acer predator 791g no power
  • mosfetratus
    Sure Not
    • Feb 2019
    • 174
    • Resistron
    During use laptop simply shut off. also i was using throttlestop @ -150mV if this has anything to do with the problem.
    when plugged in power supply goes to short protection, gives 0.50V.
    Should i inject 19v into main power rail?
  • mon2
    • Dec 2019
    • 14077
    Re: acer predator 791g no power
    Hi.
    1) Never just inject voltage onto rails till more is known about the condition of your logic board.
    2) Is your model also known as the ACER ASPIRE ?
    3) PU4401 is the first mosfet that is mated with the DC adapter. We can start with that investigation.
    Do you have the schematic & boardview files handy ?
    4) Does your logic board look like the attached ?
    • mosfetratus
      Sure Not
      • Feb 2019
      • 174
      • Resistron
      Originally posted by mon2
      Hi.
      acer predator g9-791g. Sadly i dont have schematics. p5ncn/p7ncn main board rev: 2.0
        • 20745
        Schematic,revision 1 but should be ok https://www.badcaps.net/forum/showthread.php?t=82221
        Edit: and a boardview https://www.badcaps.net/forum/showpo...75&postcount=6
        • mon2
          • Dec 2019
          • 14077
          Ok. Found the version 1.0 schematic in the database and perhaps v2.0 of the boardview file.
          Does the attached look the same as yours ?
          It is tied to the encrypted viewer that does not allow for saving so cannot share.
          • mosfetratus
            Sure Not
            • Feb 2019
            • 174
            • Resistron
            q8802 pin 5-8 is 5Ohmn, 1-3 77kohm, 4 is 100kohm. first mosfet
            • mosfetratus
              Sure Not
              • Feb 2019
              • 174
              • Resistron
              Originally posted by SMDFlea
              strange that 17 and 15 inch models share identical boards. as its pretty accurate to mine
              • mosfetratus
                Sure Not
                • Feb 2019
                • 174
                • Resistron
                measured ohms on l8001 and i get 2.8, which is vcore. i think it's gg for the cpu
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  You have short in B+ or +19V rail. Remove R8800 and measure resistance on pin5-8 of Q8802 again. It should go up. Now measure resistance on R8800 both pads. The pad which is showing short needs voltage injection but max 1V. You can increase the Amp as much as you can. Something is likely to hot up. Find out.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    That's fine. Dont mess unnecessarily here.
                    • mosfetratus
                      Sure Not
                      • Feb 2019
                      • 174
                      • Resistron
                      pad 2, which is ac-bat-sys, is 5ohm. at this moment i need to fix my bench supply by replacing tl594c. Wait for update and thanks alot for the help . my shop only have tl594cd, is it ok to replace?
                      • piernov
                        • Jan 2016
                        • 4435
                        • France
                        Always check for shorted high-side MOSFET before injecting anything.
                        • mosfetratus
                          Sure Not
                          • Feb 2019
                          • 174
                          • Resistron
                          i tested 8 pin mosfets that connects to ac bat sys. all look fine. problem is, that is not dead short.
                          • mosfetratus
                            Sure Not
                            • Feb 2019
                            • 174
                            • Resistron
                            found short. u8006 "advanced mosfet" :/ without injecting voltage, was too keen to findout.
                            is there a more available ic to cis631, hard to find any.
                            • mosfetratus
                              Sure Not
                              • Feb 2019
                              • 174
                              • Resistron
                              got mosfets but with G not T. Replace and computer works.
                              But i get artifacts. Screen is without artifacts when i uninstall intel drivers. Sheit.
                              https://imgur.com/a/9UWjBLp
                              • mon2
                                • Dec 2019
                                • 14077
                                I think your screen resolution or refresh rate is too high for this display panel.
                                Test the idea with power up but run in SAFE mode -> then boot into Windows.
                                This will force the screen resolution to be VGA mode = 640x480 and see if you can read the graphics now with the display.
                                Once this is confirmed working, proceed to change the device driver settings for this display to be a lower resolution and lower refresh rate till you can max out the screen resolution (ie. 800x600, etc. and go up from there).
                                • mosfetratus
                                  Sure Not
                                  • Feb 2019
                                  • 174
                                  • Resistron
                                  bios, safe-mode looks correct. Tried to test with each ram removed - same problem. I can't change refresh rate or make custom Hz. Only resolution, but still same problem with different resolution.
                                  • mon2
                                    • Dec 2019
                                    • 14077
                                    Meaning that your display does not look like the shared 'overscan' image ?
                                    You can read the text and view the 640*480 graphics in safe-mode ?
                                    • mosfetratus
                                      Sure Not
                                      • Feb 2019
                                      • 174
                                      • Resistron
                                      Image is scaled OK in regular mode. Safe-mode works in 1080p rez.
                                      • mosfetratus
                                        Sure Not
                                        • Feb 2019
                                        • 174
                                        • Resistron
                                        furmark is like this :\
                                        https://imgur.com/a/VoquX0n
                                          Acer Predator Predator Helios 300 Notebook Helios 300 Specification for Upgrade or Repair
                                          This specification for the Acer Predator Predator Helios 300 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Predator Helios 300 boardview and Predator Helios 300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:35 AM
                                        • survivalbloke
                                          Acer Predator Helios 300 - will not power up if battery is CONNECTED
                                          by survivalbloke
                                          This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                                          06-25-2025, 12:20 PM
                                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:28 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
