Macbook A1465 works fine Linux but turns off in MacOS
  • marce002
    • May 2018
    • 316
    • Argentine
    Hello
    I have this macbook Air 11 inch, was working fine with macos,,, then suddenly turns off by itself after apple logo screen.....it cant boot...
    Formating and installing does not work because it also turns off.....
    But: booting linux ubuntu from pendrive and also installing it in ssd works fine!! hours and hours, the macbook runs fine and fast and cool....
    So she does not like MacOS , loves Linux... can this be related to EFI? I have tried booting macos with shift pressed and allow me to login but even in this safe mode it turns off itself with a dialog saying "Are you sure you want to shut down your computer now" but I did not press power off.... now it is worse it does not ask such dialog and turns off...
    Temperature is normal because linux works fine.... no water damage...
    weird very weird issue. any hint?
    Marcelo J
  • reformatt
    • Feb 2020
    • 1399
    Re: Macbook A1465 works fine Linux but turns off in MacOS
    Rule out hardware issues by either running ASD or D from boot. Ubuntu usually runs fine on device with hardware issues in my experience, it's quite forgiving as it just ignores any errors. Apple kexts may result in a panic when defective hardware is initialised.
    • marce002
      • May 2018
      • 316
      • Argentine
      thanks reformatt ,, very clear ...Im gonna run the diagnostic and will report ..
      Marcelo J
      • marce002
        • May 2018
        • 316
        • Argentine
        ok something appears but no google results very precise....
        Hardware Test has detected an error: while
        TESTING MAIN LOGIC BOARD
        4SNS/1/40000001: VPOR-6.894
        run again shows
        4SNS/1/40000001: VPOR-6.854
        and again shows
        4SNS/1/40000001: VPOR-6.840
        Marcelo J
        • marce002
          • May 2018
          • 316
          • Argentine
          ah ok it is the volt at VP0R which is arround 6.8Vol but there is nothing in schematics nor boardview with that name vp0r.... i will test deeply again with the advance test AND CONNECTED TO CHARGER, because stupidly was on battery testing....
          Marcelo J
          • reformatt
            • Feb 2020
            • 1399
            VP0R: PBUS Voltage Sense Enable & Filter, pg40 of the 820-00164 schematic
            • marce002
              • May 2018
              • 316
              • Argentine
              Ok that was not present with AC charger, so plugged it in and retest full extended and now only one error hapened it is:
              4SNS/1/40000000: THSP-69.125
              pass3, and 27mins 41 seconds
              Marcelo J
              • marce002
                • May 2018
                • 316
                • Argentine
                Think it is temperature sensor of SDD.... then Found C7340 broken decapited... i will replace and recheck...and report back... thnks reformatt
                Marcelo J
                • marce002
                  • May 2018
                  • 316
                  • Argentine
                  Replaced that cap C7340 .... BUT NO LUCK.... still restarting during boot.. the coil L7330 is also damaged in its ceramic.... but is connected ok, culprit maybe? ....any other hint? thanks onnadvance
                  Marcelo J
                  • marce002
                    • May 2018
                    • 316
                    • Argentine
                    finally it is a keyboard problem, because disconnected keyboard/touch and used external keyboard and no problem at all....
                    i do not know why ubuntu was working and not turning off anyways....
                    The power key is ok, so again no idea of why it is turning off except that a bad keyboard combination produces the shutdown
                    thanks a lot
                    Marcelo J
                    • Stephen
                      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                      by Stephen
                      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                      03-15-2024, 09:37 AM
                    • tomtom67
                      MacBook Pro 16" (2019) A2141: power consumption? Dead GPU? MacOS not installing
                      by tomtom67
                      A friend brought his fresh-from-ebay macbook pro A2141 after he failed replacement keyboard plugging.
                      I fixed all the little problems he introduced.
                      I am unable to install macOS to this device. Both Sequoia and Catalina (from Internet Recovery) start to install, but after ~2-5 minutes into the installation the macbook does a hard restart (max fan spin for a split second, then reboot without chime).
                      I noticed what I think is a very high power consumption, like 20V/1.7A when activating WiFi for internet recovery, and more like 20V/3.7-4.1A while downloading the recovery...
                      10-08-2024, 08:59 AM
                    • 24gsm
                      MacBook Pro A1708 install macos fail
                      by 24gsm
                      hi to all
                      i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                      after enter to recovery and format hdd 1to .
                      after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                      can help please
                      Serial Number: FVFXP0U0HV2J
                      Config Code: HV2J
                      Find My Mac: OFF
                      04-16-2025, 03:57 AM
                    • Simplebeans
                      Macbook Pro A1708 820-00840-a not completing MacOS install
                      by Simplebeans
                      As some of you may be aware i had recently acquired a liquid damaged Macbook Pro A1708 820-00840-a which was not powering on, power issues sorted and it was down to a shorted capacitor, please see my original thread on this if you would like to find out more (https://www.badcaps.net/forum/showthread.php?t=103060)
                      Now that i have the Macbook Pro powering on i am experiencing a multitude of other suspected problems. Ha.
                      Firstly I’m attempting to install MacOS Monterey using a bootable USB installer. I have formatted the SSD(128GB) as Mac OS Extended (Journaled). Whichever...
                      02-20-2022, 10:52 AM
                    • ryogadan78
                      MacBook Pro 15" A1707 820-00281 turns on once in 10 (or maybe more)
                      by ryogadan78
                      I have this macbook that is behaving abnormally. Initially it had a battery life problem, after changing the battery everything seemed ok, but after about 5 days it started giving problems. It turns on once in 10 (or maybe more), more often after I unplug the battery connector and plug it back in. Sometimes after SMC reset. But it's not a stable rule. Visual inspection shows no problems, no signs of liquid contact or burning. Looking with the thermal camera I notice that the chip that heats up the most is U7220.
                      Any suggestions?​
                      05-24-2025, 04:26 AM
