820-00138 Orange Light won't charge
  • wasaab
    • Mar 2020
    • 16
    Hi everyone, I have been working on a water damaged 820-00138 ISL6259 was replaced and now have PPBUS_G3H and fan spin without battery plugged in. L7130 measures 16.59V on AC power and 11.03V when on battery on L7130. When plugging in a genuine Apple charger the green light goes on for a brief moment and then turns off. Computer runs fine off battery. Another strange thing is when using a non-official charger the battery does charge. I am at a loss on where to look next. I was suspecting maybe one of the charging mosfets possibly? Q7130 perhaps? I was hoping perhaps someone with a bit better understanding of the charging circuit can point me in the right direction of where I should look next. Any help is much appreciated,
  • Simplebeans
    • Sep 2021
    • 135
    Re: 820-00138 Orange Light won't charge
    First of all your current power adapter is that the correct one for your model? Can you confirm for me please what you have.
    And also what does your battery status menu report when you have the charger plugged in?
    • reformatt
      • Feb 2020
      • 1505
      What does PPDCIN_G3H measure with a genuine charger? The genuine Magsafe's use a load sense in order to switch through the power. PPDCIN_G3H should measure 0V with no charger plugged in. The load is created by R7012. If you don't have 0V here, then you need to check Q7010 and Q7180.
      I've had Q7180 go leaky, so allows battery side volts back through it, which interferes with the load detection of the magsafe. Knock off's don't have this feature so just pump through regardless of load.
      • wasaab
        • Mar 2020
        • 16
        Hi Simplebeans thanks so much for the response. Yes it is the correct charger model A1424 85W MagSafe2 adapter. Battery status shows that it is just running on battery only. The green light goes out as soon as I plug in the charger. With the battery unplugged the board will power up and I get fan spin with orange light. The light goes out as soon as the battery is plugged in. No green light either. It seems the charger shuts off completely. Then I have to unplug it for a bit to reset it.
        • wasaab
          • Mar 2020
          • 16
          Thank you reformatt, I will check this rail later and report back my findings, thank you for this information it is very helpful!
          • piernov
            • Jan 2016
            • 4439
            • France
            Shorted charging rail high-side MOSFET, bad charger IC.
            • Simplebeans
              • Sep 2021
              • 135
              I think you mean ‘A1398’, ok have you completed a SMC and PRAM/NVRAM reset?
              Check the battery connector board side and just make sure everything is ok on the connector and PINS and report back.
              • wasaab
                • Mar 2020
                • 16
                Thanks SimpleBeans, the charger model is a1424 85w charger. The computer is an a1398. I have checked the connector side of the battery and all checks out fine. SMC/NVRAM reset does nothing unfortunately. I am suspecting a bad mosfet as piernov suggested.
                • wasaab
                  • Mar 2020
                  • 16
                  Had a chance to check R7012 and 0v is what it measures with no charger and battery plugged in.
                  • wasaab
                    • Mar 2020
                    • 16
                    So I check R7012 and have 0V, in looking at the schematic though I think you may have meant R7120 which is connected to the two current sense resistors on the ISL chip. Now when I measure this point I have 11V. I think we may be onto something here. I think you may be correct in thinking Q7180 is at fault. I will see if I have a donor board to swap this part out. Keep you posted as to the results. Thanks again for all the help everyone!
                    • wasaab
                      • Mar 2020
                      • 16
                      Replaced Q7180 and Q7010, still no change. Tried multiple chargers, also tried a new battery to make sure it wasn't that.
                      • Simplebeans
                        • Sep 2021
                        • 135
                        It is R7012 you need to measure this is part of the circuit with Q7010. If you can measure R7012 and report back please?
                        • wasaab
                          • Mar 2020
                          • 16
                          Thanks it measures 0v at R7012
                          • Simplebeans
                            • Sep 2021
                            • 135
                            Thanks ok so that covers the majority of the things it could have been, i think we possibly have left a couple of things to explore here. I need you to do another thing can you also inspect the charging port for any debris and burn marks. I do not think it wil be this anyway because you are getting a green light on occasion but I want to make sure. If you find any debris remove them with tweezers and if there is any marks clean them up, you can use Isopropyl Alcohol (99.9%) and cotton buds. Make it nice and clean and report back please. Remove battery power before doing this.
                            • reformatt
                              • Feb 2020
                              • 1505
                              What does PPBUS_G3H and PP3V42_G3H measure with a genuine magsafe and a knockoff? If both measure ok, then you need to troubleshoot backwards on the one wire circuit (SMC_BC_ACOK, U7000, U7001).
                              • ipatch
                                troubleshooting microsoft surface pro 4 no power no led charge light
                                by ipatch
                                hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                10-05-2023, 11:59 AM
                              • Rezendes
                                820-3115-B No Orange Light, Won’t charge battery
                                by Rezendes
                                Hello, I have a MacBook 820-3115-B board that never shows an Orange light and goes straight to a green light and turns itself on when the ac adapter is plugged in. System won’t run off battery and turns off immediately when ac power unplugged. I believe the battery should be ok as it was a replacement not too long ago but it’s possible that’s the issue as most anything is possible I guess. I don’t have any spare batteries or donor boards although I have ordered 2 on the way. I have replaced U7000 and same results. I have also applied flux and reflowed the SMC IC and no change. Nothing...
                                06-23-2024, 12:56 PM
                              • judamex
                                MacBook Air 820-00165 turns on But no green and orange light, not charge
                                by judamex
                                MacBook Air turns on without battery connected, no green or orange light comes on, I connect the battery and it shows battery with lightning and it restarts constantly.
                                03-06-2025, 03:55 PM
                              • tccyo22
                                Macbook Pro A1278 intermittent orange charge light
                                by tccyo22
                                Hi there, I've got a Macbook Pro A1278 board code 820-2936-B in which I have a very strange charging issue.
                                Backstory is when I plugged the charger in, it would give a green light and swap to orange like normal but after a few seconds would go off to no light, laptop still powered on and functioned fine.
                                So naturally I replaced the ISL chip first which made no difference so I also removed and reballed the SMC. This seemed to fix the issue for about an hour until I was back to square one again.
                                Decided to then take an SMC from another board, reball that...
                                04-20-2023, 08:58 AM
                              • mosfetratus
                                macbook A2918, orange light off when shut off
                                by mosfetratus
                                When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
                                Works with battery and charges, but when i shut off i get this problem.
                                It had liquid spill. Board has no corrosion, keyboard is working, power button...
                                05-31-2024, 03:34 AM
