acer VA30-HB no power
  • nassih
    • Oct 2015
    • 280
    • morocco
    hi everybody a have an acer VA30-HB no power,the client informed me that the laptop had a display problem,work only on the external screen, after a few days it was no longer lit,
    i have 5vALW but 3.3v no its coming and disappear immediately when i plug adapter in , no short, U4501 replaced too.someone had similar problem?
  • nassih
    • Oct 2015
    • 280
    • morocco
    Re: acer VA30-HB no power
    3.1v in power switch
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Try replacing PT4502 with 330uf. What is the resistance on 3V Coil??
      • nassih
        • Oct 2015
        • 280
        • morocco
        diode mode red probe in gnd i have 0.360
        • nassih
          • Oct 2015
          • 280
          • morocco
          pt4502 replaced with 330uf same problem,3.3v coming then goes off
          • nassih
            • Oct 2015
            • 280
            • morocco
            maybe the cpu?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Originally posted by nassih
              maybe the cpu?
              Very unlikely. You can remove the 3V coil and try injecting 3V on the output side of this coil. make sure you dont have any shorting in cpu vrm area specially high side mosfets before injecting voltage.
              • nassih
                • Oct 2015
                • 280
                • morocco
                problem solved after replacing PR4502 resistor divider for creating VFB2,also the display problem was en LVDS connector LCD side it was damaged.
                tanks community
