Hi all. I hope someone has come across something similar, as I am baffled.
I have a faulty logic board from a 2015 A1502 Macbook Pro Retina (820-4924-A). Some signs of liquid, but all corrosion cleaned, and several components refloated or replaced to eliminate any visually corroded areas of the board.
Machine boots fine now, but the keyboard and trackpad do not work at all when booting normally into Catalina, Big Sur, or Monterey. At the login screen, the cursor does not move at all when moving on the trackpad, and no keys on the keyboard respond on screen, however the machine does make a sound when any key is pressed (The sound is the keyboard buffer full sound).
Plugging in an external keyboard and/or mouse also does not work. Neither respond (except for the keyboard buffer full sound which is also present with an external keyboard).
The strange part is that booting into safe mode and recovery mode, both the keyboard and mouse function 100% normally without issue. Machine is stable and screen behaves normally in recovery mode and safe mode.
Another issue which may or may not be related, the screen slowly fades to black when not in recovery or safe mode. What I mean is it's like the brightness is reducing just like when the screen dims due to inactivity but seems to happen slower than normal screen brightness reduction due to inactivity, but not 100% sure this isn't just normal behaviour. At one point the screen also showed a white fading border, but that seems to only have been seen a couple of times.
I have swapped the logic board into a known working chassis (thus a different trackpad/keyboard ribbon cable, trackpad, keyboard, power board, and screen, etc.), and had the exact same issue, so problem follows the logic board.
I have done fresh installs of Catalina, Big Sur and Monterey, on different drives and same result. KB and trackpad work fine in recovery mode until first boot into the new OS, then neither respond again (and external kb and mouse do not respond).
My initial gut feeling was a bad hall sensor, but it does not fit with the symptoms completely as external keyboard and mouse also do not work when booting normally.
I have checked both logi.wiki, and repair.wiki, and the only things they recommend are changing the trackpad ribbon cable, and a potential issue with the hall sensor, so no help there.
Has anyone ever had a similar issue, or any ideas as to what I can try changing to fix this?
Any help or thoughts appreciated. Cheers.
 I've seen what this community can do, so I'm pretty sure you guys can help me out.
