MSI Laptop GP62M Leopard - MS-16J91_1 no power
  • corrize
    • Apr 2021
    • 294
    • France
    Hello, I have a MSI Laptop GP62M Leopard - MS-16J91_1
    The laptop is full dead : no led, nothing at start button.
    I'm working on motherboard disassembled. I measured 19v at high side mosfets but 9.7v at gates of both. It is normal pls ? Is it the charging chip providing the gates voltage ?
    3-5v chip is good but it provide 4.75v : too low ?
    No 3.3v at bios chip
    19v rail is ok on board, but no voltage on anyt coil.
    No short nowhere.
    Not an easy one. I have schematic. What should I check first pls ?
  • mon2
    • Dec 2019
    • 14660
    Re: MSI Laptop GP62M Leopard - MS-16J91_1 no power
    Link or post the schematic. If it is on this forum, just link it.
    Post the voltages on the first 2 mosfets.
    Start with the charger IC. Post all voltages on the charger IC.
    Next, remove all power. Meter in resistance mode (2k is good). Then measure the resistance to ground of each coil. Red meter lead on coil. Black lead to any good ground.
    Post any low resistance reading.
    • mon2
      • Dec 2019
      • 14660
      Found the schematic in my database.
      According to other techs, check PR214 which is a common fault for the logic board that will not power on. The resistance for PR214 is too large.
      Check the resistance with NO power to the board. Meter in resistance mode (2k setting is ok). Then check the resistance across this part with the meter.
      What is the reading ? It should be about 1.8K ohms. If the reading is much higher, then remove off the board and check the resistance again for this part.
      Again, should be about 1.8k when off the logic board. Replace or solder back with a good 1.8k resistor.
      • corrize
        • Apr 2021
        • 294
        • France
        Thanks mon2, it is a good way : coil of 3v (from the 3-5v chip) is shorted (0 Ohms). I'm following this way.
        PR 214 ; 1.25k measured, I guess it's good
        I post schematic. Where do you find the boardview pls ?
        I keep in mind the 9v at gates of high side mosfet and check the IC charging. I will see that after.
        • mon2
          • Dec 2019
          • 14660
          See attached for the boardview file. Hope it will load in your boardview file viewer. If not, post back.
          • corrize
            • Apr 2021
            • 294
            • France
            Thanks for boardview.
            Update : I tryed to inject voltage (1.2v) on coil (shorted) of 3v (from 3-5v chip) with 4 Amp, and nothing, no hot spot nowhere on the board. I don't use thermal camera, I use my fingers. The board keep cold. Incredible.
            I supposed 3v coil mosfet (PQ40) was faulty (drain-source shorted) but it is not hot, even with alcohol on.
            Same with 3-5v chip.
            Same with big chip (chipset) ; no hot spot.
            Can I try with 5 amp ? It's a big MSI board, but 5 amp seems very high.
            • mon2
              • Dec 2019
              • 14660
              Can you list the coil you are observing to be shorted to ground ?
              With the meter on resistance mode (2k setting); red meter probe on coil & black meter probe to ground - the resistance reading is close to 0 ohms ?
              Wait till we / others can review. There has to be a shorted part but want to see the details of the coil.
              • corrize
                • Apr 2021
                • 294
                • France
                0 Ohms between coil and ground. True short. It’s only coil shorted.
                I can follow this short (0 Ohms) between drain and source of direct linked to this coil : mosfet (PQ40). Pin 1 2 3 (source) are to ground on schematic.
                So I supposed this mosfet is faulty, because it sould be OL betwenn drain and source. But no hot spot on it.
                I just tryed 5 amp and no hot spot nowhere. At this power, only big chips like chipset can keep cold. An The board is cold, cold.
                I supposed short inside connector now. I will check.
                • mon2
                  • Dec 2019
                  • 14660
                  Which coil?
                  • corrize
                    • Apr 2021
                    • 294
                    • France
                    The coilis directly linked with PQ40 : the name of this coil is : CHOCKE11
                    P45 in the schematic.
                    • corrize
                      • Apr 2021
                      • 294
                      • France
                      I measured caps shorted on chipset’s PCB ; 0 Ohms. It’s weird, I sent 1.2v 5A and it keeped cold, even with temperature prob taped on it, the temperature don’t moved.
                      So chipset dead.
                      Thanks for your help.
                      • abudo
                        • Jan 2020
                        • 29
                        Hi thanks for sharing this. I just have a problem opening this on openboardviewer. Which boardviewer should I use? Thanks
                        • mon2
                          • Dec 2019
                          • 14660
                          Use the boardviewer posted on this thread:
                          https://www.badcaps.net/forum/showthread.php?t=117486
                          • abudo
                            • Jan 2020
                            • 29
                            Hi thanks for you prompt reply.
                            I have same model with same problem (no power)
                            I have a question. I can measure 19v on PQ41 in pin 5. What could be the voltage output from PQ41 pin 123 and pin 4? Im not getting any voltage output on this chip. Whats the best thing to do?
                            Your tips will be highly appreciated
                            • mon2
                              • Dec 2019
                              • 14660
                              See attached. Start with the power adapter connected and confirm the voltage to ground of the noted points of interest.
                              Need to know if the DCin mosfets are working to power the charger IC.
                              Meter in DC volts (30V or higher) scale.
                              Red probe on the points to measure. Black to ground (shield is ok).
                              Post each measurement.
                              • abudo
                                • Jan 2020
                                • 29
                                Yes I can measure 19v on these points
                                • mon2
                                  • Dec 2019
                                  • 14660
                                  Review the net name for the power (VCC) pin of the flash memory IC. Then search for that net name till you find the regulator who creates that power rail.
                                  Check if that rail is being enabled or not.
                                  Post your findings.
                                  • abudo
                                    • Jan 2020
                                    • 29
                                    thanks I will chase the rails on BIOS chip.
                                    Thanks again
                                      Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                      This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                      09-06-2024, 09:30 PM
                                      Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                      This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-06-2024, 08:47 AM
                                    • Nagy Daniel
                                      Lowest possible resistance on laptop motherboard rail - Guide Table request
                                      by Nagy Daniel
                                      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                      So, I generated a table with AI so I can...
                                      03-04-2025, 08:24 AM
                                    • RdeveLabs
                                      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                      by RdeveLabs
                                      To all the members here...
                                      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                      05-05-2025, 04:59 AM
                                      Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                      This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-07-2024, 06:11 AM
