Help with Dell board LA-9872P blinking not charging and power off removing AC adapter
  • ex250
    • Jun 2019
    • 97
    • Spain
    Hi guys,
    I'm having now a final issue,
    The laptop can starts on battery or with AC, the both are properly detected, AC 240w and the battery health excellent.
    I can run starting on Battery, normal drain and use, plugged the AC, laptop continues working but not charges it, and if you remove the AC laptop shuts down like battery was not present.
    Also noted, with the battery attached, the battery light blinks each 2 seconds, like trying to charge, every time the battery light goes of, at bios the AC adaptor changes 1 second to 210w adapter and 240w again. Tested with other 240w AC charger and same.
    HWinfo reports a charge current of only 11mw, clearly insufficient
    Without the battery, with the laptop plugged, the battery light blinks 1 white 4 orange, cicling 3 times or 4 and after that orange blinking continously like a problem in the charge circuit.
    Any one could point any clue about what to check?
  • ex250
    • Jun 2019
    • 97
    • Spain
    Re: Help with Dell board LA-9872P blinking not charging and power off removing AC ada
    Just one fast update, just mounted on a dell docking station, and here works as expected... battery charges and not shut off without AC, also HWinfo charge ratio 21701mw
    • mon2
      • Dec 2019
      • 14101
      See attached.
      Review the voltage on each of these pins of PD701 when:
      1) powered through the external power adapter only
      2) powered by the docking station only
      • ex250
        • Jun 2019
        • 97
        • Spain
        Hello these are:
        PD701
        Pin 3 power External 19.48v P2 0,09v P1 19,19v
        Pin 2 power Dock 19,48v P3 0,05v P1 19,20v
        Seems that both lines are ok, not?
        • mon2
          • Dec 2019
          • 14101
          Ok. Review page 62 of your posted schematic.
          There are 4 mosfets in the top left side of this page.
          With the dock station, the power rail to the logic board bypasses this group of 4 mosfets.
          Remove all power. No battery. Meter in resistance mode (2k is ok).
          Check the resistance of each mosfet of these 4 :
          Source (1-2-3) and drain (5-6-7-8)
          Source (1-2-3) and gate(4)
          Gate (4) and drain (5-6-7-8)
          Post each measurement and the meter scale used. Checking for a low resistance = defective mosfet. If you see '1' and 'OL' then switch to the next higher resistance scale on the meter to measure it.
          • ex250
            • Jun 2019
            • 97
            • Spain
            Pq1002
            s->d 3,45M
            s->g 4,97M
            g->d 14,06M
            pq1005
            s->d 3,61M
            s->g 361,1K
            g->d 4,09M
            PQ1008
            S->D 3,16M
            S->G 199K
            G->D 3,36M
            PQ1009
            S->D 3,16M
            S->G 199K
            G->D3,30M
            • mon2
              • Dec 2019
              • 14101
              pq1005
              s->d 3,61M
              s->g 361,1K
              g->d 4,09M
              PQ1008
              S->D 3,16M
              S->G 199K
              G->D 3,36M
              PQ1009
              S->D 3,16M
              S->G 199K
              G->D3,30M
              Remove the mosfet off the board and check again the above measurements while the part is removed out of circuit.
              I would replace each of the above mosfets. These readings are considered to be low in the mosfet world. They should be inexpensive on Aliexpress. If in a rush, we can try to locate replacements from other vendors and perhaps source from TI / Mouser / Digikey. Post back. Or you can take from donor boards.
              Do continue to review the other mosfets on the same schematic page and post their readings. Just in case they need to be replaced.
              • ex250
                • Jun 2019
                • 97
                • Spain
                Will remove and report readings, PQ1002 not needed?
                • mon2
                  • Dec 2019
                  • 14101
                  PQ1002 has high readings so should be ok.
                  Once you order from Aliexpress - consider to also buy this part as a replacement - just in case but looks ok to me.
                  • ex250
                    • Jun 2019
                    • 97
                    • Spain
                    Removed the mosfets, I had one spare to compare diode readings of the PQ1008 and PQ1009, are pretty closer to the new one, and also the activation on gate works as expected, PQ1005 has similar readings and also the activation on gate works giving continuity
                    Readings are (S->D) on PQ1008 and PQ1009 (MDU3603)-> 0,539 0,537 and 0,525 in the new one.
                    On the PQ1005 (a 4435 one) -> 0,549
                    Also the value on PQ1005 s->g 361,1K is the same now on the board with them removed, also in the others, same values.
                    • ex250
                      • Jun 2019
                      • 97
                      • Spain
                      Also an update to this, many tanks Mon for your invaluable help, changed PQ1005 and PQ1002, now working.
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • danielsak
                        Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                        by danielsak
                        Hello, I have issue with Dell Inspiron 3542.
                        Motherboard marking:
                        Code:
                        PWB FX3MC REV: A00
                        The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                        1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                        1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                        10-11-2024, 04:36 PM
                      • ipatch
                        dell inspiron 5567 laptop battery lipo WDX0R
                        by ipatch
                        recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
                        1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
                        2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
                        got the computer...
                        04-02-2023, 04:45 PM
                      • tomodachi
                        Dell Precision 5510 " Not a Dell Battery"
                        by tomodachi
                        Hi
                        Dell Precision 5510
                        Mobo code : LA-C361P
                        This one came in for battery replacement but without original battery, so original battery and charging history is unknown.
                        The customer said he bought the computer several years ago second-hand and was told that there was no battery inside but that he could purchase one if he wanted.
                        So we ordered a geniune battery for customer, plugged it in
                        RTC battery was also dead and it was also replaced. First boot up brought up warning message;
                        Funny thing is Service Tag is already set.
                        And...
                        11-07-2024, 06:08 AM
                      • lawrenceptrini
                        Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
                        by lawrenceptrini
                        Hi Guys,
                        I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
                        The laptop is working fine with the adapter plugged in and also with a charged battery.
                        Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
                        ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
                        loses its charge, it stays on 0%.
                        Measurements taken
                        Charging IC (ISL95522HRZ) 32 pins
                        Voltage to ground with ac adapter only plugged in:
                        1)...
                        08-26-2024, 06:45 PM
