Please help: Asus fx506l no power
  • Lukosiukas
    • Jul 2018
    • 106
    • Lithuania
    Hi guys, got interesting problem : Asus fx506l with dabkxdmb8e0 board. It had liquid damage on palm rest (motherboard clean af), 19v is present but no 3.3v, 5v. Checked all coils, no-one had short to ground. I'm thinking the ITE IT8987VG is bad. Please confirm my suspicion. Plugin in without battery, orange light is blinking, sometimes power led turns on like for .1 seconds.
  • Repdata
    • May 2020
    • 67
    • Deutschland
    Re: Please help: Asus fx506l no power
    Reprogram ITE IT8987VG for testing
    • Lukosiukas
      • Jul 2018
      • 106
      • Lithuania
      Mine is BGA type, dont have any schematics or diagrams, is there any other possible way to test it ?
      • reformatt
        • Feb 2020
        • 1483
        Check the larger caps around the EC for voltage in standby. One or more should have +3.3V. Some designs don't switch on +3.3V till enabled by the EC. Logic voltage is usually provided by a LDO output of the 3.3V regulator IC.
        Look at each IC on the board part numbers to work out which one is providing the 3.3V and 5V rails.
        • mhd alaa
          • Oct 2021
          • syria
          pls did you have program it
          • tH0RiN
            • Apr 2016
            • 6
            • España
            Same here, Any ec.bin to download an reprogram?
              • 21692
              Laptop bios and EC requests go here -> https://www.badcaps.net/forum/forumdisplay.php?f=40
              • 5o5
                • May 2018
                • Russia
                This EC is self-programming from bios... Look at the schematics
                • guruji
                  • Oct 2012
                  • 122
                  • India
                  check the spi resistor to hold 7pin should be 3.3k
                  • luckyfahad79
                    • Oct 2020
                    • 6
                    • United Kingdom
                    how do you judje by this pic its bios programmable ..thanks
                    • jasko_jacker
                      • Oct 2014
                      • 1140
                      • italy
                      Usually ite is self programming , type ?
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • ShadowAi
                        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                        by ShadowAi
                        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                        03-15-2024, 10:46 AM
                      • meraklinetx
                        Asus Z97-a power cycle, no boot no cpu voltage
                        by meraklinetx
                        Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                        05-10-2023, 06:08 AM
