Couldnt Boot Laptop HP 14-bw087tu
  • ndarjo21
    • Nov 2021
    • 81
    • Indonesia
    Re: Couldnt Boot Laptop HP 14-bw087tu
    my ch314a and 1.8v adapter is good, i have use it to flash ic bios which have 1.8v vcc.
    • ndarjo21
      • Nov 2021
      • 81
      • Indonesia
      i try to use 1.8v adapter, and jump the from ene adapter directly to 1.8v adapter, when i click detect, it will show ic not responding three times, and when i click detect again, it show wrong device.
      • Stevedb
        Stevedb
        • Feb 2018
        • 624
        • Belgium
        Hi which bios chip you would program?
        • ndarjo21
          • Nov 2021
          • 81
          • Indonesia
          Actually not bios chip. But the kbc chip
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            Oh i do not think you can program it with ch341a programmer you wil need svod programer , rt809 or vertyanov programmer. But you can probly buy preprogrammedkbc chips too.
            • ndarjo21
              • Nov 2021
              • 81
              • Indonesia
              #26
              nooooo.... its too expensive... its kb9027, neo programmer not supported it? i have look in the neo programmer, there are kb902x. but i never read that kb9027 couldnt reprogrammed in ch314a, are you sure?
              • ndarjo21
                • Nov 2021
                • 81
                • Indonesia
                #27
                better buy svod or rt809 for flash kbc? which have most kbc support
                • ndarjo21
                  • Nov 2021
                  • 81
                  • Indonesia
                  #28
                  vertyanov or rt809f, which is better?
                  • ndarjo21
                    • Nov 2021
                    • 81
                    • Indonesia
                    #29
                    are you sure rt809f can program kb9027? cause it cheapest device
                    • ndarjo21
                      • Nov 2021
                      • 81
                      • Indonesia
                      #30
                      i have another laptop which is dead, the kbc is kb9029q and another one is it8685e, can rt809f flash that? or should i use vertyanov or svod?
                      • ndarjo21
                        • Nov 2021
                        • 81
                        • Indonesia
                        #31
                        i succesfully flash the kb9027q use ch314a programmer. i not jumper from vcc in ch314a to vcc of kbc before, so it doesnt read the kbc. but the problem still same, the R22 and 1R0 still have 0 volt. and i will trace again
                        • ndarjo21
                          • Nov 2021
                          • 81
                          • Indonesia
                          #32
                          I have check the voltage, S5_ON in kbc is measured, but pin 100 99 and 98 which is SPI_1.8V_ON, MAINON and SUSON is not measured. I check vcc 3 volt of kbc in L2000 is measured 3 volt, but when i check +1.8V_ECIO ,it measured 0 volt. when i trace 1.8 volt, it come from +1.8V_ROM which come from PR231 and go to PU14. in the PU14, the enable pin is pin 3 and pin 5, and that pin come from pin 100 and 99 in kbc. anyone can tell me?
                          • ndarjo21
                            • Nov 2021
                            • 81
                            • Indonesia
                            #33
                            i think the problem is mainon and the spi_1.8v_on, because that, the +1.8V_ECIO not detected. because that problem, PL15 and PL11 not worked. either that, the VRON pin 34 in U2000 which is enable the PL44 and PL46 measured 0 volt. How can a kbc just work in S5_ON pin?
                            • Stevedb
                              Stevedb
                              • Feb 2018
                              • 624
                              • Belgium
                              #34
                              Does the capslock on extern keyboard toggle?? Can you light up capslock?
                              • ndarjo21
                                • Nov 2021
                                • 81
                                • Indonesia
                                #35
                                i have check, when i connect the extern keyboard, the capslock not light up.
                                • ndarjo21
                                  • Nov 2021
                                  • 81
                                  • Indonesia
                                  #36
                                  resistance
                                  PL44 R22 17 OHM
                                  PL46 R22 8.48 OHM
                                  PL15 1R0 40.7 OHM
                                  PL11 1R0 0.926k OHM
                                  it is short to ground or normal?
                                  • ndarjo21
                                    • Nov 2021
                                    • 81
                                    • Indonesia
                                    #37
                                    where mainon, suson, SPI_1.8V_ON and VRON come from? it is from internal of kbc right? enable just from +3VPCU_EC and +3VPCU_KBC? if thats right, can it be the kbc is defective?
                                    • ndarjo21
                                      • Nov 2021
                                      • 81
                                      • Indonesia
                                      #38
                                      but if the kbc defective, why the ch341a programmer can read it kb902x in the software.
                                      • ndarjo21
                                        • Nov 2021
                                        • 81
                                        • Indonesia
                                        #39
                                        I chechk the rsmrst pin and dnbswon in kbc, it reads 3.3 volt. But when i check SUSB and SUSC, it reads 0 volt, it is normal? Or should i use oscilloscope to check the signal is exist or not. Cause i dont have oscilloscope. But i thought that the SUSB and SUSC exist, cause there are 3 and 5 voltage in the coil
                                        • ndarjo21
                                          • Nov 2021
                                          • 81
                                          • Indonesia
                                          #40
                                          what if i shorted S5_ON, SPI_1.8V_ON, MAINON and SUSON can it damaged the motherboard? because S5_ON is exist
                                          • jrodefeld
                                            Asus laptop won't boot (no power) - possible bad caps?
                                            by jrodefeld
                                            I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                                            The model:
                                            Asus Zenbook Pro Duo UX582L
                                            I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                                            However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                                            09-02-2024, 04:55 PM
                                          • Calidebear
                                            Dell 3537 laptop doesn't boot without embedded display.
                                            by Calidebear
                                            I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
                                            So checked the schematics to bypass this issue.
                                            Found something but I don't know how to read this schematics.
                                            Dell 3537 mobo 9982p rev 3
                                            Schematics attached,...
                                            03-29-2025, 11:37 AM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
