820-2915-A Wont power on with battery connected
  • beogeek
    • Apr 2018
    • 97
    • Serbia
    Re: 820-2915-A Wont power on with battery connected
    replaced Q7055
    source 12.38
    drain 12.38v
    gate 5.384v
    still same issue, fans spin up and then nothing
    I've also placed back D6990 fyi
    • mon2
      • Dec 2019
      • 13836
      Without power, post the resistance readings of the replacement Q7055 mosfet.
      Then post the voltage of PPBUS_G3H with the battery.
      Does the fan continue to run with the battery or just a brief on then off cycle if using only the battery?
      • beogeek
        • Apr 2018
        • 97
        • Serbia
        Q7055
        source (1-2-3) & drain (5-6-7-8) 28MΩ red probe on source, black on drain
        source (1-2-3) & gate (4) 0Ω red probe on source, black on gate reversed probes 5.4MΩ
        gate (4) & drain (5-6-7-8) 24MΩ red probe on gate, black on drain
        PPBUS_G3H measured at R5400 R5410 12.38v
        • mon2
          • Dec 2019
          • 13836
          This is not a good reading. This should not be a short. Can you confirm ?
          Also confirm that soldering is ok on Q7055 and the related parts.
          You can apply flux on the mosfet (Q7055) -> hot air it till the part is able to swim. Then nudge it with tweezers and the part should move and settle back naturally onto the SMD pads on the PCB.
          Then check the resistance again for source & gate pins.
          OR - did you mean to write "OL" (over limit) for this resistance reading ?
          • beogeek
            • Apr 2018
            • 97
            • Serbia
            Sorry source (1-2-3) & gate (4) OL not 0ohms, yes checked it its soldered on well. 8.56MΩ when I reverse the probes
            • beogeek
              • Apr 2018
              • 97
              • Serbia
              #26
              see check it
              • mon2
                • Dec 2019
                • 13836
                Ok - now the Q7055 mosfet readings are good.
                Confirm the voltage of PPBUS_G3H after the fan spin stops (use battery only).
                Then check that the same voltage is present @ PPVIN_G3H_P3V42G3H. This is pin # 3 of D6990.
                The battery should continue to create the PP3V42_G3H @ coil L6995, pin #2. Confirm this voltage as well after the fan stops the spin.
                • beogeek
                  • Apr 2018
                  • 97
                  • Serbia
                  #28
                  PPBUS_G3H 12.38
                  @ PPVIN_G3H_P3V42G3H. This is pin # 3 of D6990: 3.354
                  PP3V42_G3H @ coil L6995, pin #2. 2.504
                  Now i do not get fan spin with just the battery connected, I only get slight fan spin if I connect the adapter. Even shorting the keyboard connector doesn't produce a slight fan spin with just battery connected.
                  • mon2
                    • Dec 2019
                    • 13836
                    PPBUS_G3H 12.38
                    Good value.
                    Both of these are bad values.
                    Check the voltage on pin # 1 again on D6990 diode. This is PPBUS_G3H and should match the voltage of 12v38. This voltage is going into D6990 but not leaving this dual diode.
                    Do you have a replacement for D6990 ?
                    If not, we can try a temp "hack" (will have to do it quickly before @Piernov reads this thread
                    • beogeek
                      • Apr 2018
                      • 97
                      • Serbia
                      #30
                      pin # 1 again on D6990 diode 12.38v yes ive got a donor board, should I swap them?
                      • mon2
                        • Dec 2019
                        • 13836
                        Yes, please do. The dual diode is not working correctly for this leg of the circuit.
                        • beogeek
                          • Apr 2018
                          • 97
                          • Serbia
                          #32
                          ok replaced the diode, reading is now 12.38v also L6995 is showing 3.475v on both sides. Now shorting the keyboard does produce fan spin but for a few seconds, like when the battery and power is connected.
                          • mon2
                            • Dec 2019
                            • 13836
                            Good.
                            If you use only the power adapter, the logic board works properly and you can see the Apple logo, etc. ?
                            If you then use only the battery, you see the fan spin for a few seconds but then nothing ? After the fan turns OFF, confirm the voltage of PPBUS_G3H and PP3V42_G3H.
                            Both should remain to be normal values with only the battery.
                            • beogeek
                              • Apr 2018
                              • 97
                              • Serbia
                              #34
                              Yes boots fine without battery.
                              PPBUS_G3H 12.37
                              PP3V42_G3H 3.475
                              Both should remain to be normal values with only the battery. Correct.
                              • mon2
                                • Dec 2019
                                • 13836
                                Now that PP3V42_G3H is restored with the battery only, check the voltage of D6950 again.
                                Post the readings.
                                • beogeek
                                  • Apr 2018
                                  • 97
                                  • Serbia
                                  #36
                                  D6950 pin 1&2 3.463 pin3 0V
                                  • mon2
                                    • Dec 2019
                                    • 13836
                                    Now the diode readings are correct.
                                    1) Confirm that the SMBUS (same pins you just tested) are solid and reaching the physical connector for the battery. If the contacts are not solid to the battery, then the logic board cannot see the battery pack. Numerous transactions occur over these I2C (SMBUS) pins to extract parameters from the battery.
                                    2) After the above - boot up WITH the power adapter & battery connected.
                                    Does the MAC OS see the battery and report the number of charge cycles, etc. ? This will confirm that the SMBUS interconnect is OK.
                                    3) Aside from the above, I think it will be best to replace the battery and test again. It appears that everything is in order now - aside from the actual SMBUS communication with the battery pack.
                                    Post the details of the above testing. You are very close.
                                    • beogeek
                                      • Apr 2018
                                      • 97
                                      • Serbia
                                      #38
                                      Ok touched up the diode, tested it from the diode to the connector it has continuity from the diode to the battery connector.
                                      Trying to boot with the battery still no go, will boot without it. With the battery connected the fans spin for a brief moment and then back to nothing.
                                      • beogeek
                                        • Apr 2018
                                        • 97
                                        • Serbia
                                        #39
                                        I'll order the replacement battery and check it again when it arrives. Sheesh and everyone always complains that the SMC is difficult to replace, this was a nightmare hahah doubt I would have gotten to this stage without your help again. And now thinking back, I tripped up over Q7055, I didn't measure it correctly and then I ended up in a loop looking for the issue while it was staring me right in the face. I'll get that battery and see what it does when it arrives, I'll post back when it arrives. Thank you mon2 you've been a bloody life saver!
                                        • mon2
                                          • Dec 2019
                                          • 13836
                                          No worries. Trying to throw out my 2 bits when I can..it is very much trial & error and hopefully will save someone some time in future readings.
                                          Can you confirm that you are able to boot up if BOTH, the adapter & battery are connected ? If you can boot up normally, what does the MAC OS report for your battery ?
                                          Very interested to know if the logic board can ping out the # of charge cycles, etc. out of the battery pack. This will confirm that the BMS inside the battery pack is OK.
                                          Otherwise, I think what may be happening here is that the SMBUS communication is at fault with the actual battery pack. That is a hunch. The lines are open-drain and are now being pulled up to the 3v42 rail ok.
                                          Perhaps the BMS module inside the battery pack is defective. A replacement known good battery is a good test for your case. Just be cautious from where you source your batteries as others have reported that there is a lot of garbage on the market. Not a bad idea to buy from Amazon or similar where you have a return policy if you do not love the battery.
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • code share
                                            Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                            by code share
                                            I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                            Here's what I've tried so far:
                                            • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                            • Booted successfully on AC power only with the battery disconnected
                                            • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                            • Battery
                                            04-21-2025, 12:50 PM
                                          • platinumsteel
                                            Macbook Pro 13'' 2017 A1708 Won't power on with battery connected.
                                            by platinumsteel
                                            Hi guys i have a 820-00840 that works fine and boots up as long a battery is not connected. I initially thought it was a bad battery so i went ahead and bought a new battery for it and slapped it in yesterday and realize that the same fault exists. When i screw in the battery and connect the little battery strip and i press the power button it will not power on.At that time If i connect the charger i get fan spin for 10 seconds then stops but the machine won't power on.If i disconnect the little battery strip and re-plug the charger the machine boots as normal.It's not the battery connector strip...
                                            03-03-2023, 10:17 AM
                                          • wraster
                                            Laptop stays on for only ~10sec when battery is connected, fine otherwise (Lenovo ThinkBook 15 G4 AMD)
                                            by wraster
                                            I have a Lenovo ThinkBook 15 G4 AMD (HLXB5 LA-M062P) that, when the battery is connected, starts up and shuts off in about 10 seconds, even when connected to power supply via USB-C charger. When the battery is disconnected, the computer stays on as in normal/expected operation (powered by USB-C charger input). I bought a new battery and see the exact same thing. My conclusion is it is not the battery itself but maybe some circuit or component involved in battery/DC-in crosstalk. I found a schematic but not boardview (request link below - sorry for the formatting, I'm not sure how to make an inline...
                                            Hi, I have a TB 15 Gen 4 that has an issue with the battery circuits. I believe the schematic is the same as this one: https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/schematic-requests-only/3522169-lenovo-thinkbook-14s-yoga-gen2-la-m062p
                                            02-25-2025, 11:33 PM
                                          • donnos
                                            A1989 820-00850 does not boot when battery is connected
                                            by donnos
                                            Hi All,
                                            have this macbook came in issues not able to turn on, found out the battery is blown(literally having holes in it). tried to do a battery swap and its still not booting up. However without battery connected, macbook boots up fine.
                                            Tried battery from another vendor, macbook boots but does not charge, system reports detects battery data and shows battery "service recommended". this at least tells me that the SMC/T2 is working.
                                            Tried changing ISL6240 chip and still the same. all 4 ports working fine,
                                            Checked current sensing resistors all...
                                            03-23-2023, 11:36 AM
