No Power DAZAARMB6E0 REV E
  • kalilinux25
    • Mar 2018
    • 2069
    • ZAMBOANGA SIBUGAY
    Re: No Power DAZAARMB6E0 REV E
    ACN- 5.7V stable
    ACP- 5.7V stable
    CMSRC -5.7V stable
    ACDRV- 5.7V stable
    ACOK -0V
    ACDET - 2.7V stable
    IADP -0V
    IDCHRG- 0V
    PMON-0V
    PROCHOT-0V
    ILIM-0V
    LDODRV-0V
    PHASE-0V
    HIDRV-0vV
    BTST-5.6V
    REGN- 6V
    • kalilinux25
      • Mar 2018
      • 2069
      • ZAMBOANGA SIBUGAY
      Then check requirement of 3V/5V regulator.
      PU7
      TPS51225RUKR
      pins with voltage reading only
      PIN3 - VREG3 -3.2V
      PIN9- VBST2 2.2V
      PIN12 VIN -5.8V
      PIN17- VBST1-2.2V
      ALL OTHER PINS has no VOLTAGES ZERO values
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Originally posted by kalilinux25
        PU7
        TPS51225RUKR
        PIN3 - VREG3 -3.2V
        PIN9- VBST2 2.2V
        PIN12 VIN -5.8V
        PIN17- VBST1-2.2V
        When the vin is at 5.8V, do you think IC will work. Inject 19V on CLR directly and then measure TPS51225 pins. that will make sense. On injecting 19V on CLR, you must get 3V on coil. If you are still not getting 3V on coil, there lies the problem. BQ24780/S will never work if there is any issue with 3V rail. I've already given you these inputs, why not work on them. It should'nt take 10-15 days to repair a board unless you are stuck for want of spares.
        • kalilinux25
          • Mar 2018
          • 2069
          • ZAMBOANGA SIBUGAY
          MY bq24780s is getting hot
          • kalilinux25
            • Mar 2018
            • 2069
            • ZAMBOANGA SIBUGAY
            what do you mean by CLR sir ?
            • kalilinux25
              • Mar 2018
              • 2069
              • ZAMBOANGA SIBUGAY
              #26
              ACN- 19v stable
              ACP- 19v stable
              CMSRC -19v stable
              ACDRV- 19v stable
              ACOK -0V
              ACDET - 1.2V stable
              IADP -0V
              SDA-3.2V
              SCL-3.2V
              IDCHRG- 0V
              PMON-0V
              PROCHOT-0V
              ILIM-0V
              LDODRV-0V
              PHASE-0V
              HIDRV-0vV
              BTST-5.6V
              REGN- 5.9V
              pump voltage at PR188
              • kalilinux25
                • Mar 2018
                • 2069
                • ZAMBOANGA SIBUGAY
                #27
                ACOK -0V testing the PR30 100K value outboard. PR195 correct outboard
                ACIN PIN 2 PR30 has 2.9v
                REGN-PIN 1 PR30 5.9V
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #28
                  You injected 19V on CLR and BQ24780S getting hot. Right?? So Charging IC is likely to be bad.Was 3VALW available on coil when 19V was injected on CLR(Current Sensing Resistor)??
                  • kalilinux25
                    • Mar 2018
                    • 2069
                    • ZAMBOANGA SIBUGAY
                    #29
                    Nope no voltage on 3v coil and 5v coil. I already change the charger ic
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #30
                      Inject 19V on CLR, then measure voltage on all pins of TPS51225 and post here. Have you replaced TPS51225??
                      • kalilinux25
                        • Mar 2018
                        • 2069
                        • ZAMBOANGA SIBUGAY
                        #31
                        PU7
                        TPS51225RUKR
                        PIN3 - VREG3 -3.2V
                        PIN9- VBST2 2.2V
                        PIN12 VIN -19V
                        PIN17- VBST1-2.3V
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          #32
                          Vreg5 not there?? Resistance on vreg5 pin??
                          • kalilinux25
                            • Mar 2018
                            • 2069
                            • ZAMBOANGA SIBUGAY
                            #33
                            39koms
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              #34
                              Inject 5V on vreg5 pin and see the consumption on dc supply. Anything getting mildly hot?? You should'nt use adapter/battery while injecting 5v on vreg5 pin. If things are normal, replace the 51225 IC. You must get 3V/5V Ldo working.
                              • kalilinux25
                                • Mar 2018
                                • 2069
                                • ZAMBOANGA SIBUGAY
                                #35
                                nothing getting hot jst taking 1 miliamp every seconds goes 0amp
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  #36
                                  Then why not replace TPS51225 and see if LDO lines are working or not??
                                  • kalilinux25
                                    • Mar 2018
                                    • 2069
                                    • ZAMBOANGA SIBUGAY
                                    #37
                                    Iwaa waiting for this type of ic sir order time
                                    • dinosglxaros
                                      • Nov 2016
                                      • 55
                                      • greece
                                      #38
                                      hello i have a similar problem with this motherboard, but when i make a jumper of pq17 from pin 5 to va2 the laptop works..is it ok to leave it with that jumper?
                                      • kalilinux25
                                        • Mar 2018
                                        • 2069
                                        • ZAMBOANGA SIBUGAY
                                        #39
                                        The battery wont charge
                                        • kandyan
                                          • Mar 2013
                                          • 53
                                          • Sri Lanka
                                          #40
                                          since there is no shorts, try a jumper from pin5 of PQ17 to PR8(CMSRC side). Be careful not to connect at VA2 side. Plug your dc again and hopefully you will get 24V at pin4 of PQ17. Report back.
                                          I have the same symptom motherboard and I have changed the BQ24780S and PQ17 MOSFET with no success.
                                          After I have made a jumper between pin5 and CMSRC side motherboard was turned on but not charging if i plugged in the battery. What might be the problem please?
                                          • ResoluteHawk
                                            Quanta 0P5 (DA0P5HMB8E0-Rev E) Missing ACDRV
                                            by ResoluteHawk
                                            I have an HP 15-DY laptop in because the battery is not charging.
                                            If I use a charged battery, the laptop powers on but the battery will not charge, however the orange charge light does turn on. The laptop loses power as soon as I disconnect the battery.
                                            I've replaced the BQ247 chip with a known working one and I get the same issue and the same measurements.
                                            Measurements are as follows:
                                            BQ728 IC
                                            VCC (Pin 20) => 19V
                                            CMSRC (Pin 3) => 0.8V (This is a problem but I can't figure out what's causing the low voltage)
                                            ACDRV (Pin...
                                            04-10-2025, 11:36 AM
                                          • elsomer
                                            Acer nitro 5 bq24781 no acdrv
                                            by elsomer
                                            Hi people, i have an acer nitro 5 with motherboard model gh51m la-k861p , it came with the resistor pr103 blow up, i repaced that resistor, i check the coils plb2, pl301, pl501 and has no short to ground, i conect the charger and it doesnt power at all, i check pqb3 on pin 5 to 8 and its 19v, pin 1 to 4 its 0
                                            so i repaced, pqb3, pqb4, and makes no change, still no acdrv, i replaced bq24781 and makes no change, still no acdrv, if someone can help pls, thanks, this are the schematic and boardview
                                            [MOD EDIT] LINK to schematic & boardview -> https://www.badcaps.net/forum...
                                            04-22-2024, 11:30 AM
                                          • mkdj
                                            MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                            by mkdj
                                            About me, my goal and the equipment I (don't) have:
                                            I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                            About my issue and my goal:
                                            A friend of mine has a MacBook Air M1 A2337 that does not...
                                            04-03-2025, 08:28 AM
                                          • zaurus81
                                            Asus TUF Gaming F16 (2024) FX607J no power no ACDRV
                                            by zaurus81
                                            Hi all, I have a Asus TUF Gaming F16 (2024) FX607J motherboard with liquid damage. The oxide on the board was removed before giving it to me. This made it more difficult to repair. Also they did not give me the power supply.
                                            When I connect the 20 volts with the bench power supply I get 4.3 volts on the main power line. If I remove the power sensing resistor I get 20 volts on one side (first 2 mosfets are ok) and 4.3 volts on the main power line (see photo). How is this possible?? I thought the 4.3 volts was coming from the battery mosfet so I unsoldered it and tested it. It is ok too. I...
                                            11-21-2024, 05:04 AM
                                          • pc_okay
                                            Battery not charging ideapad 3-15ITL6 after shortage repair
                                            by pc_okay
                                            Hello guys,
                                            I have this laptop coming for not starting at al.
                                            There was a shortage on a condo on B+ circuit near PJ100. (please find shematic attached) Link to schematic --> https://www.badcaps.net/forum/troubl...08#post1754008
                                            Problem solved by removing it.
                                            But now the laptop is not charging... It's working on battery and/or without charger perfectly.
                                            The led charge is orange...
                                            09-19-2024, 08:30 AM
