A1466 820-3437-B 10 second fan off on
  • test_guy2010
    • Jul 2018
    Hello, I have a MacBook board that I am stuck on.
    This is a 820-3437-B board which I know the standard turn on procedure is 3 fan spins before powering up and staying on, however this board the fan turns on for about 10 seconds, turns off, then turns on and stays on until powered off.
    This board did appear to have some liquid near U1900 (clock chip) which I have replaced as well as the crystal just to make sure.
    I get all voltage rails, vCore stable at about 1.7v, very little heat coming from the CPU/PCH (mostly PCH), with a USB with a bootable system the light flashes indicating the PCH should be working.
    However it is failing to boot through as well as the strange starting behaviour.
    Odd things I have found are U3900 (camera processor) was heating up quite a bit so was taken off the board, should be able to boot without it, just missing camera functions, signal PCH_INTVRMEN is 2.6v and PCH_INTRUDER_L is 1.6v.
    I am unsure where to go from here so asking for advice, thanks.
  • reformatt
    • Feb 2020
    • 1495
    Re: A1466 820-3437-B 10 second fan off on
    Check U8005 for corrosion (can be hard to spot). Seen something similar...was corrosion under pin 1.
    If that fails, flash a known working clean ME BIOS to U6100 and check all termination resistors. Are you getting a chime/display etc?
    • test_guy2010
      • Jul 2018
      No good, nothing around U8005 took it off and checked.
      Flashed a clean BIOS to the chip, resistors are fine.
      No display or chime, just the 10 second fan spin, off then back on and stays spinning.
      For now this will have to be a fail as it's been a time sink for me.
      • reformatt
        • Feb 2020
        • 1495
        Pull off the edge bonding and reflow the SMC with plenty of flux. Usually crap underneath it with weird behaviour. Also check PCH resistance to ground for PP1V05 rail. Under 100 ohm is usually damaged PCH from messed up converter feedback.
        • Instafixx
          • Jul 2022
          • 374
          • India
          Hi, i have the exact same issue. Wonder if this was solved. In my case if we probe the SMC_RESET_L anyhwhere on the board, the Fan Spin stops.
          U8005 Pin #1 shows 5V.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • Soulzink
            Samsug washing machine. Power supply DC41-00189a board issue
            by Soulzink
            I am trying to fix a samsung washinmachine power supply main board.
            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
            The power supply board reference is the following: DC41-00189a
            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
            04-19-2025, 06:26 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
