Dell LA-G341P No power.
  • macsoftware
    • Jul 2016
    • 25
    • MOROCO
    Re: Dell LA-G341P No power.
    plz help me the file lag341p.brd not workin in openboardview the sofware give this error <there was an error opening the file > can someone have a nother file without password thank you
    • Mbw1a
      • Nov 2018
      • 29
      • Europa
      Apologies for the late reply but have been busy so had to put this aside.
      Bought a similar motherboard on ebay in working condition. but now its dead again..
      wont start up at all no lights. Can someone explain where to start troubleshooting? I'm not so good at schematics.
      thanks in advance
      • Stevedb
        Stevedb
        • Feb 2018
        • 624
        • Belgium
        First you must measure the dcin mosfets for voltage an CSR , then the grey coils for voltages also when you push powerbutton and also resistance with no power , no bios battery and battery and put all the information on hd picture front and back . Then will somebody help you to troubleshoot your board. And also link the shematic, brdview. Upload the shematic/boardview in shematic section and linked here. Succes
        • PantherDave
          by PantherDave
          Hi all!
          I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
          05-29-2024, 02:01 PM
        • Mark01
          Dell Optiplex 7490 AIO - red power led after flash
          by Mark01
          Hi guys,
          This is my first post! ๐Ÿš€
          I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
          Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
          07-04-2025, 12:54 PM
        • zlr8r
          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
          by zlr8r
          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
          Ill try and give as much info as I can.
          Dell Inspiron 17 (7786) Laptop
          Service Tag: 5J0NHT2
          Bios: 1.9.0
          When I received this , it would only flicker on the KB backlight for a second, then off and on.
          Then it started getting weirder!
          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
          12-12-2023, 09:31 PM
        • LimesKey
          Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
          by LimesKey
          Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
          10-17-2025, 05:33 PM
