A1466 820-3437-B 10 second fan off on
  • test_guy2010
    • Jul 2018
    • 3
    Hello, I have a MacBook board that I am stuck on.
    This is a 820-3437-B board which I know the standard turn on procedure is 3 fan spins before powering up and staying on, however this board the fan turns on for about 10 seconds, turns off, then turns on and stays on until powered off.
    This board did appear to have some liquid near U1900 (clock chip) which I have replaced as well as the crystal just to make sure.
    I get all voltage rails, vCore stable at about 1.7v, very little heat coming from the CPU/PCH (mostly PCH), with a USB with a bootable system the light flashes indicating the PCH should be working.
    However it is failing to boot through as well as the strange starting behaviour.
    Odd things I have found are U3900 (camera processor) was heating up quite a bit so was taken off the board, should be able to boot without it, just missing camera functions, signal PCH_INTVRMEN is 2.6v and PCH_INTRUDER_L is 1.6v.
    I am unsure where to go from here so asking for advice, thanks.
  • reformatt
    • Feb 2020
    • 1412
    Re: A1466 820-3437-B 10 second fan off on
    Check U8005 for corrosion (can be hard to spot). Seen something similar...was corrosion under pin 1.
    If that fails, flash a known working clean ME BIOS to U6100 and check all termination resistors. Are you getting a chime/display etc?
    • test_guy2010
      • Jul 2018
      • 3
      No good, nothing around U8005 took it off and checked.
      Flashed a clean BIOS to the chip, resistors are fine.
      No display or chime, just the 10 second fan spin, off then back on and stays spinning.
      For now this will have to be a fail as it's been a time sink for me.
      • reformatt
        • Feb 2020
        • 1412
        Pull off the edge bonding and reflow the SMC with plenty of flux. Usually crap underneath it with weird behaviour. Also check PCH resistance to ground for PP1V05 rail. Under 100 ohm is usually damaged PCH from messed up converter feedback.
        • Instafixx
          • Jul 2022
          • 374
          • India
          Hi, i have the exact same issue. Wonder if this was solved. In my case if we probe the SMC_RESET_L anyhwhere on the board, the Fan Spin stops.
          U8005 Pin #1 shows 5V.
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
