HP 250 G5 / BDL50 LA-D704P missing ACOK
  • eniac22
    • Jun 2012
    • 125
    • Greece
    Hi i have problem with HP 250 G5 / BDL50 LA-D704P no power / no light on charger led, the same problem with charged battery.
    I measured the following voltages with charger and without battery, i believe voltages is correct except ACOK.
    Pin 1 ACN : 19,4V
    Pin 2 ACP : 19,4V
    Pin 3 GMSRC : 19,4V
    Pin 4 ACDRV : 25,2V
    Pin 5 ACOK : 0V
    Pin 6 ACDET : 2,6V
    Pin 7 IOUT : 0V
    Pin 8 SDA : 0V
    Pin 9 SCL : 0V
    Pin 10 ILIM : 0V
    Pin 11 BATDRV : 0V
    Pin 12 SRN : 3,1V
    Pin 13 SRP : 3,1V
    Pin 14 GND : 0V
    Pin 15 LODRV : 0V
    Pin 16 REGN : 6V
    Pin 17 BTST : 5,8V
    Pin 18 HIDRV : 3,1V
    Pin 19 PHASSE : 3,1V
    Pin 20 VCC : 19V
  • mon2
    • 14720
    Re: HP 250 G5 / BDL50 LA-D704P missing ACOK
    Also, pins 8 & 9 are floating. This implies your always on rail is not working.
    Trace the pull up resistors to the always on rail and confirm that voltage rail is enabled. You could have a bad cap on that rail. A very common fault.
    The ACOK likely is also pulled up to the same faulty rail so is showing 0v.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      +3V LDO is missing as @mon2 has advised. Findit out and check resistance on +3V LDO.
      • eniac22
        • Jun 2012
        • 125
        • Greece
        +3V LDO produced from PU2 (RT8243AZQW) ? if so i get this values on PU2
        Pin 11 VIN: 19,5V
        Pin 12 ENLDO : 4,48V
        all other pins has 0V
        • mon2
          • 14720
          Post the voltage on pin #15 (+3VL) of PU2.
          From your last post, PU2 may be defective.
          Remove all power. Measure the resistance to ground of pin 15 on PU2.
          • eniac22
            • Jun 2012
            • 125
            • Greece
            All pins of PU2 have 0 volt exept pin 11 and pin 12, so the pin 15 has 0V.
            Resistance to ground of pin 15 when i measure after remove the power supply is 0 ohm and if i measure after a while the resistance is 66,7κohm
            • eniac22
              • Jun 2012
              • 125
              • Greece
              I replace PU2 (RT8243A) and now i have white led on the charger cable but the laptop not power on after i press the power button.
              PU201:
              Pin 1 ACN : 19,48V
              Pin 2 ACP : 19,48V
              Pin 3 GMSRC : 19,45V
              Pin 4 ACDRV : 25,1V
              Pin 5 ACOK : 3,2V
              Pin 6 ACDET : 2,63V
              Pin 7 IOUT : 0V
              Pin 8 SDA : 3,27V
              Pin 9 SCL : 3,27V
              Pin 10 ILIM : 0,45V
              Pin 11 BATDRV : 3,15V
              Pin 12 SRN : 3,13V
              Pin 13 SRP : 3,14V
              Pin 14 GND : 0V
              Pin 15 LODRV : 0V
              Pin 16 REGN : 6,08V
              Pin 17 BTST : 5,86V
              Pin 18 HIDRV : 3,14V
              Pin 19 PHASSE : 3,14V
              Pin 20 VCC : 19,16V
              PU2:
              Pin 1 FB1 : 0V
              Pin 2 ENTRIP1 : 0V
              Pin 3 TON : 0V
              Pin 4 ENTRIP2 : 0V
              Pin 5 FB2 : 0V
              Pin 6 PGOOD : 0V
              Pin 7 BOOT2 : 0V
              Pin 8 UGATE2 : 0V
              Pin 9 PHASE2 : 0V
              Pin 10 LGATE2 : 0V
              Pin 11 VIN : 19,48V
              Pin 12 ENLDO : 4,47V
              Pin 13 ENIM : 0V
              Pin 14 LDO5 : 5V
              Pin 15 LDO3 : 3,27V
              Pin 16 LGATE1 : 0V
              Pin 17 PHASE1 : 0V
              Pin 18 UGATE1 : 0V
              Pin 19 BOOT1 : 4,55V
              Pin 20 BYP1 : 0V
              • mon2
                • 14720
                There are a lot of 0V on PU2. The issue may be linked to pin #13 of PU2 which mates with the EC and believe that EC_ON is a digital GPIO enable pin. Inside the EC is usually a 8051 microcontroller that requires firmware to perform its task. No experience with the EC reprogramming so wait on others to reply with their feedback.
                Details of PU201 are looking very good.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Yes, EC_ON comes from SIO and it enables the 3/5V regulator. Could be bad sio,bad dc jack,bad ec firmware, rtc section fault.
                  • razadom
                    • Apr 2015
                    • 105
                    • Madagascar
                    Hi all
                    I have the same problem after changing cpu mosfet and controller.
                    Before the laptop go on but no voltage on cpu and vgt coil.
                    I have reprogrammed bios also
                    So i think the same as you propose that the ec must be reprogram
                    If someone has idea share please
                    • tecnicojr
                      • May 2022
                      • 0
                      • nueva loja
                      I have a similar case in the line of three marks a resistance of 24.3 with respect to ground
                      • mon2
                        • 14720
                        Tengo un caso similar en la linea de tres me marca una resistencia de 24.3 con respecto a tierra
                        • bridges_4u
                          DK10FG-6050A2491301-MB-A03 missing ACOK
                          by bridges_4u
                          Hi there,
                          I have a DK10FG-6050A2491301-MB-A03 motherboard with missing ACOK voltage. Here are the basic voltages of BQ24725A. The motherboard is dead with no signs of life.
                          ACN : 19.35V
                          ACP : 19.36V
                          ACDET : 2.7V
                          REGN : 5.916V
                          VCC : 19.36V
                          Diode mode to ground reading on ACOK rail is 0.450V on pin 1 of R6013 and 0.230V at pin 2. Replaced BQ24725A a couple of times. Still no luck.
                          The problem was that I was not having 3.3V/5V from the TPS51225 regulator. So I tracked down to the BQ24725A which was missing the ACOK voltage...
                          07-21-2024, 12:34 PM
                        • benjas11
                          BQ24780S (acok missing)
                          by benjas11
                          Hello everyone, I need your help. I'm having issues with a Lenovo motherboard. When I plug in the charger, there's no current consumption. However, the laptop works if I bypass the charger IC by applying 20V directly to the main resistor. I checked the voltages at the charger IC and found that ACOK (AC OK signal) is missing, and ACDRV (AC Drive) isn't sending voltage to the gates. I've searched for shorts but found none. I replaced the charger IC three times, but ACOK remains around 0.24V–0.35V. The MOSFETs test fine. If anyone has encountered this issue, I'd appreciate your advice.​
                          05-21-2025, 01:18 PM
                        • ugamazing
                          820-02020 PPBUS_AON missing
                          by ugamazing
                          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                          02-05-2025, 04:21 PM
                        • jpreza
                          Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                          by jpreza
                          I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                          Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                          It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                          Looking at the card, it appears to be missing the following:
                          1x 1.0uH inductor - orange square
                          2x...
                          11-01-2024, 10:54 PM
                        • BYTEHAT248
                          Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
                          by BYTEHAT248
                          Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
                          Today, 04:48 PM
