Fuses in Macbook Pro 2019 A2159
  • mp844
    • Dec 2021
    • 21
    • Poland
    Hi, would anyone have a boardview / listing of all the motherboard fuses on A2159, please?
    I made the mistake of connecting up another LCD (quick & dirty, for testing) without disconnecting the battery correctly, and now the laptop is bricked.
    It does take charge and I can see +12V line at numerous fuses on the board but I must be missing something (hoping it is a fuse!). Any help would be greatly appreciated..
    Happy New Year!
    Martin
  • Simplebeans
    • Sep 2021
    • 135
    Re: Fuses in Macbook Pro 2019 A2159
    Happy New Year!
    Martin
    Whats the board number usually it's found on the board?
    • mp844
      • Dec 2021
      • 21
      • Poland
      FV9945202
      VZKRGYB0
      1. 4G 742
      I hope this helps? If not, please let me know and I will have to extract the board first.
      • piernov
        • Jan 2016
        • 4437
        • France
        https://logi.wiki/index.php/Board_Nu...Book_Air_13.22
        • mp844
          • Dec 2021
          • 21
          • Poland
          Thanks, it's seems to be the one below, can anyone help with a complete fuses listing/boardview please? Or perhaps you know which fuses in your experience are likely to go when another display is plugged in to mainboard?
          A2159 MacBook Pro 13" Touch Bar Two USB C
          820-01598 2019 MacBook Pro 13"
          • mon2
            • Dec 2019
            • 14366
            See attached.
            Start with fuse F8400 which is the INPUT fuse to the backlight boost circuit.
            Meter in DC volts mode; 30+ volt scale should be fine.
            Red meter probe on F8400 & black meter probe to ground.
            Check & post the voltage reading on BOTH sides of this fuse.
            • mp844
              • Dec 2021
              • 21
              • Poland
              Firstly, many thanks for your time.
              I get 10.8V on both sides of this fuse.
              Remarks: laptop was off for nearly a month (I was away); so initially I was getting 0V on this and other fuses. Plugged in charger, I was able to see up to 40W draw on USB-C charge monitor. CPU heatsink got a bit warm. I can see the same 10.8V across other fuses on board and numerous capacitors. Laptop will not turn on though.
              • mon2
                • Dec 2019
                • 14366
                What is the voltage that is negotiated on the USB Type C connector ?
                Is it 5v or 20v after a few seconds of connecting the Type C power adapter ?
                Are you using the original power adapter ?
                • mp844
                  • Dec 2021
                  • 21
                  • Poland
                  It's the 96W Apple charger.
                  It has negotiated 20V and draws around 2A, has been for the past half hour, however this is not a steady draw and goes up and down a little, I saw 58W on it for a moment a few times. It fluctuates but definitely charges.
                  I'm sure it starts at 5V but then it must quickly negotiate 20V because my charge monitor does not pick it up.
                  CPU heatsink is warm, about 40degC, screen and keyboard are dead, no response to long press of power button.
                  edit: CPU fan spins a few rotation when CPU sink gets too warm. It still appears bricked. Thi swas hard to notice.
                  • mon2
                    • Dec 2019
                    • 14366
                    The 20V negotiations is good. This implies the USB power delivery controllers are functional and they are chatting with the external power adapter to select this power contract.
                    The PPBUS_G3H rail looks low for the Macbook Pro.
                    Reference:
                    https://www.logi.wiki/index.php?title=PPBus_G3H
                    1) Meter in resistance mode (2k is ok).
                    Remove all power.
                    Check the resistance to ground for F8400. What is the resistance ?
                    2) Meter in DC volts scale (30v+ is ok).
                    Check the PPDCIN_G3H_CHGR voltage. This should match what the USB Type C meter is reporting and should be ~20VDC.
                    See attached on a cluster of caps that can be used for this measurement.
                    • mp844
                      • Dec 2021
                      • 21
                      • Poland
                      Reference:
                      Remove all power.
                      Board removed, capacitors drained. I get around 12 MOhms (Mega) at F8400 in ref to GND. I plugged in USB-C daughterboard, charger with monitor, it negotiated 20V again and I measured 20.3V at the capacitor cluster.
                      n.b. I left it to fully charge overnight, and voltage at F8400 rose to 12.43V (remained at 12.4V after unplugging charger).
                      Will be happy to go through next steps, the board is out. Many thanks.
                      • mon2
                        • Dec 2019
                        • 14366
                        Hi.
                        See attached.
                        Measure and post the voltage for PP3V3_G3H.
                        • mon2
                          • Dec 2019
                          • 14366
                          In addition to the above measurements, check & post the voltage readings for each of the coils on the logic board (see attachment).
                          Each coil is linked to a local switching regulator. The coils are 2 pin devices, you can measure either side of the coil with the red meter probe (DC 20V scale should be fine).
                          Black meter probe to ground (shield is ok).
                          • mp844
                            • Dec 2021
                            • 21
                            • Poland
                            01 = 0V (MegaOhms in ref to GND)
                            02 = 5V
                            03 = 3.3V (PP3V3_G3H)
                            04 = 12.6V
                            05 = 0V (50 Ohm in ref to GND)
                            06 = 0.66V
                            07A= 0.66V (hidden under connector tape, to the left from inductor 7, R22)
                            07 = 0.72V
                            08 = 0.7V
                            08B= 0.8V (to the right from inductor 8, smaller one marked R47)
                            09 = 0.95V
                            10 = 1.2V
                            F8400 fuse = 12.6V
                            • mon2
                              • Dec 2019
                              • 14366
                              * this rail is for the LCD backlight which is not working so makes sense to be @ 0V
                              * L7702 on the logic board
                              * for the 1v0 rail required for the EDRAM
                              * the resistance @ 50 ohms is not a bad reading
                              Check & post the voltages linked to Q7702 (dual mosfet), pin # 1. You can use one of the capacitors shown in the top right of the schematic.
                              Use C7752 with red meter probe (20v scale) & black meter probe to ground.
                              • mp844
                                • Dec 2021
                                • 21
                                • Poland
                                +12.6V between that cap and GND.
                                • mon2
                                  • Dec 2019
                                  • 14366
                                  This is a good voltage.
                                  See attached. Measure and post the voltages on the Q7702 mosfet.
                                  Be very careful on measuring pin # 3 on the mosfet with the meter lead.
                                  • mp844
                                    • Dec 2021
                                    • 21
                                    • Poland
                                    Used a needle and a few measurements to be sure;
                                    Pin 3 of Q7702 = constantly fluctuates between -500mV...+200mV with momentary spikes up to 1V
                                    Pin 5 at the inductor/pad = 0V
                                    • mon2
                                      • Dec 2019
                                      • 14366
                                      See attached. Measure & post the ENABLE voltage for this switching regulator.
                                      • mp844
                                        • Dec 2021
                                        • 21
                                        • Poland
                                        0V at the pad, about 46kOhms, both in ref to GND.
                                        • bouch
                                          unlock macbook air A1932 2019
                                          by bouch
                                          hi
                                          i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                                          i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                                          i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                                          have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                                          I need help or information?
                                          Does anyone have the minat2 activator 1.4 software?
                                          Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                                          Thank yo...
                                          03-12-2025, 10:14 AM
                                        • Eniaro
                                          MacBook Pro 2019 A2159 (2-port) wont boot
                                          by Eniaro
                                          Trackpad clicks.
                                          Plugging in a genuine USB-C charger and any other charger = 20V and charges all the way.
                                          Plugging in a Dell USB-C dock or monitor causes the voltage to cycle endlessly between 5V and 19V
                                          The Caps Lock button doesn't illuminate.
                                          Holding the power button (fingerprint scanner) for 10 seconds stops the trackpad clicking temporarily, but it starts clicking again after 3 seconds.
                                          If I open the lid slightly, the trackpad stops clicking (it seems to be detecting the lid opening/closing).
                                          The keyboard backlight...
                                          11-27-2024, 04:25 PM
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                        • kuba2102
                                          MacBook Pro 2019 A2159 Replacing SSD does it need programming?
                                          by kuba2102
                                          Hi. I suspect the SSD has failed on this machine. I couldn't find answers googling it hence my question. Can you just take and replace SSD from another mac 2019 or it need to be programmed with serial numbers etc? Also eg. if my macbook is 128GB and using only one slot/bank for the SSD and another slot/bank is not being used (empty), can you remove the SSD from slot 1 and put it into slot 2, would it work? I know for a fact that those SSD are set in RAID partitions so if arranged in wrong order it's not going to work, but I'm curious if it needs programming also if the SSD can be soldered onto...
                                          09-01-2022, 12:58 PM
                                        • thuygsm
                                          Macbook pro A2159 EMC3301 no image, no CapsLocklight, only USB activity
                                          by thuygsm
                                          Hello! Please help with a strange disease that I have never encountered before.
                                          At first I got the following status:
                                          MacBook does not turn on. Current consumption is about 0.500-0.600A at 20V from USB-C.
                                          - no signs of rust, or spilled water
                                          - CPU gets hot, fan still spins, no Capslocks light
                                          then I cleaned it and I got the following video:
                                          - Cannot install software, and after a while I get a red screen and the whole thing freezes
                                          Macbook Pro A2159 / Bệnh lạ
                                          07-28-2025, 11:35 AM
