blown up and caps around it PC901, PC902 .. all up to PU901 shorted, found culprit shorted cap on top side of board PC905, removed cap and short up to PU901 is gone. Shorted PJP901 to bypass filter for the moment.
                                  problem is CPU and GPU vcore coils are all shorted aswell and I don't know where can I safely inject power to test which component or driver is bad.
                                  PLA01 20.8 Ohm PLI01 3.8 Ohm, PLI02 3.8 Ohm, PLI03 3.8 Ohm, PLI04 3.8 Ohm...
                                  11-10-2022, 06:55 AM
                                • Omar Villalba
                                  Dell Alienware M16 R1 AMD (Infinity A+N MB1 213199-1 Y5J11$CA) schematic
                                  by Omar Villalba
                                  Good morning, colleagues.
                                  I'm looking for the schematic or boardview for a Dell Alienware M16 R1 AMD (Infinity A+N MB1 213199-1 Y5J11$CA).
                                  I would really appreciate it if someone could share it.
                                  My main issue is that the backlight is not working. I found fuse F5503 to be blown; I replaced it, but it blows again (goes into protection).
                                  It's worth noting that there's no short on the fuse line, so any guidance or similar experience would be greatly appreciated.
                                  Today, 09:21 AM
