ASUS ROG GA502D missing 19v
  • jeweemiah
    Learn anything
    • Feb 2022
    • 25
    • Texas
    Re: ASUS ROG GA502D missing 19v
    First Input mosfet:
    Drain: 20v
    Source: 0v
    Gate: 0v
    Second Input mosfet:
    Source: 0v
    Gate: 0v
    Drain: 4.3v
    Charging IC
    Charging IC
    PIN 1 = 4.7 V
    PIN 2 = 4.7 V
    PIN 3 = 0 V
    PIN 4 = 0 V
    PIN 5 = 1.3 V
    PIN 6 = 2.4 V
    PIN 7 = O V
    PIN 8 = 0 V
    PIN 9 = 0 V
    PIN 10 = 0 V
    PIN 11 = 1.6V
    PIN 12 = 0 V
    PIN 13 = 0 V
    PIN 14 = 0 V
    PIN 15 = 0 V
    PIN 16 = 0 V
    PIN 17 = 4.2 V
    PIN 18 = O V
    PIN 19 = 4.2 V
    PIN 20 = 4.2 V
    PIN 21 = 0 V
    PIN 22 = 0 V
    PIN 23 = 0 V
    PIN 24 = 0 V
    PIN 25 = 0 V
    PIN 26 = 0 V
    PIN 27 = 1.7 V
    PIN 28 = 19.4 V
    • mon2
      • Dec 2019
      • 14090
      measure and post the voltage readings of EACH pin on the charger IC. List the voltage list in order so that it is easier to review.
      • jeweemiah
        Learn anything
        • Feb 2022
        • 25
        • Texas
        Sorry my bad this is the compelete one
        Charging IC
        PIN 1 = 4.7 V
        PIN 2 = 4.7 V
        PIN 3 = 0 V
        PIN 4 = 0 V
        PIN 5 = 1.3 V
        PIN 6 = 2.4 V
        PIN 7 = O V
        PIN 8 = 0 V
        PIN 9 = 0 V
        PIN 10 = 0 V
        PIN 11 = 1.6V
        PIN 12 = 0 V
        PIN 13 = 0 V
        PIN 14 = 0 V
        PIN 15 = 0 V
        PIN 16 = 0 V
        PIN 17 = 4.2 V
        PIN 18 = O V
        PIN 19 = 4.2 V
        PIN 20 = 4.2 V
        PIN 21 = 0 V
        PIN 22 = 0 V
        PIN 23 = 0 V
        PIN 24 = 0 V
        PIN 25 = 0 V
        PIN 26 = 0 V
        PIN 27 = 1.7 V
        • mon2
          • Dec 2019
          • 14090
          Has the charger IC been replaced?
          If yes, apply flux and low air pressure but high heat till the ic swims onto the pcb pads.
          If the IC has not been replaced, suggest to source a fresh part for this repair.
          The charger IC has a fixed voltage regulator on pin #24 (REGN). See the datasheet above for full details. You have 0v on the output of this LDO, it should be ~6 volts.
          • jeweemiah
            Learn anything
            • Feb 2022
            • 25
            • Texas
            I replaced the IC and got the 6V. Here is the new measurement
            PIN 1 = 4.3 V
            PIN 2 = 4.3 V
            PIN 3 = 0 V
            PIN 4 = 0 V
            PIN 5 = 5.9 V
            PIN 6 = 2.7 V
            PIN 7 = O V
            PIN 8 = 0 V
            PIN 9 = 0 V
            PIN 10 = 0 V
            PIN 11 = 0 V
            PIN 12 = 0 V
            PIN 13 = 0 V
            PIN 14 = 0 V
            PIN 15 = 0 V
            PIN 16 = 0 V
            PIN 17 = 1.2 V
            PIN 18 = O V
            PIN 19 = 1.2 V
            PIN 20 = 1.2 V
            PIN 21 = 0 V
            PIN 22 = 0 V
            PIN 23 = 0 V
            PIN 24 = 6 V
            PIN 25 = 6 V
            PIN 26 = 0 V
            PIN 27 = 0 V
            PIN 28 = 19.4 V
            Still only got 4.3v on the main power rail.
            • mon2
              • Dec 2019
              • 14090
              Pins 11 & 12 are I2C (SMBUS) lines that require a pull up resistor on each pin.
              Find these resistors and post pics of them.
              One side of the resistor should be to sda pin and the other side to an always on 3v3 rail.
              Same for the SCL pin.
              You are showing the I2C lines to be 0v so either the resistors are missing/defective or the always on rail is defective.
              Find the resistors to confirm the issue.
              Also, it appears that you have a battery connected?
              Remove it and test only with the adapter for now.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #27
                @mon2 When 19V is not available on CLR, How +3VLP(LDO) will generate?? So SDA/SCL will be zero.
                • mon2
                  • Dec 2019
                  • 14090
                  Sorry - what is CLR ?
                  • jeweemiah
                    Learn anything
                    • Feb 2022
                    • 25
                    • Texas
                    #29
                    So after replacing the IC again. I now have 20v on my power rail
                    But still laptop won't turn on with or without the battery connected.
                    What are the next steps after this then? is this a bad fault?
                    • mon2
                      • Dec 2019
                      • 14090
                      Excellent.
                      With the adapter connected (no battery), measure the voltages again on each pin of the charger IC. Post the readings.
                      • jeweemiah
                        Learn anything
                        • Feb 2022
                        • 25
                        • Texas
                        #31
                        Here it is
                        PIN 1 = 19.6 V
                        PIN 2 = 19.6 V
                        PIN 3 = 0 V
                        PIN 4 = 0 V
                        PIN 5 = 5.9 V
                        PIN 6 = 2.7 V
                        PIN 7 = O V
                        PIN 8 = 0 V
                        PIN 9 = 0 V
                        PIN 10 = 0 V
                        PIN 11 = 0 V
                        PIN 12 = 0 V
                        PIN 13 = 0 V
                        PIN 14 =0V
                        PIN 15 = 0V
                        PIN 16 =0V
                        PIN 17 = 0.1 V
                        PIN 18 = O V
                        PIN 19 = 0 V
                        PIN 20 = 0.1 V
                        PIN 21 = 0.6 V
                        PIN 22 = 0 V
                        PIN 23 = 6 V
                        PIN 24 = 5.8 V
                        PIN 25 = 6 V
                        PIN 26 = 0.3 V
                        PIN 27 = 0.1 V
                        PIN 28 = 19.7 V
                        As for pin 11 and 12 the track goes to other parts of the board no resistor along the pins.
                        • mon2
                          • Dec 2019
                          • 14090
                          Measure the voltage on each pin of the first 2 mosfets with the adapter connected, no battery.
                          Post the readings.
                          • jeweemiah
                            Learn anything
                            • Feb 2022
                            • 25
                            • Texas
                            #33
                            Here its
                            1st mosfet =
                            Drain: 20.2 V
                            Source: 20.1 V
                            Gate: 26 V
                            2nd mosfet =
                            Source: 20.1 V
                            Gate: 26 V
                            Drain: 20.1 V
                            • mon2
                              • Dec 2019
                              • 14090
                              The mosfet voltages look good and gate is the expected voltage (~DCIN+6 volts to turn on).
                              However, do not see the same gate voltage in your post # 31.
                              Can you measure each voltage on the charger IC and post the list again ?
                              • jeweemiah
                                Learn anything
                                • Feb 2022
                                • 25
                                • Texas
                                #35
                                here you go brother
                                PIN 1 = 20.1 V
                                PIN 2 = 20.1 V
                                PIN 3 = 0 V
                                PIN 4 = 0 V
                                PIN 5 = 5.9 V
                                PIN 6 = 2.7 V
                                PIN 7 = O V
                                PIN 8 = 0 V
                                PIN 9 = 0 V
                                PIN 10 = 0 V
                                PIN 11 = 0 V
                                PIN 12 = 0 V
                                PIN 13 = 0 V
                                PIN 14 =0 V
                                PIN 15 = 0 V
                                PIN 16 =0 V
                                PIN 17 = 0.1 V
                                PIN 18 = O V
                                PIN 19 = 0 V
                                PIN 20 = 0.1 V
                                PIN 21 = 0.6 V
                                PIN 22 = 0 V
                                PIN 23 = 6 V
                                PIN 24 = 5.8 V
                                PIN 25 = 6 V
                                PIN 26 = 0.3 V
                                PIN 27 = 0.1 V
                                PIN 28 = 19.7 V
                                • mon2
                                  • Dec 2019
                                  • 14090
                                  The new list still does not show the proper voltage for ACDRV. However, the gate voltage is correct so the charger IC is spitting out the proper boosted voltage to turn on the mosfet.
                                  Carefully check again as the list is important for a proper review.
                                  Specifically, you must have ACDRV pin # 4 @ 26v since this is reaching the gates of the mosfet. It is the charger IC that will take in the DCIN voltage and the boost it up to the required ~26v to turn on the N-channel mosfets.
                                  • jeweemiah
                                    Learn anything
                                    • Feb 2022
                                    • 25
                                    • Texas
                                    #37
                                    The track of pin#4 goes immediately inside the board
                                    • mon2
                                      • Dec 2019
                                      • 14090
                                      That is fine but when using your meter, red lead on pin # 4 of the charger IC and black lead to ground - are you able to read the same voltage as on the GATE of the mosfet ?
                                      Just trying to establish that you are properly measuring the voltages on the charger IC.
                                      There are many 0v readings on the charger IC and do not believe the readings are accurate.
                                      Use the red meter directly on the pin of the charger IC - I think you should be able to find a close solder / shiny PCB pad to take these measurements.
                                      • jeweemiah
                                        Learn anything
                                        • Feb 2022
                                        • 25
                                        • Texas
                                        #39
                                        I resoldered again the IC appplying enough solder so it covers each pad so that my leads can have a test point directly on each side of the pin.
                                        And now my 20v can't even get to the board. My charger goes in to protection mode when I plug it in lol.
                                        Tried replacing the IC and still charger goes to protection mode.
                                        So Im back to my problem at the beginning but worse
                                        • mon2
                                          • Dec 2019
                                          • 14090
                                          Apply flux onto the IC -> ample heat -> low air pressure and remove the IC.
                                          With the charger IC removed, check the first 2 mosfets for possible defects with the resistance checks - see many earlier posts on the process.
                                          Then use flux again + low temp solder to coat each pad of the PCB where this IC is to be soldered. Take your time and be sure to not damage the IC pads.
                                          Then use desoldering braid to remove the excess solder off the PCB - to flatten the solder bumps as much as possible.
                                          Then use IPA to clean up the pads and locations you have just worked.
                                          Check the bottom side of the charger IC to be sure it is clean of any shorts.
                                          Apply flux again and apply the charger IC back onto the board. Very little solder is required to solder down SMD parts so the 'tinning' of the solder on the IC should be enough.
                                          If the reworked IC is not working then you probably have a short somewhere.
                                          • Scotchmist
                                            Asus GA502D keeps blowing mosfet
                                            by Scotchmist
                                            I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                                            I have removed the mosfet and can run the laptop no problem
                                            The MOSFET is FDPC5018SG
                                            Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                                            08-24-2024, 02:23 PM
                                          • AppleLover123
                                            Asus X712EA 3 volts after the first mosfet
                                            by AppleLover123
                                            Hey guys,
                                            i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                            I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                            Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                            I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                            Now i thought something...
                                            12-15-2024, 07:49 AM
                                          • m0jo1103
                                            Need help.... Lenovo L340-15IRH mosfet missing!
                                            by m0jo1103
                                            Can someone please help me.. Mosfet is missing on this motherboard (Lenovo L340-15IRH) I cant find the part number.. Can someone please send me a picture or part number of the mosfet missing on the board.. Thankyou!
                                            05-19-2025, 07:13 AM
                                          • khabib
                                            ASUS STRIX G531GT MISSING PM_SLP_SUS#
                                            by khabib
                                            Hello guys i have ASUS laptop that power on but can't switch ons , i trying using power sequence and last missing PM_SLP_SUS# .
                                            here what i measure already:
                                            EC_RST# 3.3V
                                            SRTCRST# 3v
                                            +3VA_RTC 3V
                                            RTCRST# 3V
                                            ME_SusPwrDnAck 0V
                                            AC_PRESENT 3.3 V
                                            AC_IN_OC# 0V
                                            PS_ON 3,3V
                                            +3VA_DSW 3.3V
                                            DPWROK_EC /R 3.2V
                                            PM_BATLOW# 3.3V
                                            SM_INTRUDER# 2.8V
                                            PM_SLP_SUS# -----> MISSING VOLTAGE ( but sometime this voltage is present )
                                            THat is can confirm PCH relate issue...
                                            05-28-2024, 01:30 AM
                                          • MicroSMD Lab
                                            ASUS ROG Zephyrus GPU Mosfet repeat failure
                                            by MicroSMD Lab
                                            The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                                            I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                                            01-10-2024, 06:36 AM
