Need help with 820-00165
  • mon2
    • Dec 2019
    • 14666
    Re: Need help with 820-00165
    Would you have a 1uf capacitor from a donor board ? Other cap values may also be ok but 1uf appears to be proven to work.
    By applying as shown by @smzlwan223, you will be creating a RC circuit that will trigger off the PP3V3_SUS line.
    • goksi75
      • May 2020
      • 31
      • Srbija
      #42
      I have, I report the results.
      • goksi75
        • May 2020
        • 31
        • Srbija
        #43
        I did as @smzlwan223 said, but the problem remained the same.
        • mon2
          • Dec 2019
          • 14666
          Can you post a clear and zoomed picture of your modification ?
          • goksi75
            • May 2020
            • 31
            • Srbija
            #45
            This is the best I can for now.
            • goksi75
              • May 2020
              • 31
              • Srbija
              #46
              Turning it on in safe mode most normally wakes up from sleep mode, does that mean anything?
              • smzlwan223
                • Mar 2022
                • 20
                • 中国
                #47
                Looking at the picture you sent, I feel that your capacitor seems to be changed to the wrong capacity, remember must be changed into 1UF, so that can play the RT delay circuit.
                • smzlwan223
                  • Mar 2022
                  • 20
                  • 中国
                  #48
                  Or You could try replacing the U8130 IC.
                  • goksi75
                    • May 2020
                    • 31
                    • Srbija
                    #49
                    Ok I report the results.
                    • goksi75
                      • May 2020
                      • 31
                      • Srbija
                      #50
                      Replacing U8130 but the problem remained the same.
                      • goksi75
                        • May 2020
                        • 31
                        • Srbija
                        #51
                        Solved, replaced U6400 and now it works fine, thank you all for your help especially @smzlwan223.
                        • mon2
                          • Dec 2019
                          • 14666
                          There is no U6400 on this logic board.
                          • goksi75
                            • May 2020
                            • 31
                            • Srbija
                            #53
                            My mistake U6100.
                            • smzlwan223
                              • Mar 2022
                              • 20
                              • 中国
                              #54
                              You're too kind! Yesterday through Wechat and Goksi75, after the video to see the fault, it is very easy to find the problem, before the fault description, the maintenance of the problem caused by the wrong direction, in fact, the fault is caused by the internal program Error U6100 Rom. You can use a programmer to brush the factory BIOS ROM file.
