820-01700 5v 0.25 a
  • wnt2fx
    • May 2021
    • 24
    820-01700 5v 0.25 a
    Hello everybody, I am a little desperate understanding this t2 board. Somebody worked on it before ( u3100) I guess reflowed. Liquid damage hit mainly the right wing but also u7800 area. L7811 looked horrible.
    First thing I did was carving out a short on ppbus ssd0. Not so much maybe 2 three layers deep "just" in the extent of pad 1 of c9573.
    I do not have the battery here.
    On all ports except on the master u3100 (XA= 0.01A and no pbus) I get 5v going up in 2 steps within 2 seconds to 0.24A and stays stable there. The only thing I notice gets warm is the t2 area and pp3v3_g3h_rtc supply. Not hot, only 30 C
    The last line in power sequence I get is PMU_ACTIVE_READY If I remeber right it is at 1.7v. I did not check all lines in the sequence there but many and they are all present in correct value e.g.
    PP1V1_SLPDDR
    PP0V9_SLPDDR
    PP0V82_SLPS2R
    PP0V8_SLPS2R
    PP1V1_SLPS2R
    PP1V8_SLPS2R
    https://logi.wiki/index.php/T2_and_C...28820-01700.29
    I do not have
    PMU_VDDMAIN_EN
    I replaced u3100 but unchanged.
    I checked some t2 lines to gnd ( logiwiki, me: redGND, blackGND )
    PPVDDCPU_AWAKE 10-15 Ohm 18 19
    PP0V82SLPDDR 30-40 Ohm 40 45
    PPVSSCPUSRAM_AWAKE 100-120 Ohm 170 253
    PP1V1_SLPS2R 1-2 kOhm 5,9k 5,3k
    PP0V9_SLPDDR 40 Ohm 55 61
    PP1V8_SLPS2R 4 kOhm 200k 13k
    will take a big nap now. After some hints / ideas I am more than willing to note down more measurements. best regards,
    k
  • wnt2fx
    • May 2021
    • 24
    Re: 820-01700 5v 0.25 a
    Ultrasonic cleaning --> still 0.25A@5V on three ports, still 0.01A@5v and so no PPDCIN_XA_G3H_F output on primary port.
    The power sequence says "H9M LOAD SECURE ROM, SMC BATTERY TRAP" right before creation of PMU_VDDMAIN_EN. I can get the battery today but wonder if this makes sense as long I have this amperage draw on three an no amps on primary port.
    U9580, R5620, C9580, C9581, C9583, C9584 and C9574 were removed in my first test now they are back but no change. I removed them because the area looked hit and after removing R5620 it was clearly a short on PPBUS_G3H_SSD0_SNS. To dig down the short I first removed theese components to then find out that the board is burnshorted in pad1 of C9573.
    I noticed a strong difference drop to GND on PP1V8_SSD0 (.06), compared to PP1V8_SSD1.
    Injecting 1V draw about a half mA
    also
    PP2V5_NAND_SSD0
    PP0V9_SSD0
    have a lower diodedroptoGND compared to their _SSD1 equivalants but not so much.
    • piernov
      • Jan 2016
      • 4435
      • France
      SSD chips are almost certainly dead. T2 won't initialize in that case. Must be replaced from donor board then must perform T2 DFU restore.
      • wnt2fx
        • May 2021
        • 24
        Hey piernov. Thanks for beeing here ! Generally: t2 must come from identical Board ?
        Now, I don’t think that the t2 is dead:
        Today I picked up the housing with battery and after I installed the logicboard I suddenly had 0.07A @ 19v input on all ports.
        I just connected fans, audio, power button and touch bar connections, not the battery yet ! So I was wondering if any of the flex connected where crucial to negotiate 20v an disconnected one after another. But still, logicboard in the housing, nothing connected and 19V. As usual on USB-C Ampmeter - 96W charger.
        I can not explain why I have no more 5v 0.25A / 0.01 A on main port symptomatic.
        The board power cycles it seems to me. Every about 20 seconds the drawn amps drop to 0.01 for a seconds and the fan wants to kick in.
        With battery plugged the draw raises slowly to about 0.8A before the reset / cycling occurs. The battery has some charge at least. When I disconnect the charger the board continues cycling and has stable voltages (until 20 seconds :-) on the few points I measured. No DFU recognition.
        ppbus 12.58V.
        correct value and stable until each 20 seconds:
        all SSD0 and SSD1 voltages
        PP3V3_G3H_RTC_X
        all major SLPs
        PP3V3_G3H_T
        PP5V_G3S
        How can I find out if t2 fails to fetch efi from nand or if it does not get to that point because some malfunctioning circuitry is the root ? What rails are clever to check now and/or would it be wise to take out the nand and check it?
        • wnt2fx
          • May 2021
          • 24
          ah I was too fast. You wre for sure speaking about the nand and not the t2. ssd chips must come from donor board because of eSPI ?
          I mean this board should be saved anyways but my first concern is data recovery here.
          Every 20 seconds ppbus drops from 12.58V to 12.28V.
          Please someone guide me on how to proceed with this one. thank you so much
          • francescoranchi
            MBP 13inch 2018 No Power - 820-00850-07 motherboard faulty (U3100 get's hot)
            by francescoranchi
            Hello everyone! I'm new to this forum but I hope I can find help and also help others at the same time!
            I have a MacBook Pro 13inch from 2018 and it doesn't turn on anymore it's completely gone. I was using it connected to a USB-C / HDMI adapter to connect it to the tv when it just turned off and it's not powering on anymore.
            I don't have an AMP meter so I can't see how many amps are getting pulled. The only symptom is the U3100 getting very hot, upon closer inspection it looks like it burned because there's a small hole on the top surface of the IC (I've already seen...
            09-16-2023, 07:08 AM
          • abajor
            A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
            by abajor
            Like title says A2141 came in with Water Damage, customer desperately wants the data.
            The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
            I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
            That said after cleaning up the...
            12-21-2024, 07:16 PM
          • liteott
            A1706 820-00239 u3100 #52 solder pad lost
            by liteott
            Try to Replace U3100 (CD3215C00 chip) it was pad #62 ppbus_g3hot short to Ground (CB300 take out still short) after remove off the U3100 "short" disappear.
            But for maybe temperature not enough high I found the solder pad #6 #50 #52 was lost and the #6 and #50 are GND I don't care but the #52 shows
            "NC_USBC_XA_RESET_L" and I want to see where this point to go or come but the board view shows no-where to go or come.
            Can you help me what this" NC_USBC_XA_RESET_L" to do and if I replace new ic chip without this #52 pad should the board working? (I...
            05-12-2021, 02:09 PM
          • spleenharvester
            AEG U3100-4-M Oven - RCD trips after heating up
            by spleenharvester
            Odd problem here with this oven. Once it's been heating for about 10 minutes the RCD trips. If you try and flip the RCD back on it will trip instantly until the oven has cooled down again.
            It's previously eaten an element so I replaced the element again - fault remains. My next thought was possibly the cooling fan, as the mainboard's cooling fan kicks in after about 10 minutes usually, but the resistance is testing OK.
            There's some quite badly melted plastic around the earth connection at the back of the oven, but I'm not sure if this damage was caused by the fault or...
            08-18-2022, 12:31 PM
          • Dallas90
            A2289 MacBook Pro - No power - Need help!
            by Dallas90
            I need your help with repairing this Macbook Pro. The fault is that the laptop does not power on. there are different current draw from the various USB ports.
            It is worth mentioning that there is no liquid on the board after a visual inspection. below you can see all readings and info after some diagnostic.
            There are also some thermal images uploaded in the thread.
            What should I do next? any suggestions?
            Thanks in advance.
            Current draw:
            USB port 1: 4.9V - 0.356A
            USB port 2: 4.9V - 0.056-0.60A...
            02-01-2024, 04:41 PM
