Help I want to ask about HP 840 G1 6050A2560201 MB A03 laptop components
  • uch
    Newbie
    • Aug 2017
    • 5
    • Indonesia
    I have a motherboard 6050A2560201 MB A03 which is missing one component, which is as shown in the picture below
    then I tried to look for references on the internet and got some information, that apparently the missing component is as shown in the image below
    and the information I got from the schematic is that the missing component is a resistor as shown in the picture below
    but this information is still not enough for me, please help to determine what components are missing and what are the specs like? how many ohms? what type? I'm looking for a replacement
    Thank you for the help
  • uch
    Newbie
    • Aug 2017
    • 5
    • Indonesia
    Re: Help I want to ask about HP 840 G1 6050A2560201 MB A03 laptop components
    please help me
    • mon2
      • Dec 2019
      • 14672
      Hi. It should be fine to just short the location with a solder blob.
      From my understanding you have 2 rails that can power the VCCIO.
      One rail will be active when the logic board is awake = main power rail.
      If the logic board is in sleep mode, the main power rail will disable and the always on, lower current rail will be switched to power the VCCIO pins.
      The VCCIO pins need to be present to perhaps power devices like a mouse -> when the mouse is moved, the logic board can then wake up again.
      • uch
        Newbie
        • Aug 2017
        • 5
        • Indonesia
        ok, i will try to connect it now
        • uch
          Newbie
          • Aug 2017
          • 5
          • Indonesia
          thanks a lot bro, you saved my life, your advice really works
          • Yolofolkss
            Huawei D14 dah98ambad0 rev d please help identify Missing components
            by Yolofolkss
            Hello I just bought this laptop to be used personally (that I'm currently trying to repair.), I am aware that liquid (gravy) has been spilled in this area before. but there are missing components it it possible to have a board view or a schematic of this? or just an idea on what components its missing?
            as far as I know this parts are connected as sense or enable.... that's how far I know...
            Images attached:
            the picture of the area. and some of the pinouts that I noticed on the chip...
            03-26-2023, 12:37 AM
          • Artakozu
            Xfx RX470 - Missing components
            by Artakozu
            Hi, I'm new to this forum.
            I recently bought a damaged XFX RX470 for around $10-12 USD. As you can probably see, I believe the only issue is some missing components, likely due to a scratch or a fall.
            Can anyone help me confirm which components are missing, and specifically, tell me the value of capacitor C502?...
            05-20-2025, 06:26 PM
          • summerwhite
            DJI Mini Pro 3 missing components near camera connector
            by summerwhite
            I have a DJI drone that is not displaying a video feed anymore after a repair.
            When tearing down the DJI drone to fix the armature there was some hot glue next to the camera connector that i had to remove.
            Now there are missing components either because they got pulled off or because they where never placed.
            I have two reference images from XXZ and a photo of mine.
            I'm truely hoping someone has another DJI Mini Pro 3 that they can help me identify what these components are and if they are necessary.
            On the board view from XXZ they...
            04-06-2025, 11:15 PM
          • grimacelord
            HP 15-cs3055wm - DAG7BLMB8DQ REV:D - Missing Components - Fan Error
            by grimacelord
            I have an HP laptop here (model and board model in title) that powers on with an error message about the fan not working properly and needs to shutdown. The thing is, the fan is spinning just fine. I disregarded the message and continued to boot into Windows and loaded up OCCT to look at temperatures and the OCCT was reporting that the CPU was very hot (98C) and climbing, so I shutdown the computer, did a CMOS reset and checked then thermal paste and heatsink for dust build-up. Paste looked good, but I cleaned it off and applied fresh paste anyway and blew out the fan from...
            03-15-2024, 01:29 PM
          • Ryan Wurtz
            DAOPDIMB8GO Rev .G not charging, missing components identification
            by Ryan Wurtz
            Missing components on the motherboard.
            Anybody by chance have the same model and can let me know what they are?
            Symptoms of the laptop are. Working, booting, seems fine except does not charge. Windows even says it's charging. But does not. Also charging light is on. So I'm guessing Im missing some Resistors
            Can manually charge the battery.
            Let me know if you need more pictures or have any questions....
            09-02-2025, 07:40 PM
