gl553vd
  • mazenkataya
    • Dec 2021
    • 45
    • lebanon
    gl553vd
    any one can help , this laptop charging working normally ,and white led observed after power button pressed,
    3.0 volt is founded on power button in keybaord
    3.3 volt founded on bios chip
    3.3 &5.0 power system founded any help
    power consumption on power supply 0.03 mili ampere
    new bios file tried the same issue.
    nor cpu neither gpu & chipset get warm after power button pressed.
  • mon2
    • Dec 2019
    • 14001
    Re: gl553vd
    Hi.
    1) Are you using the original power adapter rated @ 120W ?
    2) Laptop is charging normally but consumes 0.03 mili ampere ?
    3) Without the battery, the laptop does not work with the power adapter ?
    See attached.
    With the power adapter connected, measure the voltages on each pin of the charger IC. Post the readings.
    Most likely the fault is in the first 2 mosfets.
    • myth77
      • Feb 2017
      • 380
      • Croatia
      Re: gl553vd
      What is the resistence on chipset? +3VO and 1VO? and do you read voltage?
      • mazenkataya
        • Dec 2021
        • 45
        • lebanon
        Re: gl553vd
        Originally posted by mon2
        Hi.
        See attached.
        the voltage on pin 1 is 19 volt and on pin number 6 is 2.4 volt
        the laptop is 0.03 with battery and without battery and when press power button the white led light up but nothing on display
        • mon2
          • Dec 2019
          • 14001
          Re: gl553vd
          Post the voltage readings on each pin of Q8801 and Q8802 mosfet. Use only the external adapter.
          • mazenkataya
            • Dec 2021
            • 45
            • lebanon
            Re: gl553vd
            please can you point me to the testing pins so that i can measure
            • mazenkataya
              • Dec 2021
              • 45
              • lebanon
              Re: gl553vd
              q8801
              5,6,7,8 =19v
              4=24v
              1,2,3=19v
              q8802
              123=19v
              5,6,7,8,=19
              4=24v
              • mon2
                • Dec 2019
                • 14001
                Re: gl553vd
                Mosfets look good.
                Does this laptop work without the battery but using only the power adapter?
                Is the battery a good battery?
                Any liquid damage?
                Post the voltage on each pin of the charger ic but connect the battery and adapter.
                If the laptop fails to turn on, remove all power and check the resistance to ground of every coil on the board. These are usually grey in color and large parts.
                • myth77
                  • Feb 2017
                  • 380
                  • Croatia
                  Re: gl553vd
                  voltage and resistence please!
                  • mazenkataya
                    • Dec 2021
                    • 45
                    • lebanon
                    Re: gl553vd
                    1v0 have 1.0 volt and resistnace is 0.064(diode mode red on gnd)
                    3v3 have 3.3 volt and resistance is 0.121(diode mode red on gnd)
                    in ohm 1v0 have37.5ohm and 3v3 have 247 ohm
                    notice super i/o on thermal cam have normal temp 24 degree
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      09-06-2024, 05:59 AM
