HP G62 conversion problem
  • Gudguy
    • Jun 2016
    • 48
    • Nigeria
    hello gurus in the community,i need someone to explain what an what do i need to add or remove from the hp g62-a19sa board.i have detected that the ATi chip set fail all the time,all required voltage are present .here attached the schmatic for the board.thanks
  • Gudguy
    • Jun 2016
    • 48
    • Nigeria
    Re: HP G62 conversion problem
    I need someone to guide me about HP g62 conversion
    If you check page 33 where the Kbc ite8582 is. I don't know which resistor to swap or which one to remove. My mentor mcpslig123,lapfix,mons and Co where are you.
    • speggio91
      • Apr 2020
      • 83
      • Italy
      Hello, i've never done a conversion to UMA on this model, but I found in this forum, an old post with a step by step picture guide.
      https://www.badcaps.net/forum/showpo...02&postcount=8
      It seem a pretty tedious job with no warranty that will work for every G62 boards with discrete graphics.
      We can wait for the more expert users to give us their opinion about it, or you can cross check the pictures with the boardview and schematics to see if this job make sense.
      (the boardview can be opened with boardviewer 2 beta)
      By the way, silly question, if the issue is the graphic chip causing crashes or no display, did you already try to reflow it? You could extend its lifespan if done it correctly.
      Good luck!
      • Gudguy
        • Jun 2016
        • 48
        • Nigeria
        @spiggio91 thanks for your contribution,as regard to whether have reflow or not.have done re-flow several time,that why am look for alternative of keep the laptop running again.any contribution and suggestion will be appreciated from the learned member.thanks
        • Gudguy
          • Jun 2016
          • 48
          • Nigeria
          The schematic and post your redirect me to does not match the G62 board am working one.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            As per the schematic attached, SIO is on page22 and its IT8502 and not IT8582. I've attached 2 pics. Atleast one pic should match your mb. Do changes as per the pic which matches ur board. I've not done conversion on this mb ,so cant guarantee about its authenticity. The link given by @speggio91 is for Quanta AX1 and its completely different. However, that guide is tested by me personally to be working.
            • Gudguy
              • Jun 2016
              • 48
              • Nigeria
              sorry for replying you late.thanks so much my mentor.i will give you feed back soonest
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Zeonalbasta
                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                by Zeonalbasta
                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                09-13-2024, 01:17 PM
              • Gibon378
                Problem with stopping audio and video for no reason
                by Gibon378
                PC Specs:
                • CPU: Ryzen 5 1600
                • GPU: GTX 1080 Palit JetStream
                • MOBO: ASRock ab350 PRO4
                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                • PSU: XFX 650W (don't remember what model)
                • OS SSD: ADATA SP920
                • OS: Windows 10 21H2
                Problem description:
                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                11-19-2022, 09:41 AM
              • perzyk23
                Lenovo T580 - LCD Panel problem - error 0288
                by perzyk23
                Good morning,
                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                10-25-2024, 12:42 AM
              • SDNarcia
                Dell 15R-5521 keyboard problem (KBC?)
                by SDNarcia
                Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                As additional information,...
                07-20-2024, 10:47 PM
