Dell Alienware 17 R4 BAP10 LA-D751P, cpu b+ shorted?
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    is it normal t have 1 ohms resistance to the CPU B+?
    MOD Edit ,link to schematic https://www.badcaps.net/forum/showthread.php?t=74069
    BAP10 LA-D751P REV 1.0
    Last edited by SMDFlea; 10-02-2023, 02:03 AM. Reason: Added "Dell Alienware 17 R4 BAP10 LA-D751P" to thread title
  • mon2
    • 14662
    Re: cpu b+ shorted?
    Yes, it is possible.
    See section 2.2 :
    https://www.logi.wiki/index.php/Begi...with_no_reason
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      Re: cpu b+ shorted?
      See section 2.2 :
      thanks I though my cpu is dead
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        Re: cpu b+ shorted?
        why when I attached the PL500 a cpu b+ line I got shortedd at my PR702 a 19v line.. When I remove the PL500 shorted 19v line missing .?? those it mean my short comes from the cpu b+ line?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          Re: Dell Alienware 17 R4 BAP10 LA-D751P, cpu b+ shorted?
          why dont u inject? with 10A 1V u see hotspot on CPU if it is dead. or u find bad capacitor. but i have two of them with bad cpu
          • piernov
            • Jan 2016
            • 4439
            • France
            No you don't inject voltage, you check for a shorted high-side MOSFET…
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              I'm trying to remove all the ic that related to the cpu b+ line but the problem even a 500c heat I cant remove the ic , what a amzing board
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Use a knife tip on your soldering iron and put some solder on all pins of mosfets first and then try removing it with a lot of good bga quality flux applied.
                  • mon2
                    • 14662
                    Multilayer pcbs like this one will have lots of heavy copper. This will make parts removal and soldering difficult. Do consider to buy an underside preheater to help. We recently bought the Hakko preheater unit but many on the market and clones on AliExpress.
                    • dellxps15
                      • Feb 2014
                      • 1598
                      • italy
                      check all mosfet on cpu side by probing in diode mode drain-source and drain-gate and source-gate values. generally a shorted mosfet give low resistance on source-gate.
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        I tried my hotair staion is jsut a yihua 858d
                        • kalilinux25
                          • Mar 2018
                          • 2089
                          • ZAMBOANGA SIBUGAY
                          thanks for the good advice
                          • gtech83
                            • Dec 2010
                            Anyone have info on PL500 Ferrite Bead Value Part info?
                            • gtech83
                              • Dec 2010
                              Found it
                              • Drassh
                                • Apr 2017
                                • 43
                                • Mexico
                                Found it
                                Thanks for sharing.
