Hi everyone, I have been working on a water damaged 820-00138 ISL6259 was replaced and now have PPBUS_G3H and fan spin without battery plugged in. L7130 measures 16.59V on AC power and 11.03V when on battery on L7130. When plugging in a genuine Apple charger the green light goes on for a brief moment and then turns off. Computer runs fine off battery. Another strange thing is when using a non-official charger the battery does charge. I am at a loss on where to look next. I was suspecting maybe one of the charging mosfets possibly? Q7130 perhaps? I was hoping perhaps someone with a bit better understanding of the charging circuit can point me in the right direction of where I should look next. Any help is much appreciated,
820-00138 Orange Light won't charge
Re: 820-00138 Orange Light won't charge
First of all your current power adapter is that the correct one for your model? Can you confirm for me please what you have.
And also what does your battery status menu report when you have the charger plugged in?Last edited by Simplebeans; 02-19-2022, 12:24 AM. -
What does PPDCIN_G3H measure with a genuine charger? The genuine Magsafe's use a load sense in order to switch through the power. PPDCIN_G3H should measure 0V with no charger plugged in. The load is created by R7012. If you don't have 0V here, then you need to check Q7010 and Q7180.
I've had Q7180 go leaky, so allows battery side volts back through it, which interferes with the load detection of the magsafe. Knock off's don't have this feature so just pump through regardless of load.Comment
Hi Simplebeans thanks so much for the response. Yes it is the correct charger model A1424 85W MagSafe2 adapter. Battery status shows that it is just running on battery only. The green light goes out as soon as I plug in the charger. With the battery unplugged the board will power up and I get fan spin with orange light. The light goes out as soon as the battery is plugged in. No green light either. It seems the charger shuts off completely. Then I have to unplug it for a bit to reset it.Comment
Thank you reformatt, I will check this rail later and report back my findings, thank you for this information it is very helpful!What does PPDCIN_G3H measure with a genuine charger? The genuine Magsafe's use a load sense in order to switch through the power. PPDCIN_G3H should measure 0V with no charger plugged in. The load is created by R7012. If you don't have 0V here, then you need to check Q7010 and Q7180.
Shorted charging rail high-side MOSFET, bad charger IC.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
I think you mean ‘A1398’, ok have you completed a SMC and PRAM/NVRAM reset?Hi Simplebeans thanks so much for the response. Yes it is the correct charger model A1424 85W MagSafe2 adapter. Battery status shows that it is just running on battery only. The green light goes out as soon as I plug in the charger. With the battery unplugged the board will power up and I get fan spin with orange light. The light goes out as soon as the battery is plugged in. No green light either. It seems the charger shuts off completely. Then I have to unplug it for a bit to reset it.
Check the battery connector board side and just make sure everything is ok on the connector and PINS and report back.Last edited by Simplebeans; 02-20-2022, 04:07 AM.Comment
Thanks SimpleBeans, the charger model is a1424 85w charger. The computer is an a1398. I have checked the connector side of the battery and all checks out fine. SMC/NVRAM reset does nothing unfortunately. I am suspecting a bad mosfet as piernov suggested.Comment
So I check R7012 and have 0V, in looking at the schematic though I think you may have meant R7120 which is connected to the two current sense resistors on the ISL chip. Now when I measure this point I have 11V. I think we may be onto something here. I think you may be correct in thinking Q7180 is at fault. I will see if I have a donor board to swap this part out. Keep you posted as to the results. Thanks again for all the help everyone!What does PPDCIN_G3H measure with a genuine charger? The genuine Magsafe's use a load sense in order to switch through the power. PPDCIN_G3H should measure 0V with no charger plugged in. The load is created by R7012. If you don't have 0V here, then you need to check Q7010 and Q7180.
It is R7012 you need to measure this is part of the circuit with Q7010. If you can measure R7012 and report back please?So I check R7012 and have 0V, in looking at the schematic though I think you may have meant R7120 which is connected to the two current sense resistors on the ISL chip. Now when I measure this point I have 11V. I think we may be onto something here. I think you may be correct in thinking Q7180 is at fault. I will see if I have a donor board to swap this part out. Keep you posted as to the results. Thanks again for all the help everyone!Last edited by Simplebeans; 02-25-2022, 01:51 PM.Comment
Thanks ok so that covers the majority of the things it could have been, i think we possibly have left a couple of things to explore here. I need you to do another thing can you also inspect the charging port for any debris and burn marks. I do not think it wil be this anyway because you are getting a green light on occasion but I want to make sure. If you find any debris remove them with tweezers and if there is any marks clean them up, you can use Isopropyl Alcohol (99.9%) and cotton buds. Make it nice and clean and report back please. Remove battery power before doing this.Last edited by Simplebeans; 02-27-2022, 08:12 AM.Comment
by ipatchhello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
by RezendesHello, I have a MacBook 820-3115-B board that never shows an Orange light and goes straight to a green light and turns itself on when the ac adapter is plugged in. System won’t run off battery and turns off immediately when ac power unplugged. I believe the battery should be ok as it was a replacement not too long ago but it’s possible that’s the issue as most anything is possible I guess. I don’t have any spare batteries or donor boards although I have ordered 2 on the way. I have replaced U7000 and same results. I have also applied flux and reflowed the SMC IC and no change. Nothing...
by judamexMacBook Air turns on without battery connected, no green or orange light comes on, I connect the battery and it shows battery with lightning and it restarts constantly.
by tccyo22Hi there, I've got a Macbook Pro A1278 board code 820-2936-B in which I have a very strange charging issue.
Backstory is when I plugged the charger in, it would give a green light and swap to orange like normal but after a few seconds would go off to no light, laptop still powered on and functioned fine.
So naturally I replaced the ISL chip first which made no difference so I also removed and reballed the SMC. This seemed to fix the issue for about an hour until I was back to square one again.
Decided to then take an SMC from another board, reball that... -
by mosfetratusWhen i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
Works with battery and charges, but when i shut off i get this problem.
It had liquid spill. Board has no corrosion, keyboard is working, power button... - Loading...
