The new 3.3v and 5v Regulators i need a clarity here
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello guys
    i was working on the new lenovo laptop with the new power supply for 3.3v and 5v, below on the picture i circled a resistor that was installed on the Vin power rail for the 3.3v always chip, but i dont understand the fuction and use of the resistor, why it was installed...Please anyone whose more advanced can assist please
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: The new 3.3v and 5v Regulators i need a clarity here
    That resistor is a pull-down resistor for the enable pin. But it is strange indeed because EN is connected to Vin. So I guess they had a design change but did not remove the resistor.
    • mnciks11
      • Aug 2019
      • 345
      • south Africa
      Ey I was so confused my brother
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        that pull dow resistor is for put voltage down fast from capacitors to fast swith down. if it was not there the capacitor can hold charge and EN signal will be active for long time.
        every en signal must have capacitor and resistor paralel to ground like EN1 signal
          • 21914
          The resistor isn`t installed on some other compal boards,it could be a mistake in the schematic ,they didn`t mark it as @ no-stuff.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            I agree with @smdflea
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              Yup, I would say PR339 should not be @ and PR335 should be.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Exactly. You find out the mistake in diagram.
                • reformatt
                  • Feb 2020
                  • 1505
                  Refer to the datasheet, enable pin is not meant to be left floating. So the 1M resistor ties that logic line to ground when no voltage is present. Prevents erratic operation when power is first supplied.
                  • jinu_j
                    by jinu_j
                    Hi
                    05-03-2025, 10:51 PM
                  • mikey5791
                    Need help to replace burned resistor in 350w atx psu
                    by mikey5791
                    Hi to all forum members,
                    Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                    The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                    Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                    Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                    12-26-2024, 04:55 AM
                  • MidnightRoller
                    Can a resistor lose resistance after hot air?
                    by MidnightRoller
                    I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                    I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                    02-02-2022, 11:46 PM
                  • artvandalai
                    What resistor ohm will work better to repair this waterpik?
                    by artvandalai
                    The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                    01-05-2025, 04:10 PM
                  • chth96
                    Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                    by chth96
                    I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                    Since then, This AC/DC adaptor have been out of order.
                    But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                    After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                    And Is there any possibility that it will suddenly explode as well as to be out...
                    12-03-2023, 04:40 AM
