Acer Predator Helios 300 - will not power up if battery is CONNECTED
  • survivalbloke
    • Aug 2021
    • 312
    This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening. Thanks in advance!
    Model PH315-54-748Y
    SN: NHQC5AA0011440BA443400
    Board GH51G LA-L181P Rev 1B
  • mon2
    • Dec 2019
    • 14736
    Review the 2nd mosfet.
    • survivalbloke
      • Aug 2021
      • 312
      2nd mosfet measures 19.8v on source and drain, 25.9v on gate.
      • mon2
        • Dec 2019
        • 14736
        Check the battery mosfet. Suggest to remove all power and check the resistance across the source / gate / drain pins.
        • survivalbloke
          • Aug 2021
          • 312
          There are three mosfets beside the BQ chip.
          PQB6: was first readin 6.5k source and drain, 125k source and gate, but now, somehow it is reading 9M source and drain, and I checked a third time and getting 7M source and drain.
          PQB5: 21M source and drain, 105k source and gate
          PQB2: 21M source and drain, 13M source and gate
          Question about mosfets... If I have my meter in diode mode, with Red - Source and Black-Drain, I should get ~0.5v, but if I reverse that, I should get OL, correct? If that's the case, then my first DCin Mosfet is working correctly, but the second one, along with all three of the mosfets near the BQ chip show 0.45 with red on source and black on drain, but if I reverse those, I get 1.5v and it steadily increases. If I'm understanding, that is not normal, at least for N channel mosfet, correct?
          • Sephir0th
            • Oct 2020
            • 1289
            These measurements aren't conclusion when done inside of the circuit. There are always other components which interfere. This means when you want to make absolutely sure, you need to remove the Mosfets in questiin and measure them out of circuits. In-Circuit you are normally good to go as long as a Mosfet (in the DC-IN circuit) measure above 1 KiloOhms in any direction.
            But generally spoken, 25V at the Mosfets gate are already enough to tell they are good.
            Does battery power reach the Main power rail when connected only (without charger)?
            FairRepair on YouTube
            • survivalbloke
              • Aug 2021
              • 312
              Sorry for such a delayed response. Yes, I have verified battery voltage on the main rail with charger disconnected.
              • survivalbloke
                • Aug 2021
                • 312
                Anything else I can check, or should I just give up on this board?
                  • 22157
                  PR203 resistance
                  • survivalbloke
                    • Aug 2021
                    • 312
                    Originally posted by SMDFlea
                    PR203 resistance
                    .99k
                    • mon2
                      • Dec 2019
                      • 14736
                      Connect only the power adapter. Share the voltage to ground on each pin of PDB1.
                        • 22157
                        Did you check PQB4
                        • survivalbloke
                          • Aug 2021
                          • 312
                          PDB1:1 = 19.57
                          PDB:2 and PDB:3 = 19.88, which is the voltage I get at the DC jack. I'm not an expert, but shouldn't I have no voltage on +19VB with the battery disconnected?
                          • survivalbloke
                            • Aug 2021
                            • 312
                            Did you check PQB4
                            PQB4 seems OK, since I'm getting charger voltage out of it. That's a correct statement, right?
                            • mon2
                              • Dec 2019
                              • 14736
                              post # 13 - correct. This DUAL diode is defective. Replace it.
                              • survivalbloke
                                • Aug 2021
                                • 312
                                Odd, I replaced that diode with one off another board, but I still get charger voltage on both the inputs. Output on pin1 is 19.3v now.
                                • mon2
                                  • Dec 2019
                                  • 14736
                                  My bad. This DUAL diode is wired to accept the input from the raw adapter voltage and other leg is from the main power rail. Often, the dual diode is with raw adapter voltage AND the other leg is from the battery voltage (not the main power rail).
                                  Go back to the battery mosfet @ PQB2. Measure the voltage to ground on each pin (source / drain / gate). Post each measurement. Do this with the power adapter connected.
                                  In this case, this mosfet should be DISABLED.
                                  • survivalbloke
                                    • Aug 2021
                                    • 312
                                    Disabled would be connecting source to gate, correct? Do I do that while the power adapter is connected?
                                    Looks like I'm getting charger voltage on drain and .2v on source and gate.
                                    • mon2
                                      • Dec 2019
                                      • 14736
                                      No bypass tricks yet. With the adapter & battery connected, you are measuring a gate voltage of 0v2? Is this correct? If yes, this is OK since this low voltage is keeping this mosfet OFF / DISABLED. The mosfet is a N-channel part so the gate must be low to disable and higher than the voltage being passed between source / drain to enable.
                                      Can you confirm the gate voltage again with both the adapter & battery? Then disconnect the adapter and the battery voltage should be passed onto the main power rail. Then the gate voltage will be a boosted voltage and should be higher than the battery voltage. Confirm it.
                                      • survivalbloke
                                        • Aug 2021
                                        • 312
                                        No, the previous reading was with charger connected only. When I connect charger AND battery, I now get charger voltage on drain and 15.3v on source and gate.
                                        • survivalbloke
                                          Acer Predator PT516 - no power, drawing 2.8a lid closed, battery connected
                                          by survivalbloke
                                          This is a Predator PT516-51s laptop, serial number is rubbed off. Board is LA-L211P Rev 1A. Charging light is on, machine draws 2.8a lid closed. If I press the power button, I get a blue power light indicator about 5 seconds, then it goes back off. I pulled the board to discover that with battery and AC connected, battery mosfet 1 light up under thermal. I then verified a short to ground on battery mosfet 2 source. If I inject voltage there, my PSU goes to current limit, but nothing illuminates on the board - anywhere, either side. I removed mosfet 2 but still have the ground short at source....
                                          10-21-2025, 01:35 PM
                                          ACER Predator Predator G6-710 I108022 NL Predator G6 i7-7700K Specification for Upgrade or Repair
                                          This specification for the ACER Predator Predator G6-710 I108022 NL can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Predator G6-710 I108022 NL boardview and Predator Predator G6-710 I108022 NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-12-2024, 03:28 PM
                                          ACER Predator Predator Orion 9000-600 I81070-01 NL Predator i7-8700K Specification for Upgrade or Repair
                                          This specification for the ACER Predator Predator Orion 9000-600 I81070-01 NL can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Predator Orion 9000-600 I81070-01 NL boardview and Predator Predator Orion 9000-600 I81070-01 NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          Acer Predator PH317-56-78JZ Notebook Helios 300 Specification for Upgrade or Repair
                                          This specification for the Acer Predator PH317-56-78JZ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH317-56-78JZ boardview and PH317-56-78JZ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 06:38 AM
                                          Acer Predator PH315-55 Notebook Helios 300 Specification for Upgrade or Repair
                                          This specification for the Acer Predator PH315-55 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH315-55 boardview and PH315-55 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Acer...
                                          09-07-2024, 06:21 AM
