Couldnt Boot Laptop HP 14-bw087tu
  • ndarjo21
    • Nov 2021
    • 77
    • Indonesia
    I have a laptop HP 14-bw087tu with motherboard type DA00P2MB6D0. This laptop before i change the keyboard is normal. when i change the keyboard, the keyboard almost flat with the surface of touchpad board but the laptop still work fine. after that, i give thick paper between the keyboard and the plat below the keyboard, but it become bulked when i assembly all of part the laptop. i dont try turn on the laptop that time so i dont know the laptop is normal. then i remove that thick paper, and assembly all of the laptop part. when i try to turn on, the laptop not even start, fan not spinning and no harddisk spin or heat in processor. i have reprogram the bios with eeprom programmer. i have try resetting cmos with all general step before reprogram the bios. but the problem still exist. i have check when ac adapter plugged in, the voltage is exist in the PGOOD northbridge chip. The northbridge chip is RT3662AC. i have remove ram but still same, i have change with another ram from other laptop but still same, i have change the slot of ram but still same. i have check cmos battery is 3 volt. have tried just connect dc adapter, power switch and external monitor use vga socket but still same. Can anyone here help me to solve this problem or ever meet the same problem?
  • ndarjo21
    • Nov 2021
    • 77
    • Indonesia
    Re: Couldnt Boot Laptop HP 14-bw087tu
    when i test my bios chip use multimeter, i found that VCC, SIO3 and SCLK connected together, i see in the boardview and the datasheet of bios chip which is MX25L6473F, that three of that pin connect to different capacitor and resistor. can this prevent the laptop to boot?
    • ndarjo21
      • Nov 2021
      • 77
      • Indonesia
      what equivalent part of MX25L6473F bios chip? can i use slower clock speed ie 10g. my bios chip is MX 25L 6473F m2 I 08g.
      • Stevedb
        Stevedb
        • Feb 2018
        • 622
        • Belgium
        Tes you can, you can see in the vcsa table og the biosdump, which ic are compatible.
        • ndarjo21
          • Nov 2021
          • 77
          • Indonesia
          I have look in the macronix datasheet comparation, it says that mx25L6437F is compatible backward with another mx25L64xxE. So i check the bios pin in board view and that exact same with the mx25L6406E. Difference of that ic just the speed. So i will buy that ic and try it, because mx25L6406E can buyed without import from china. Thanks for your reply
          • Stevedb
            Stevedb
            • Feb 2018
            • 622
            • Belgium
            You can also use winbond winbond 25Q64FVSIQ if i remember you can it also see in chematic i think the replacement orin the biosdump itself.
            • ndarjo21
              • Nov 2021
              • 77
              • Indonesia
              thanks again, i will try if the first ic replacement didnt work, cause the mx6406 ic just 0.5 USD. but the winbond chip also still cheap, just 1 usd. can you give me the schematic? cause i only have the boardview. what apps to read biosdump? is bios dump is the bin file? i am newbie so i dont know so much about this. but it is right, when the bios ic shorted the leg internal it can prevent motherboard to turn on?
              • Stevedb
                Stevedb
                • Feb 2018
                • 622
                • Belgium
                Hi
                I hope this is the right shematic.
                Good luck
                Steve
                • ndarjo21
                  • Nov 2021
                  • 77
                  • Indonesia
                  Hi
                  Good luck
                  Steve
                  i think the schematic is right, i just need to learn how to read schematic. thank you so much
                  • Stevedb
                    Stevedb
                    • Feb 2018
                    • 622
                    • Belgium
                    No problem what i woult do make a high resolution pictures with the voltage on every coil and the resistance to ground with no power, no bios battery , no ram and post it here. Then can someone help you here.
                    • ndarjo21
                      • Nov 2021
                      • 77
                      • Indonesia
                      The resistance to ground of each coil i see is here.
                      PL11 0.926k ohm 1R0
                      PL7 14.76k ohm 1R5
                      PL9 58.95K ohm 2R2
                      PL15 48.2 ohm 1R0
                      PL46 10.25 ohm R22
                      PL44 20.3 ohm R22
                      should i check the voltage too? with only dc adapter?
                      • ndarjo21
                        • Nov 2021
                        • 77
                        • Indonesia
                        i dont have good camera so i couldnt take a high resolution photo of the mainboard
                        • ndarjo21
                          • Nov 2021
                          • 77
                          • Indonesia
                          and my eeprom programmer is ezp2019+. when i try to flash another laptop bios, which is winbond but with 1.8 v vcc, when i write it always corrupt. so i will buy CH341A eeprom programmer to flash the ic bios which have 3 volt vcc
                          • ndarjo21
                            • Nov 2021
                            • 77
                            • Indonesia
                            PL11 0.926k ohm 1R0
                            PL7 14.76k ohm 1R5
                            PL9 58.95K ohm 2R2
                            PL15 48.2 ohm 1R0
                            PL46 10.25 ohm R22
                            PL44 20.3 ohm R22
                            i had flash the bios ic, and i think it make good bios, not corrupted when verify, i also compare the binary file and it says identic. i have test the coil.
                            when i plug dc adapter, the 4R7 show 3,12 volt which is PL5, all other coil read 0 volt. when i press the power button, the 4r7 still show 3,12 volt. the 1R5 show 3.3 volt and 2R2 show 5 volt. all 1R0 and R22 show almost zero volt
                            • ndarjo21
                              • Nov 2021
                              • 77
                              • Indonesia
                              i thought the damaged component is the kbc ENE KB9027Q C because the 0 volt coil enable or mainon from that kbc.
                              • ndarjo21
                                • Nov 2021
                                • 77
                                • Indonesia
                                can i use motherboard HP PAVILION 240 G6 in hp 14-bw087tu. that laptop have the same type which is DA00P2MB6DO REV
                                • ndarjo21
                                  • Nov 2021
                                  • 77
                                  • Indonesia
                                  hello all, can i get ec for DA00P2MB6D0
                                  • Stevedb
                                    Stevedb
                                    • Feb 2018
                                    • 622
                                    • Belgium
                                    I think you probably can if it has the same boardnumber. For 1,8 v chip to program you need 1,8v adapter board..
                                    € 1,99 11%OFF | 1.8V Adapter Voor Moederbord 1.8V Spi Flash SOP8 DIP8 W25 MX25 Gebruik Op Programmeurs TL866CS TL866A EZP2010 EZP2013 EZP2019 CH341A
                                    https://a.aliexpress.com/_mN3CvPA
                                    • ndarjo21
                                      • Nov 2021
                                      • 77
                                      • Indonesia
                                      i have buy ch314a, 1.8v adapter, and ene adapter. i have try by connect the ksi4, ksi5, ksi6, ksi7 and kso3 to the ch314a by use ene adapter which is this https://www.tokopedia.com/pratamakom...rt809f-flasher . i have also connect kso3 to ground, but i connect the vcc to vcc in bios pin 8 which is 3.3 volt. when i detect the ic in neoprogrammer, it says "ic not respond". should i connect the vcc to vcc kbc? or should i try use 1.8 adapter?
                                      • ndarjo21
                                        • Nov 2021
                                        • 77
                                        • Indonesia
                                        i have try use 1.8v adapter without connect the vcc in the ene adaptor to anywhere. but it still says " ic not responding". when i use 1.8v adapter, the led in ene adapter turn off, when i not use 1.8v adapter, the led in ene adapter turn on.
                                        • jrodefeld
                                          Asus laptop won't boot (no power) - possible bad caps?
                                          by jrodefeld
                                          I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                                          The model:
                                          Asus Zenbook Pro Duo UX582L
                                          I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                                          However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                                          09-02-2024, 04:55 PM
                                        • Calidebear
                                          Dell 3537 laptop doesn't boot without embedded display.
                                          by Calidebear
                                          I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
                                          So checked the schematics to bypass this issue.
                                          Found something but I don't know how to read this schematics.
                                          Dell 3537 mobo 9982p rev 3
                                          Schematics attached,...
                                          03-29-2025, 11:37 AM
                                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                          09-06-2024, 09:30 PM
                                          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:47 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
