820-00426 (A1398 2015) no trackpad, no keyboard.
  • nicocorradini
    • Nov 2020
    • 12
    • Argentina
    Hi! I have this 2015 A1398 with 820-00426 board that's driving me crazy. It originally came because of charging problems (MagSafe Board roasted, also MagSafe cable, etc. After disassembly, clean and assembly, my assistant (literally) broke FL803 and other componentes. Obviously, no screen or backlight. After replacing them, and also the LVDS connector, and LVDS flex on the screen, the board started fine, charges, chimes, shows Apple Logo, but surprise: no more trackpad or keyboard.
    Important notes:
    -Click works, so, trackpad is alive.
    -Already tried with another trackpad, another flex and another keyboard. Same result.
    -Power button works just fine, even SMC Reset works.
    -Them doesn't work in bootpicker menu, can't reset PRAM, open boot selector, etc.
    -No corrosion, broken traces, etc in trackpad / keyboard related areas, everything is clean.
    Really don't know what to do next. And client is really angry... Any ideas? Thank you in advance!
  • mon2
    • 14685
    Trackpad is linked to connector @ J4801. Review each pin.
    Review the power fuse @ F4809 which appears to be ok if the trackpad is clicking. Confirm it. Measure the voltage to ground on each side of the fuse.
    Inductor @ L4803 is not burnt? Confirm it with meter testing on each leg.
    Confirm the proper seating of the flex cables for the keyboard into connector J4813.
    Maybe this video will help:
    https://www.youtube.com/watch?v=uyprAACDlyI
    • iMuhtaseb
      A2681 Keyboard, trackpad and sleep?!
      by iMuhtaseb
      Wow it's been a while since I posted!
      This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
      A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
      It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
      Tested another locked logic board on customer's top case and it posted with keyboard and...
      05-22-2025, 09:59 AM
    • guzq
      MBA13 M3 2024 A3113 EMC8611 820-03285 No Trackpad No Keyboard (water damaged)
      by guzq
      Hi Guys,
      This Mac come with dead issues (severe water damage), now it’s turning ON except Trackpad and Keyboard not working.
      Already check and write down DM for JT400 and JT201 don’t find any abnormal value (I don’t have unit for compare).
      Already try,
      • Replacing Trackpad Flex Cable
      • Replacing New Trackpad
      • Replacing Little Board (Daughter Board)
      • Try using New Keyboard
      Still no change at all, Trackpad and Keyboard not working.
      So I check “Power Load Switches” and this is all the numbers,
      UC830 > 1 = 3.297V ; 3 =1.757V ; 4 = 3.798V...
      07-08-2025, 05:19 AM
    • Vliegenier04
      Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
      by Vliegenier04
      Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
      I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
      Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
      06-16-2025, 12:03 PM
    • playit
      ps/2 port keyboard dead ? p5ql pro / ethernet cable light
      by playit
      my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
      my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
      few years back ps2 mouse stopped working, but ps2...
      12-23-2024, 06:05 AM
    • mitchw
      MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
      by mitchw
      Hello
      I got this MacBook Pro M4 Pro to have a look at.
      It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
      Since it was liquid damaged, warranty does not apply anymore.
      Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
      The main issue was that the screen remained black.
      Anyways I cleaned the liquid damaged area, put the machine back...
      09-06-2025, 07:19 AM
