Need help with 820-00165
  • goksi75
    • May 2020
    • 31
    • Srbija
    Hi Guys!
    820-00165 all work fine until i close the screen, when i open it its black screen but the keyboard light and CapsLock on, I have to turn it off and then on again and then it works normally. I noticed that when I press the ignition button, it takes 15-20 seconds. to display the apple logo.
    The problem is wont wake up after sleep.
    Sorry for bad English.
  • reformatt
    • Feb 2020
    • 1400
    Re: Need help with 820-00165
    Check the trackpad and LIO flex cables for corrosion. SMC LID signal goes to both. If the trackpad cable is damaged, can also potentially cause full fan speed/CPU throttling.
    • goksi75
      • May 2020
      • 31
      • Srbija
      I put another checked LIO flex cables, SMC LID is 3,4v, replaced trackpad cable, fan speed is normal. As I said, all work fine, problem is wont wake up after sleep when i open it its black screen.
      • reformatt
        • Feb 2020
        • 1400
        The lid sensor is a hall effect switch in the LIO board, triggered off a magnet in the screen. Have you tried another LIO board, and if so, does SMC_LID toggle on lid open? What other troubleshooting have you done?
        • goksi75
          • May 2020
          • 31
          • Srbija
          I put another LIO board, and behaves the same, SMC_LID is same 3.4v before and after closing the lid.
          • mon2
            • Dec 2019
            • 13907
            Post the voltage readings for:
            SMBUS_SMC_3_SCL
            SMBUS_SMC_3_SDA
            • goksi75
              • May 2020
              • 31
              • Srbija
              Smbus_smc_3_scl 3.3v
              smbus_smc_3_sda 3.3v
              • mon2
                • Dec 2019
                • 13907
                SMBUS lines are ok.
                SMBUS_LID is not working correctly. You should see a different reading when closed than when it is open.
                Suspecting the same as other comments, that the LIO board is not driving this pin so that the SMC @ U5000 can monitor this logic level change and then turn ON / OFF the backlight.
                Can you remove the SSD and see if the logic board powers on every time and shows the display ? You should see the blinking folder graphic.
                When you do NOT see the display working, can you use a flashlight (phone) to view the display graphics ? Try from the BACKSIDE of this LCD display - perhaps the fault is that your backlight is faulty.
                • goksi75
                  • May 2020
                  • 31
                  • Srbija
                  Yes when i move ssd i see the blinking folder, and ever i turn the ssd and raise the OS everything is fine, but when I lower the cover it goes into sleep mode and when I raise the screen the keyboard lights up and the screen is black and when I turn on the light from the phone and put on backside of lcd, nothing is visible even the light from the phone.
                  • mon2
                    • Dec 2019
                    • 13907
                    Try the phone light on the front face - do you see any of the usual graphics / flashing folder icon ?
                    • goksi75
                      • May 2020
                      • 31
                      • Srbija
                      Now a new situation happened to me that he went into sleep mode when I picked up the lcd he didn't even want to turn on.
                      • mon2
                        • Dec 2019
                        • 13907
                        Do you see any fan spin ?
                        If not - remove all power. Remove the LCD. It is not required for this first level testing.
                        Without the LCD, apply the power adapter.
                        Do you see the magsafe LED on ? What color is the LED ?
                        Are you using the official magsafe adapter ?
                        • goksi75
                          • May 2020
                          • 31
                          • Srbija
                          Yes, I see magsafe led first green and then orange and fan is spin.
                          Yes, I using official magsafe 2 45W.
                          • mon2
                            • Dec 2019
                            • 13907
                            Good.
                            Check the contacts on the LCD screen cable -> all clean & shiny ? Ok to use alcohol (IPA) to clean the contacts.
                            Attach the LCD again. Can you see the backlight after the fan spin ?
                            If not, measure the backlight voltage for the LCD.
                            See here for other details on this logic board:
                            https://repair.wiki/w/A1466_2015-201...9D_MacBook_Air
                            • goksi75
                              • May 2020
                              • 31
                              • Srbija
                              Checked contacts on the LCD screen and all is clean.
                              I connected lcd again and have this.
                              But the problem is still present after going into sleep mode it no longer turns on.
                              • mon2
                                • Dec 2019
                                • 13907
                                Good - can see my selfie.
                                Remove all power. Remove the trackpad cable.
                                Power on again with the adapter.
                                See attached (stolen from beetstech website) - use tweezers to turn the logic board on/off across these pads.
                                Does the logic board power on and show the display every time you use the tweezers ? Repeat this testing a few times to confirm.
                                If not..
                                Remove all power. Meter in resistance mode. Confirm the resistance of R5171. Should be ~100k ohms.
                                • goksi75
                                  • May 2020
                                  • 31
                                  • Srbija
                                  I did as you said a couple of times and logic board is power on and show the display every time, R5171 is 100k.
                                  • mon2
                                    • Dec 2019
                                    • 13907
                                    Good.
                                    Remove all power.
                                    Attach the trackpad cable again.
                                    Apply power but use the same on / off PCB pads with tweezers.
                                    Can you turn on the logic board everytime ? Do this multiple times to confirm.
                                    • goksi75
                                      • May 2020
                                      • 31
                                      • Srbija
                                      Attach the trackpad cable and logic board is power on every time with tweezers.
                                      • mon2
                                        • Dec 2019
                                        • 13907
                                        Good. I think your issue is with the keyboard on/off button.
                                        Can you now test with the keyboard on/off button ?
                                        Is this flaky and sometimes fails ?
                                        The keyboard inside this unit is a membrane button - I recall this issue on this forum and we used resistors if I recall correctly to fix the fault.
                                        Let me review while you test with the keyboard only (no tweezers).
