MacBook Air 2018 not turning one
  • Win Me
    • Jan 2021
    • 30
    • France
    Hello, so I get on e-Bay an higly water damaged mother board, to replace another one with a dead T2. So I managed to fix the water damged one, after a day of schematic readings and components replacing. But I made a BIG mistake. The computer turned on, with backlight and everything, Apple logo showing but the power button wasn't working, so I unpluged the cable for audio jack and pwrbttn and pluged it in back.... And now it doesn't boot anymore, staying at 20V around 0.039-0.041 Amps. In the T2 power boot sequence the last line to get power is PP2v7_NAND, so the NAND is corectly powers on. But no PP3v3_S5 and don't understand why cause not shorted and I have PP3V3_AWAKE from the T2. Any help please?
  • mon2
    • Dec 2019
    • 14672
    Re: MacBook Air 2018 not turning one
    Post your 820-xxxx number from your logic board so that we can reference the proper schematic.
    • Win Me
      • Jan 2021
      • 30
      • France
      I will check that when I get back from work
      • Win Me
        • Jan 2021
        • 30
        • France
        If I me rember well it is a 820-01521
        • Win Me
          • Jan 2021
          • 30
          • France
          I comfirm, it is a 820-01521 mother board, I checked
          • Win Me
            • Jan 2021
            • 30
            • France
            Can anyone Help me ?
            • envym
              MacBook Pro 2018 with Activation Lock
              by envym
              Hi everyone!
              I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
              I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
              06-27-2025, 08:54 AM
            • Ugur87
              MacBook Air M4 A3240 Brand New Water Damage no Image
              by Ugur87
              I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
              08-28-2025, 01:09 PM
            • MKesenheimer
              Macbook air 2020 (820-01958) with water damage not turning on
              by MKesenheimer
              Dear all,
              I have a Macbook Air 2020 13” (820-01958) with water marks around U8700, C7665 and U2800 in front of me. The laptop is not turning on but the CPU is getting warm after a while.
              I am trying to figure out which component is potentially dead. For that I made the following measurements:
              Voltages on T2 chip rails:
              PP1v8_SLPS2R = 1.80V
              PP1v8_AWAKE = 1.80V
              PP1V8_SLPS2R_PMUVDDGPIO = 1.80V
              PP1v1_SLPS2R = 1.10V
              PP0v8_SLPS2R = 0.80V
              PP0v82_SLPDDR = 0.82V
              PP3v3_AWAKE = 3.28V
              PPVDDCPUSRAM_AWAKE = 0.80V
              PP0v9_SLPDDR...
              01-05-2023, 08:37 AM
            • robka
              MacBook Pro 2018 - A1990 Dead - not charging - only 5V
              by robka
              my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
              I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
              The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
              After that the Macbook was dead. It isn't charging anymore.
              The USB-C Port where the charger was plugged is burned. Also The Cable and the...
              03-02-2024, 02:58 PM
            • TimSinger
              MacBook Pro M4 16" A3403 on the table with water damage
              by TimSinger
              Hi guys,
              I have a MacBook Pro M4 16" A3403 on the table with water damage. I allready found the problem within a bad cap. As far as my researh went, I couldn't find the schematics and boardview for this MacBook model. They seem not to be released now. So my question is if anybody has a working A3403 on the table and could tell me, which specification this capasator has?
              I attached a photo of the missing cap. It's on the bottom side of the logicbard.
              I am very thankful for your replys.
              Thanks in advanced and best regards from Hamburg Germany...
              07-13-2025, 11:12 AM
