DELL g3 15 cal53 la-f611p rev:1.0
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    The laptop was working but after replacing the keyboard it wont display fan spins fast after that it will turn off.. errro light 3 orange 1 white.. It says CMOS FAILUTRE. It has no display I already tried removing the cmos and replace a new one and tried a new ram.
    I check the voltage of the JI0B1 pin 11
    RTC_VCC is present ,
    What to look next?
  • mon2
    • Dec 2019
    • 14210
    Re: DELL g3 15 cal53 la-f611p rev:1.0
    What are the details of the replacement keyboard ? Using a FPC cable ?
    Were the proper # of contacts and pad pitch used for the replacement cable ?
    Remove the keyboard and test again.
    Post pictures of the original keyboard cable and the replacement keyboard cable to review the contacts of each.
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      Originally posted by kalilinux25
      I already remove the board out of the case
      the first is the new one the second is the old one, they are the same kb.
      • age80
        • Jun 2013
        • 55
        • Greece
        Putting the old back has the same behaviour?
        Did you remove the battery when changing keyboard?
        Does it has an EC that is programmable?
        *just saw it has a MEC 1416 (i think non-programmable)
          • 20914
          Why was the keyboard replaced,why wasn`t it working and when did it stop working.Did it stop working suddenly after a bios update.
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            Without the old keyboard plugg same problem.. Do I need the keyboard just to poweron the laptop?
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              Keyboard wasnt working because some letters are not working.. Before replacing the kb I test it first and everything are working no issue but after changing the keyboard and plugging all the parts it womt display rtc failure error
                • 20914
                Did you remove the main battery before trying the new keyboard.Do you have +1.8VALWP
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  Yes I always do that begire chnaging battery because for safety.
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    Ill get back tommorow and test all voltages and post what voltages should I test?
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • valente222
                      DELL Inspiron Mb FDI55 LA-J081P REV 1.0 A00 error batery CMOS
                      by valente222
                      Hello everyone, I have this DELL computer. problem when turning on it does not show an image. Diagnostic LED indicates CMOS battery failure. I measure the battery and 3v is fine. When turned on with battery CMOS consumption of 240mA. By removing the CMOS battery it can consume 800mA and sometimes gives an image when it wants. This happened after a while of installing an SSD. Will ME be corrupted by Windows?...
                      03-15-2024, 10:28 AM
                    • diamon
                      Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                      by diamon
                      I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                      Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                      Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                      Pictures of these boards:
                      Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                      Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                      Dell...
                      02-28-2024, 12:51 PM
                    • master3112
                      by master3112
                      07-29-2025, 01:55 PM
                    • OntarioTL
                      Dell 5410 greyed out BT
                      by OntarioTL
                      Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                      If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                      Dell Lattitude 5410
                      Service Tag...
                      07-25-2025, 01:28 PM
