820-02016 No Power, 5v 0.00amps as
  • oemelectronic
    • Sep 2019
    • 33
    • peru
    Hi Dear
    How Are Friends Help..
    this model New Macbook Air T2 820-02016A
    No Power, 5v 0.00 amps as
    PPBUS_AON : 1.05 VOLT
    PP3v8_AON_VDDMAIN : 0 VOLT
    P1V8_S2 : 0.13VOLT
    PPBUS_USBC0 : 5 VOLT.
    suspect IC : ISL940HI IC or CD 2317 ?
    thanks
  • mon2
    • Dec 2019
    • 14660
    Re: 820-02016 No Power, 5v 0.00amps as
    Check each one of the fuses:
    (remove all power / no battery)
    Meter in resistance mode (2k is ok)
    Check resistance with meter across each such fuse.
    FF200
    FF201
    Update:
    You have some voltage so the fuses may be ok.
    1) Locate L8230. Meter in resistance mode. Remove all power. Check & post the resistance to ground for L8230, pin # 1.
    • oemelectronic
      • Sep 2019
      • 33
      • peru
      FF200
      FF201
      Update:
      Bro Mon2
      Fuses Meter in resistance mode (2k is ok) : i have 130k (direct - reverse)
      Bobina L8230 : I Have 9.70k -23k ((direct -reverse)
      thanks
      • mon2
        • Dec 2019
        • 14660
        Hi. Looks ok.
        What is voltage at L8230 ?
        • oemelectronic
          • Sep 2019
          • 33
          • peru
          hi. Looks ok.
          What is voltage at l8230 ?
          pp3v8_aon_vddmain : O volt
          • oemelectronic
            • Sep 2019
            • 33
            • peru
            HI Dear
            i change Ic 5200 new ISL9240HL SAME
            PP3v8_AON: 0 VOLT
            What is First? PPBUS_AON or PP3v8_AON
            thanks
            • mon2
              • Dec 2019
              • 14660
              it will be PPBUS_AON - mosfet @ Q5800 which uses this rail to step down to create PP3V8_AON.
              On this note, remove all power / no battery.
              Meter in resistance mode (2k scale is ok).
              Measure & post the resistance to ground of PPBUS_AON (fuse F5200, pin #2).
              • oemelectronic
                • Sep 2019
                • 33
                • peru
                Brother Mon2
                Pin 2 fuse 5200 to Gnd
                4.6k direct
                200k reverse
                • mon2
                  • Dec 2019
                  • 14660
                  Update.
                  You have a bad voltage @ PPBUS_AON but do not have a short ?
                  Do the following:
                  Remove all power.
                  Flux & remove fuse F5200 off the logic board. Keep it off the board for now.
                  Allow for the board to cool.
                  Without power, meter in resistance mode.
                  Check & post the resistance to ground for:
                  F5200, pin #1 pad on the logic board (provider)
                  F5200, pin # 2 pad on the logic board (consumer)
                  We need to know which side of the FUSE is the short circuit on the logic board.
                  Is it the provider (U5200 = ISL9240) or the consumer side ?
                  Post your measurements without the fuse.
                  After this, power up again and measure the voltage of PPBUS_AON. The issue may be a defective ISL9240 but need to check a few more points on this IC.
                  • oemelectronic
                    • Sep 2019
                    • 33
                    • peru
                    Dear
                    Same 4.8k loading and unloading pin2
                    same 5k loading and unloading pin1
                    NOT HAVE :
                    CHGR_RST_IN: 0 Volt.
                    I2C_SMC_PWR_1V8_SCL : 0 Volt
                    I2C_SMC_PWR_1V8_SDA : 0 volt
                    • Wachenaggo
                      • Jul 2018
                      • 66
                      • Philippines
                      did you fix it?? i have similar issue
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                        Using a 5 volt @ 12 amp switching power supply and two USB doctor volt / amp meter to three IPads on one power supply
                        by sam_sam_sam
                        I have been wanting to do this project for some time using a Mean-well switching power supply that I bought at least ten of them that were originally in a device that was abandoned for some reason they were listed new but removed from equipment that was never used
                        I do not understand Mean-well the capacitor next to the voltage reference ic chip was a brand that is known for failure over time the other capacitors are brand name needless to say it got replaced before I even powered it on for the first time
                        I used a four USB outlet and electrical plate that is made for...
                        08-03-2024, 07:54 PM
