HP G7000 laptop screen split into 2
  • ramzi2019
    • Apr 2019
    • 56
    • tunisia
    I need to know what can cause the screen to be split into 2 for a hp g7000??
    the screen cable seems to be good and not damaged .
    I changed the screen with no result.
    The external vga port is functionning normaly.
    I also tried another memory card.
  • mon2
    • Dec 2019
    • 14215
    Re: HP G7000 laptop screen split into 2
    Try CTRL + '+' key combination a few times.
    • ramzi2019
      • Apr 2019
      • 56
      • tunisia
      thank you for the help but nothing happen.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        The screen cable may seems good but it has broken wires inside. Replace the lvds cable and see your problem resolved.
        • ramzi2019
          • Apr 2019
          • 56
          • tunisia
          Thanks for your precious help.
          That was right, some wires of the lvds cable was broken and I successfully repaired it.
          Thank you very much
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • spice_disc
            Vizio TV M50-C1 reboot cycle and static on screen
            by spice_disc
            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
            09-08-2024, 02:37 PM
