acer predator 791g no power
  • mosfetratus
    Sure Not
    • Feb 2019
    • 174
    • Resistron
    Re: acer predator 791g no power
    Without charger laptop constant restar, then into recovery window. In safe mode uninstall drivers works ok.
    • mon2
      • 13856
      Sounds like you have the wrong device drivers for this computer. Check with Acer on the proper video device driver for your chipset and computer model.
      Every video chipset offers a basic compatibility to allow for generic drivers to be used for low resolution like VGA (640*480) resolution. This is why you are working ok in SAFE MODE.
      For higher resolution and higher refresh rates, special device drivers are required. Do not assume the video chipset drivers from other source will work on the box. They may have been modified specifically for this laptop model. Only use the video drivers from the manufacturer of the laptop to remain fully compatible.
      • mosfetratus
        Sure Not
        • Feb 2019
        • 174
        • Resistron
        Drivers i use worked fine before the incident.
        acer driver - same
        HDMI - same.
        Well it should work fine with Display port, since it goes direct to NVIDIA.
        • mosfetratus
          Sure Not
          • Feb 2019
          • 174
          • Resistron
          Originally sic631 t was soldered, i received with g manufacturer. T has floating ground on pin 4, and on g chip pin 4 is grounded.
          https://cdn.badcaps-static.com/pdfs/...a40e178c24.pdf
          Without battery computer crashes into blue screen when trying to launch furmark.
            Acer Predator Predator Helios 300 Notebook Helios 300 Specification for Upgrade or Repair
            This specification for the Acer Predator Predator Helios 300 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Predator Helios 300 boardview and Predator Helios 300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-06-2024, 08:35 AM
          • survivalbloke
            Acer Predator Helios 300 - will not power up if battery is CONNECTED
            by survivalbloke
            This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
            Yesterday, 12:20 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
            This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
            09-12-2024, 03:28 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
