samsung NP300E5
  • baki60
    • May 2020
    • 78
    • Türkiye
    samsung NP300E5
    led green red green red
    no trigger where should i watch
  • mon2
    • Dec 2019
    • 13834
    Re: samsung NP300E5
    See attached.
    Connect the power adapter. Meter in DC volts (20V or higher is ok).
    Carefully, measure the voltage to ground of each test point on the charger IC.
    The charger IC is U509 - see attached.
    Interested in the voltage readings for:
    ACN
    ACP
    REGN
    ACDRV
    VCC
    Post each measurement.
    • baki60
      • May 2020
      • 78
      • Türkiye
      Re: samsung NP300E5
      What program should I open it with?
      BoardViewer 2.1.0.8-
      it didn't work expert
      • mon2
        • Dec 2019
        • 13834
        Re: samsung NP300E5
        Try the attached.
        • baki60
          • May 2020
          • 78
          • Türkiye
          Re: samsung NP300E5
          black screen
          Originally posted by mon2
          Try the attached.
          • baki60
            • May 2020
            • 78
            • Türkiye
            Re: samsung NP300E5
            ACN 18.5
            ACP 18.5
            REGN 6.0
            ACDRV 24.5
            VCC 18.5
            these are experts
            • mon2
              • Dec 2019
              • 13834
              Re: samsung NP300E5
              These are good values for these pins.
              With the adapter connected, check the voltage to ground of each coil (inductor) on the logic board.
              You are checking for any low voltage measurements on the coil to ground. Each coil is linked to a local buck switching regulator. If the coil is with a low or zero voltage, that power rail could be defective or disabled due to a shorted part. A shorted part will consume too much current and the regulator will sense this fault and turn off the regulator.
              Otherwise, you need to review the BIOS devices on the logic board which may be corrupt.
              • baki60
                • May 2020
                • 78
                • Türkiye
                Re: samsung NP300E5
                I solved the problem master
                bios yazdım düzeldi
                thank you for your interest
                • baki60
                  • May 2020
                  • 78
                  • Türkiye
                  Re: samsung NP300E5
                  bios yazdım düzeldi
                    09-07-2024, 05:50 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
                    Samsung Galaxy Book Flex NP950QCG-X01DE Notebook Specification for Upgrade or Repair
                    This specification for the Samsung Galaxy Book Flex NP950QCG-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-X01DE boardview and NP950QCG-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 06:20 PM
