Works screen 15"A1707 on motherboard 13"A1706
  • Beeldbuisje
    • Jul 2020
    • 57
    • Belgium
    I have a Macbook pro A1706 with 820-00923 board. No Apple logo, nothing else.
    Every power source is present, laptop has fallen down from a table, no visible damage.
    Starts with 20V 830mA, after 10 seconds it becomes +/- 590mA steady. CPU gets hot after a while, fans starts to spin. You can switch it on/off by holding touch id/power button.
    Probably bad contacts on CPU so Reballing adviced?
    To exclude a bad screen, is it possible to connect this mainboard on a screen of a A1707 with 820-00928 board?
    Gert
  • Archimedes
    HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
    by Archimedes
    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
    Fans are spinning. Blindly could install windows11 and got the device manager...
    07-30-2024, 05:14 PM
  • Yehuda170
    ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
    by Yehuda170
    original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
    replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
    now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
    with original broken screen i can see in device manager touch screen in human interfaces
    but with the new screen it's not showing in device manager
    is it lenovo blocking it? is it driver missing?
    I²C is a headache
    07-14-2023, 01:29 AM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • Ado02
    MacBook Pro A2159 - No Display / Works on External Screen
    by Ado02
    I am working on a MacBook that came in for a screen replacement. The MacBook powers on and works on the external screen. However, the screen stays black. The replacement screen made no difference. On further investigation, I found small amounts of corrosion.
    Please see the attached image.
    I ordered a refurbished logicboard, but the problem didn't go away with the old or replacement screen.
    Can anyone suggest where to go from here?...
    01-12-2023, 03:35 AM
