No Power DAZAARMB6E0 REV E
  • prasath_max
    Technician
    • Feb 2020
    • 33
    • Sri Lanka
    #41
    Re: No Power DAZAARMB6E0 REV E
    since there is no shorts, try a jumper from pin5 of PQ17 to PR8(CMSRC side). Be careful not to connect at VA2 side. Plug your dc again and hopefully you will get 24V at pin4 of PQ17. Report back.
    i got this fault i have motherboard. i bypass VA1 to VA2 side geting Gate votage 24v. directtly i connect dc in not pass throught PQ17 mosfert. try to replace mostfert and charging ic also not solve problam
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      #42
      You didnt followed correctly. I've clearly told not to short between VA1 and VA2. Jumper should be from pin5 of PQ17 to PR8(the side which is connected to pin3 of charging IC and not the other side of PR8). This will bypass the current sensing of Charging Chip. It works on Acer ZAAR/Quanta X12A and many more motherboards. This solution should be used when everything else fails as this is certainly not an ideal solution.
      • eenee
        • Aug 2022
        • 49
        • Mongolia
        #43
        This problem seems to be quite common. It seems to be a simple charger issue. Connect a decent acer charger and 19v will come on.
        • teptronics
          • Sep 2021
          • 19
          • philippines
          #44
          Just replace your charging IC and you're done.. Reply your update here after replacement
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • zaurus81
            Asus TUF Gaming F16 (2024) FX607J no power no ACDRV
            by zaurus81
            Hi all, I have a Asus TUF Gaming F16 (2024) FX607J motherboard with liquid damage. The oxide on the board was removed before giving it to me. This made it more difficult to repair. Also they did not give me the power supply.
            When I connect the 20 volts with the bench power supply I get 4.3 volts on the main power line. If I remove the power sensing resistor I get 20 volts on one side (first 2 mosfets are ok) and 4.3 volts on the main power line (see photo). How is this possible?? I thought the 4.3 volts was coming from the battery mosfet so I unsoldered it and tested it. It is ok too. I...
            11-21-2024, 05:04 AM
            by sam_sam_sam
            03-31-2024, 02:12 PM
            09-06-2024, 05:59 AM
