CMOS battery replacement on Medion Akoya P2212T
  • paparazzo79
    • Dec 2018
    • 299
    • Bosnia
    Hi guys.
    I purchased this laptop from a guy but sadly he sold me with an eror when I boot up I get a meesage with time and date incorrect
    I suppose it has to do with bad BIOS battery.
    Now I did purchase new CR1220 battery and want to replace it because I don't have anyone to do the job for me.
    I think I have all the necessary tools for it.
    Does it look too complicated for a newbie like me?
    Thoughts?
    Problem is that I don't have whole stuff this protection around battery and these 2 metal pieces,nor I can order from e-bay.
    I just bought brand new CR1220 battery and that is it.
    How do I make all this with brand new battery (this "black protection" and metal pieces on the bat).
    https://www.youtube.com/watch?v=Chfo6iBPbSI&t=988s
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: CMOS battery replacement on Medion Akoya PP212T
    https://www.google.com/search?q=medi...uhr6qBcbXZ8LNM
    • paparazzo79
      • Dec 2018
      • 299
      • Bosnia
      Sorry cant order.
      Shipment +50 euros for my country..
      Can I somehow use just battery without this "shell, or use shell from older battery?
      • diif
        • Feb 2014
        • 6978
        • England
        You need a new CR1220 that has battery tabs spot welded to it, then you can remove the old wire and connector and solder it to the new battery.
        • petehall347
          • Jan 2015
          • 4427
          • United Kingdom
          https://electronic.ba/proizvod/44542...032-mitsubishi
          • paparazzo79
            • Dec 2018
            • 299
            • Bosnia
            Thank you bro but I need CR1220 not this one.
            I will contact this store anyway to check.
            • petehall347
              • Jan 2015
              • 4427
              • United Kingdom
              it should work if it will fit the space .both 3 volts
              • paparazzo79
                • Dec 2018
                • 299
                • Bosnia
                I've contacted local store miles away and the only battery they could order is this one and need to wait approx 2 weeks.
                Will this one do the job?
                CR1220/HFN PANASONIC
                Batterie: Lithium; 3V; CR1220, Ø12x2mm
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  yes that should do it
                  • Stevedb
                    Stevedb
                    • Feb 2018
                    • 624
                    • Belgium
                    Hi you can it buy on ebay no problem from germany or so. 4.95 euro + 5,95euro shipping no problem.
                    https://www.ebay.com/itm/124250858060?_ul=BE
                    • paparazzo79
                      • Dec 2018
                      • 299
                      • Bosnia
                      Real Time Clock Error at Boot
                      Hi guys.
                      I purchased used laptop from a local seller but when I turn it ON I get this error.
                      I can boot to Windows but having issues with incorrect time and date and can't connect to internet
                      How do I resolve this issue with time?
                      Would just replacing CMOS battery do the job?
                      • mon2
                        • Dec 2019
                        • 14247
                        Re: Real Time Clock Error at Boot
                        Yes.
                        Locate the coin cell battery - often it is the CR2032 style but designs do change so review it. Once the battery is replaced, enter the CMOS setup and update the date to be current. Then the parameters should stick and this error will be resolved.
                        If in doubt, share pics of the battery.
                          • 20984
                          Originally posted by paparazzo79
                          Hi guys.
                          It might help if we knew what the make and model is.Please also add the model number to your thread title in future.
                          • paparazzo79
                            • Dec 2018
                            • 299
                            • Bosnia
                            Actually there is a video on yt how to replace the battery.
                            I ordered one,just want to know if replacing will resolve the issue?
                              • 20984
                              You`ll know when you replace the battery,it will or it won`t. Ive already asked you for the make and model number, if you don`t want to post it thats fine. Its possible the model could have some known problem with the RTC circuit
                              • paparazzo79
                                • Dec 2018
                                • 299
                                • Bosnia
                                [QUOTE=SMDFlea;1100155]You`ll know when you replace the battery,it will or it won`t. Ive already asked you for the make and model number, if you don`t want to post it thats fine. [B]Its possible the model could have some known problem with the RTC circuit
                                /QUOTE]
                                Medion Akoya P2212T.
                                If that is the case then replacing battery won't resolve the issue?
                                  • 20984
                                  Ive merged both of your Akoya P2212T threads....
                                  • paparazzo79
                                    • Dec 2018
                                    • 299
                                    • Bosnia
                                    Re: CMOS battery replacement on Medion Akoya P2212T
                                    Could this issue relate to discharging laptop battery when laptop is OFF?
                                    • paparazzo79
                                      • Dec 2018
                                      • 299
                                      • Bosnia
                                      Ok,finally battery will arrive tomorrow.
                                      But I noticed one more issue with this laptop,and that is that battery discharges when laptop is switched off.
                                      Anyway,after replacing the CMOS battery,I would get anymore warning info at boot with CMOS error,press F1 to resume...etc...?
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                        MEDION AKOYA E2016 F AKOYA i3-6100 Specification for Upgrade or Repair
                                        This specification for the MEDION AKOYA E2016 F can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the AKOYA E2016 F boardview and AKOYA E2016 F schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                                        09-12-2024, 02:20 PM
                                        MEDION AKOYA P62005 AKOYA i5-8400 Specification for Upgrade or Repair
                                        This specification for the MEDION AKOYA P62005 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the AKOYA P62005 boardview and AKOYA P62005 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                                        MEDION AKOYA P66087 AKOYA i5-9400F Specification for Upgrade or Repair
                                        This specification for the MEDION AKOYA P66087 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the AKOYA P66087 boardview and AKOYA P66087 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                                        09-12-2024, 02:15 PM
                                        MEDION AKOYA P5301 J AKOYA i5-7400 Specification for Upgrade or Repair
                                        This specification for the MEDION AKOYA P5301 J can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the AKOYA P5301 J boardview and AKOYA P5301 J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
