dell n5110 data problem
  • doctormasry
    • Dec 2019
    • 98
    • giza
    laptop dell n5110
    with white lcd changed u4901 now no white screen i see light but no data
    steeps
    change lcd and connector between mb and lcd no new
    chane cpu becouse motherboard is uma
    test out lcd on vga port data ok
    volt on lcd1
    pin 1 . 2 and 3 =19 v present ok
    ping 5 = LCD_BRIGHTNESS 3.3 ok
    pin 30 . 29 and 28 = 3.3 LCDVDD ok
    pin 27 = 3.3 3D3V_S0 ok
    pin 26 = 3.3 LCD_TST_C
    pin 24 and 25 =3.3v
    pin 23 and 22 =1.2 v
    any suggestions
  • doctormasry
    • Dec 2019
    • 98
    • giza
    Re: dell n5110 data problem
    no suggestions?
    • mon2
      • Dec 2019
      • 14012
      1) Can you see the video working for this laptop using the HDMI port & external monitor ? This is to confirm the laptop is working ok.
      2) Measure & post the voltages on the other LVDS lines.
      LVDS interface requires multiple interconnects to drive the display panel.
      If any one of the connections is missing, the display will not work.
      Double check that the LVDS connector is soldered properly and with no shorts.
      • doctormasry
        • Dec 2019
        • 98
        • giza
        laptop working on external monitor good
        lvds
        pin 1.2.3 = 19v
        pin 5 = 3.3
        pin 15 = 3.3 v
        pin 30.29.28 = 3.3 lcdvdd
        pin 26 = 0v LCD_TST_C
        • mon2
          • Dec 2019
          • 14012
          You missed the voltages for the highlighted pins on the LVDS connector. See my earlier post.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            HALL1(Located bottom right corner. Check Voltage Pin2 & Pin4 and update.
            • doctormasry
              • Dec 2019
              • 98
              • giza
              thanks @mcplslg123
              pin 2 is 0v
              pin 4and 5 = 3.3 v
              • doctormasry
                • Dec 2019
                • 98
                • giza
                all measurements are in the picture
                thanks
                • doctormasry
                  • Dec 2019
                  • 98
                  • giza
                  I MAKE jumper a wire between pin2 and pin4
                  but same still backlight ok no data
                  • mon2
                    • Dec 2019
                    • 14012
                    Pins 16 & 17 on the LVDS connector are too low for the LVDS connector.
                    Each is 0v78 ?
                    Remove the LVDS display and measure the voltage on 16 & 17 again.
                    Does the voltage change ? Hoping that the video display will still be driven with some signals over LVDS pins even though the display is removed. These pins should be @ 1v2 like the other data lines for the display.
                    Keep the display removed, do not attach any power -> meter in resistance mode (2k should be ok).
                    Red meter probe on pad to test; Black meter probe to ground (shield is ok).
                    Check the resistance to ground on pin #16 of the LVDS connector. Reading ?
                    Repeat for pin # 17 of the LVDS connector. Reading ?
                    If the reading is too low then there may be a fault in the trace / shorting to ground.
                    The schematic shows that there should be nearby caps to ground for each of the LVDS signals, including the pins 16 & 17. Can you find them ? Once they are found, carefully remove them off the PCB as they may be causing this data pair to be lower than the others. Just remove one at first and see if the voltage on the linked pin on the LVDS pin goes higher. Then remove the next one and check again. Perhaps liquid damage / corossion in this area? Worth a review. If no improvement, then place the caps back. See attached.
                    After the above, it appears that the PCH is the direct video connect to this display. If the display is 100% known good and compatible with this box then it should work but concerned about the pin 16 & 17 voltages being lower than the others.
                    • Achille15
                      Dell N5110 problem
                      by Achille15
                      so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
                      03-29-2025, 04:41 PM
                    • toti24
                      (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
                      by toti24
                      dell precision m4600 laptop
                      i7 2760qm
                      8gb ram 750gb HDD
                      intel hd 3000 integraded and nvidia quadro 2000m
                      pleasea bear with me english isnt my language and ill try to be as clear as possible
                      note i live in mexico in a very small town..
                      thank you.
                      laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
                      the brick happened when i was installing win 10 using usb.
                      used rufus and officia microsoft.iso
                      it finished copying files from usb...
                      03-06-2022, 08:39 PM
                    • SDNarcia
                      Dell 15R-5521 keyboard problem (KBC?)
                      by SDNarcia
                      Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                      As additional information,...
                      07-20-2024, 10:47 PM
                    • masoksian
                      Dell latitude e7470 not turn on .power buton on off and Run Power problem
                      by masoksian
                      I am dealing with the problem of turning on and off my Dell e7470 notebook.
                      The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                      The system does not turn on, there is no post.
                      I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                      The problem continues in the same way.
                      I tried to turn on the Fn key, nothing came to the screen....
                      02-15-2025, 12:08 PM
                    • MahmoudNasser
                      Dell 7480 problem with freezing during the Windows loading process
                      by MahmoudNasser
                      Hello everyone, I wish you a happy day.
                      I have a Dell Latitude 7480 laptop that has a problem with freezing during the Windows loading process. If it manages to boot up, it becomes very slow and doesn't load anything from the desktop.
                      Device Data
                      Model Dell Latitude 7480
                      CPU:i7-7600U
                      SN:7T58PL2
                      MP PartNumper:CAZ20 LA-E131P Rev:1.0 A00
                      Bios Chips:W25Q128BV
                      The attempts that have been made to solve the problem have not yielded any results.
                      1. Changing the M.2 and M.2 Nvme hard drives.
                      2. Trying...
                      07-09-2023, 05:04 AM
