MBP 13inch 2018 No Power - 820-00850-07 motherboard faulty (U3100 get's hot)
  • francescoranchi
    • Sep 2023
    • Italy
    Hello everyone! I'm new to this forum but I hope I can find help and also help others at the same time!
    I have a MacBook Pro 13inch from 2018 and it doesn't turn on anymore it's completely gone. I was using it connected to a USB-C / HDMI adapter to connect it to the tv when it just turned off and it's not powering on anymore.
    I don't have an AMP meter so I can't see how many amps are getting pulled. The only symptom is the U3100 getting very hot, upon closer inspection it looks like it burned because there's a small hole on the top surface of the IC (I've already seen similar holes and they are typical of burned ICs), please see the picture!
    Now the question is:
    - Would the MacBook still turn on with battery power if I remove the U3100? or does the MacBook not turn on at all without it?
    - What do you think about the "hole" on top of the U3100? would you agree with me saying that it is probably burned?
    - What other things would you suggest I check to confirm the fault?
    Main question is if the Macbook still turns on without U3100 (doesn't have to be fully functional, just fan spin would be nice)
    Thanks for anyone that can help me!
    --> The hole that I'm talking about in the U3100 is the one above the letter "C" on the top left of the IC.
    IMAGE:
    https://drive.google.com/file/d/1S3Q...w?usp=drivesdk
  • mon2
    • 14801
    Re: MBP 13inch 2018 No Power - 820-00850-07 motherboard faulty (U3100 get's hot)
    U3100 will need to be replaced due to internal damage of the part. It is probably acting like a short to prevent further boot. At the very least the part needs to be properly removed, pcb pads cleaned so they are not solder shorting. Then you can test with only a battery but then the battery will not be able to charge.
    • abajor
      A2141 minor liquid damage, U3100 TOP port dead. Periodically boots to 20V ~1A on other USBC ports
      by abajor
      Just wondering if anybody has seen this issue. I'm assuming that all of the CD3217's are semi functional for the chips to request 20V from the PSU.
      This unit had some soda spattered up into the side vent. I ultrasonic cleaned the board, now getting this weird sometimes requesting 20V behavior, then it goes back to 5.2V ~ 25mA The U3200 jack cycles.
      I'm hoping this is just an issue with some components between the TOP Jack and U3100 and not U3100 itself.
      Not seeing anything unusual on thermals just some of the power supply inductors getting warm when it's requesting...
      08-25-2025, 01:13 PM
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
    • JarzabekPZ
      HUAWEI Matebook D15 Bom-WDQ9 - faulty onboard RAM
      by JarzabekPZ
      I have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
      08-08-2025, 03:40 AM
    • Spudgun
      Why doesn't current just bypass faulty capacitors.
      by Spudgun
      Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
      04-01-2025, 10:33 AM
    • abajor
      A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
      by abajor
      Like title says A2141 came in with Water Damage, customer desperately wants the data.
      The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
      I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
      That said after cleaning up the...
      12-21-2024, 07:16 PM
