iPad 2019 not charging
  • Jenzo
    • Jul 2019
    • 135
    • Belgium
    Hey everyone!
    Have an iPad 2019 (820-01686) here that's not charging. When it came in I tested it with the Tristar tester, and it failed. Replaced the tristar, no fail on the tester anymore, but still not charging. It's drawing 0amp. Replaced the dockconnector to make sure, and the Tristar a second time, but still no luck.
    What should I be looking at next? Thanx in advance!
  • mon2
    • Dec 2019
    • 13880
    Re: iPad 2019 not charging
    See attached. Suspecting the soldering of the referenced dockflex pcb joints. Took me 3 attempts to resolve this and went well after this rework. Apple wanted the client to buy another iPAD. The client used a cheap cable from the dollar store and it got stuck and killed the Apple charging port.
    Be patient with this area so to not rip off any pads.
    Do not use hot air - only soldering iron.
    Alex (Northridge Repair) has an excellent video on this exact repair:
    https://youtu.be/5X3lfIMAVn8
    • Jenzo
      • Jul 2019
      • 135
      • Belgium
      I've used hot air to remove the old one, and soldered the new one on.
      I've reworked it, seems to be ok, but still no luck. What would be the next step?
      Thank you for the help so far!
      • mon2
        • Dec 2019
        • 13880
        I know it sounds redundant - felt the same but the fault for us was still with this cable connection onto the main board.
        Consider to flux it well and touch upon each pad again with a soldering iron. The 0A current draw is the give away for this fault.
        Are you comfortable with the Tristar chip replacement ? Would you recall which exact Tristar version was used ? Did you make it 'dance' to confirm the ball joints of the WLCSP package are down without shorts ? We had the fun of replacing that part at least 2 times as well.
        What is the history of this device ? Was it dropped ?
        I recall some dialog about broken coils which is a common fault but let me dig around.
        • mon2
          • Dec 2019
          • 13880
          BTW - which tristar tester are you using ? Ben's ? or using DIODE mode testing ?
          If DIODE mode testing - post your diode readings.
          • Coldpaulo
            • Mar 2022
            • Brazil
            interesting
            • Jenzo
              • Jul 2019
              • 135
              • Belgium
              No problem, I'm open to any information! Now I wanted to retouch the docking flex again, but snapped off one of the E75_DPAIR1_CONN_P pad off the flex. :') Ordered a new one, so will report back about that tomorrow.
              I have done about 20 tristar replacements, so no expert but I'm not new new to this. Did a succesfull tristar replacement on an iPhone 7 right before attempting this iPad
              The type of the tristar used is 610A3B.
              We have replaced the digitizer of this ipad a good half year ago, but apart from that, nothing special that I know of.
              • Jenzo
                • Jul 2019
                • 135
                • Belgium
                Oh, and it's the tristartester.com one.
                • Jenzo
                  • Jul 2019
                  • 135
                  • Belgium
                  New charging flex installed, still no luck. :')
                  • mon2
                    • Dec 2019
                    • 13880
                    Do you still have 0A current draw?
                    Is the meter used for this testing capable of showing 3 digits of current?
                    Do you have a battery connected? If yes, remove it and test again.
                    After the above, remove all power, meter in resistance mode and check for shorted caps.
                    Review the PMIC area of caps as per this video:
                    (Do not recommend the method of power injection at this time - just check for shorted caps, if any)
                    https://youtu.be/xqki4qHCJuw
                    • elecsoluces
                      • May 2020
                      • 66
                      • France
                      What is the ipad model?
                      Are you sure it is a charge problem? Does the ipad boot with a charged battery?
                      Use a power supply to inject VBAT and check the current consumption.
                      Report reslults.
                      • Jenzo
                        • Jul 2019
                        • 135
                        • Belgium
                        @Mon2
                        Still 0.00 draw, my amp meter has 3 digits.
                        Testing without battery atm.
                        No shorted caps around the tristar, checked the pmic area and I do measure very low (0.16) resistance on PPVDD_S1_SOC, altho I have no clue if that's supposed to be higher.
                        @elecsoluces
                        Hey! The modelnumber is A2197.
                        It seems you are right, doesn't boot on a charged battery, I get an Apple logo but it goes off again.
                        Injected power into vbat, no current consumption until I prompt to boot, then 0.7A for a bit until it dies again.
                        This is very confusing since the tristar tester indidcated failing tristar, but now it seems to be more then that :') Thanx everyone for the help so far, I'm learning a lot from this process.
                        • mon2
                          • Dec 2019
                          • 13880
                          Maybe related:
                          https://www.youtube.com/watch?v=6l0uQR6CktI
                          • Jenzo
                            • Jul 2019
                            • 135
                            • Belgium
                            That would be above my skill Shouldn't the device charge if that's the issue tho?
                            • elecsoluces
                              • May 2020
                              • 66
                              • France
                              Put your charged battery and try to connect the machine in restore or DFU mode to Itunes, then try an update or a restore.
                              • Jenzo
                                • Jul 2019
                                • 135
                                • Belgium
                                Can't get it to restore, it might be the CPU problem. I'm gonna give up, thank you for the advice everyone.
                                • mon2
                                  • Dec 2019
                                  • 13880
                                  What do you see when you attempt the restore ? Any error code raised by iTunes ?
                                  Can you test with another lightning cable ? Is the lightning cable a known good and certified with the original Apple chip ? Shorter the better.
                                  Does the host PC recognize the iPAD when you connect with iTunes ? This will confirm the dockflex replacement cable is working along with many other portions of the iPAD design.
                                  • Jenzo
                                    • Jul 2019
                                    • 135
                                    • Belgium
                                    It shuts down before anything can happen. Cable is known good, use it daily, and worked fine with the previous device. PC recognises iPad tho. Thing is I'd love to continue on this, I really want to know, but customer doesn't want to wait any longer.
                                    • mon2
                                      • Dec 2019
                                      • 13880
                                      Yup - have met similar customers. They think grass is always greener in the next pasture. They will take it to the local butcher shop with a propeller head who will claim they can fix it 'while they wait' and then they come crawling back for the low level repairs when all else fails. Have seen it over and over. If you can replace tristar chips, this is not your first rodeo and you are very capable of fixing this fault but takes quality time to properly troubleshoot these black boxes. From a recent review, it appears that Apple has lowered their tablet prices so perhaps the customer will just buy another.
                                      • Jenzo
                                        • Jul 2019
                                        • 135
                                        • Belgium
                                        That is pretty much what is happening here indeed. The only thing that's bothering me about this, is that I don't know what the actual problem was now. But it is what it is, I thank you for your help!
                                        • GeirAndersen
                                          iPad .pcb file collection
                                          by GeirAndersen
                                          I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                                          Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                                          IPAD COLLECTION 1
                                          +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                                          +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                                          +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                                          +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                                          +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                                          +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                                          12-09-2024, 09:28 AM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • badboyzzz
                                          A2229 ipad pro 12.9 4gen strange problem Logic Board related charging but no usb data
                                          by badboyzzz
                                          I have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
                                          12-28-2024, 02:11 PM
                                        • waterchill
                                          Apple iPad Pro 12,9" 4Gen no charging, but working fine
                                          by waterchill
                                          Hey folks, I have this iPad Pro 12,9" 4Gen A2232 here with no charging issue. The main fault was a crossed pins / faulty USB charging port due a bad cable.
                                          So I started to replace this parts:
                                          - replaced usb-c port -> no result
                                          - replaced battery -> no result
                                          - replaced usb-c chip CD3217B12A -> no result
                                          - replaced 343S00326 -> no result
                                          - replaced 343S00327 -> no result
                                          - replaced 343S00328 -> no result
                                          I have no more ideas for this issue. There is no short on the whole board, and the iPad is working fine...
                                          04-30-2024, 05:37 AM
                                        • Thomasraud
                                          Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                          by Thomasraud
                                          i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                          QUOTED
                                          -It works on charger (without battery connected-only charger)
                                          -It works on battery (without charger connected-only battery)
                                          -& it also works when plugged in battery & charger, but it's not charging the battery
                                          //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                          and..
                                          QUOTE
                                          The IC cannot maintain the input current level
                                          06-28-2022, 06:47 PM
