820-2915-A Wont power on with battery connected
  • beogeek
    • Apr 2018
    • 97
    • Serbia
    Ok so this doing my head in and hopefully someone more knowledgeable will be able to assist.
    I've got a MacBook Pro 820-2915-A it will power on without the battery connected, but when the battery is connected it will do a 2,3-second fan spin when pressing the power button and then nothing.
    After measuring and probing around I found that R7051 was bad, reading high instead of 2.2Ω so I replaced it. Still the same issue, I have the green light on the charger but it won't power on or charge the battery.
    So to cut the long story short I've replaced U7000, R7051, Q7035, Q7030, and finally U4900 (SMC). Now when I connect the battery and adapter, the battery is charging with an orange light, in fact after waiting for 2 odd hours the BIL is indicating fully charged and the adapter changed to green once fully charged. But still, the same issue persists, when I try powering it on I get a slight fan spin and nothing, remove the battery and it powers on fine.
    I've tried by-passing the SMC but it will not power on with the battery, by-pass works without the battery connected as I can see the FANS run at full speed.
    I'm not sure what it is now, could it be the battery is bad? I've tried turning on the board with just the battery and the same thing, slight spin, and stop. So I checked Q7055 and it has 12.57v on all pins when the battery is not connected, with it is connected pin 4 is 12.54v. Also checked R6950 which is measuring fine.
    I've ordered a new battery which is on the way as I need one for myself for testing, measuring the current battery reads 12.37v.
    Any help or pointers are greatly appreciated.
  • mon2
    • Dec 2019
    • 14246
    Re: 820-2915-A Wont power on with battery connected
    Post the voltage readings of the i2C (smbus) esd diodes at D6950 with the battery connected.
    • beogeek
      • Apr 2018
      • 97
      • Serbia
      Hi mon2 appreciate the help.
      With only the bat connected
      D6950
      pin 1: 1.196
      pin 2: 1.197
      pin 3: 0
      with dc adapter connected & bat connected
      D6950
      pin 1: 2.7-3.4 fluctuating
      pin 2: 2.7-3.4 fluctuating
      pin 3: 0
      • mon2
        • Dec 2019
        • 14246
        Post the voltage readings of D6990.
        First with only the power adapter ( no battery ).
        Then remove the adapter, use only the battery.
        Post the readings.
        The PP3V42_G3H is not correct with only the battery.
        • beogeek
          • Apr 2018
          • 97
          • Serbia
          D6990
          with charger only
          pin 2: 16.70
          pin 3: 16.41
          with bat only
          pin 2: 0.010
          pin 3: 2.952
          • mon2
            • Dec 2019
            • 14246
            D6990 is with 3 pins.
            Please also post the voltage of pin #1 of D6990 for each case.
            Is the battery charged? What is the voltage on the battery being tested ?
            • beogeek
              • Apr 2018
              • 97
              • Serbia
              sorry my bad
              with dc
              pin 1: 12.57
              bat only
              pin 1: 12.38
              bat voltage 12.38
              • beogeek
                • Apr 2018
                • 97
                • Serbia
                prior to charging the battery it was indicating about 3 leds on the BIL, charger was amber, once charging was completed the BIL indicates full battery and the charger changed from amber to green.
                Board runs fine without the battery connected, boots the OS etc. Only when the bat is connected it wont boot, I connect the charger, the fans quarter spin and that's all it does.
                • mon2
                  • Dec 2019
                  • 14246
                  What is the voltage on both sides of R6990 ? Measure with the battery connected.
                  Post the voltage of PP3V42_G3H with only the battery.
                  • beogeek
                    • Apr 2018
                    • 97
                    • Serbia
                    R6990
                    Bat only
                    0.010 both sides
                    bat & dc
                    16.62 left side pin 2
                    16.79 right side pin 1
                    • mon2
                      • Dec 2019
                      • 14246
                      Remove all power.
                      Multimeter in DIODE mode.
                      Check & post the readings of:
                      Red meter probe on pin # 1 & black meter probe on pin # 3.
                      Red meter probe on pin # 2 & black meter probe on pin # 3.
                      Red meter probe on pin # 3 & black meter probe on pin # 1.
                      Red meter probe on pin # 3 & black meter probe on pin # 2.
                      We want to confirm that D6990 is not damaged.
                      • beogeek
                        • Apr 2018
                        • 97
                        • Serbia
                        Red meter probe on pin # 1 & black meter probe on pin # 3. 1.094
                        Red meter probe on pin # 2 & black meter probe on pin # 3. 0.253
                        Red meter probe on pin # 3 & black meter probe on pin # 1. OL
                        Red meter probe on pin # 3 & black meter probe on pin # 2. OL
                        • mon2
                          • Dec 2019
                          • 14246
                          Remove D6990 off the logic board.
                          Then measure again the voltage on both sides of R6990 with the battery only.
                          Post the readings.
                          • beogeek
                            • Apr 2018
                            • 97
                            • Serbia
                            R6690 0.001v on both sides with bat only
                            • mon2
                              • Dec 2019
                              • 14246
                              Post the voltage readings on Q7055 mosfet with only the battery.
                              Voltage readings of:
                              pins 1-2-3 (Source)
                              pin 4 (gate)
                              pins 5-6-7-8 (Drain)
                              Please confirm that you are measuring the voltage of resistor R6990 (I had a typo in the earlier post - now corrected).
                              • beogeek
                                • Apr 2018
                                • 97
                                • Serbia
                                F6905 0.0 both sides
                                • mon2
                                  • Dec 2019
                                  • 14246
                                  1) Post the voltage readings on Q7055 mosfet (with only the battery).
                                  2) Then, remove all power. Meter in resistance mode (2k scale).
                                  Measure & post the readings of the same Q7055 battery mosfet for:
                                  source (1-2-3) & drain (5-6-7-8)
                                  source (1-2-3) & gate (4)
                                  gate (4) & drain (5-6-7-8)
                                  Checking for any low resistance readings which will likely be due to the mosfet being defective.
                                  • beogeek
                                    • Apr 2018
                                    • 97
                                    • Serbia
                                    Q7055
                                    source (1-2-3) & drain (5-6-7-8) 0.4Ω red probe on source, black on drain
                                    source (1-2-3) & gate (4) 171.3Ω red probe on source, black on gate
                                    gate (4) & drain (5-6-7-8) 165.7Ω red probe on gate, black on drain
                                    • mon2
                                      • Dec 2019
                                      • 14246
                                      Q7055 is defective and needs to be replaced.
                                      You can remove off the logic board and check the resistance again to confirm the readings. The resistance is too low for this mosfet.
                                      If possible, replace with the same part but many parts can work as a replacement, if needed. Maybe you have a donor board ?
                                      • beogeek
                                        • Apr 2018
                                        • 97
                                        • Serbia
                                        I'll remove it now and report back in a jiff
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • code share
                                          Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                          by code share
                                          I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                          Here's what I've tried so far:
                                          • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                          • Booted successfully on AC power only with the battery disconnected
                                          • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                          • Battery
                                          04-21-2025, 12:50 PM
                                        • survivalbloke
                                          Acer Predator Helios 300 - will not power up if battery is CONNECTED
                                          by survivalbloke
                                          This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                                          06-25-2025, 12:20 PM
                                        • platinumsteel
                                          Macbook Pro 13'' 2017 A1708 Won't power on with battery connected.
                                          by platinumsteel
                                          Hi guys i have a 820-00840 that works fine and boots up as long a battery is not connected. I initially thought it was a bad battery so i went ahead and bought a new battery for it and slapped it in yesterday and realize that the same fault exists. When i screw in the battery and connect the little battery strip and i press the power button it will not power on.At that time If i connect the charger i get fan spin for 10 seconds then stops but the machine won't power on.If i disconnect the little battery strip and re-plug the charger the machine boots as normal.It's not the battery connector strip...
                                          03-03-2023, 10:17 AM
                                        • flat-earther
                                          how to prevent a connected charger from draining battery when not charging?
                                          by flat-earther
                                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                          So the battery is backfeeding the charger and being drained.
                                          How can I prevent...
                                          08-07-2025, 01:04 PM
